SSID and PASSWORD read from SPIFFS file contain newline
hellraise007
Postby hellraise007 » Wed Sep 04, 2019 7:02 pm
Code: Untitled.cpp Select all
#include "SPIFFS.h"
#include <WiFi.h>
void setup(){
File file;
if(!SPIFFS.begin(true)){
Serial.println("An Error has occurred while mounting SPIFFS");
return;
file = SPIFFS.open("/test.txt", FILE_WRITE);
if(!file){
Serial.println("There was an error opening the file for writing");
return;
else
Serial.println("Opening the file for writing");
String ssid= "MAD";
String pass = "1234567890";
if(file.println(test))
Serial.println("SSID Written");
//file.close();
file = SPIFFS.open("/test.txt",FILE_APPEND);
if(!file){
Serial.println("There was an error opening the file for appending");
return;
if(file.println(test2))
Serial.println("Password Was Written");
file.close();
file =SPIFFS.open("/test.txt");
//read
if(!file){
Serial.println("There was an error opening the file for reading");
return;
else
Serial.println("Opening the file for reading");
Serial.println("File Content : ");
int i=0;
String s,p;
while(file.available())
if(i == 0)
s = file.readStringUntil('\n');
else
p = file.readStringUntil('\n');
i++;
file.close();
Serial.println(s.c_str());
Serial.println(p.c_str());
WiFi.softAP(s.c_str(),p.c_str());
Serial.print("Connecting to WiFi..");
// while (WiFi.status() != WL_CONNECTED) {
// delay(500);
// Serial.print(".");
void loop(){}
On execution the AP created ( client credentials passed) have a newline character at the end. How to remove the newline character from the end of the string?
boarchuz
Re: SSID and PASSWORD read from SPIFFS file contain newline
Postby boarchuz » Wed Sep 04, 2019 8:18 pm
file.println
file.print
lbernstone
Postby lbernstone » Thu Sep 05, 2019 1:14 am
s.trim();
p.trim();
