Bootloader freeze after repeated resets
Posted: Fri Feb 17, 2017 4:57 pm
I have a timer based "watchdog" which does a system reset when it fires by just doing a simple:
...which resets the system. This works fine - for a few times, but eventually freezes somewhere between the bootloads and running the setup() code:
The very first thing my code does in setup is:
...which is obviously not seen here - nor does anything else happen.
Like I said - it resets just fine the first few times, but then stops here.
Any idea why??
REG(RTC_CNTL_OPTIONS0_REG) = RTC_CNTL_SW_SYS_RST; // SYSTEM RESETCode: Select all
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
mode:DIO, clock div:1
load:0x3fff0008,len:8
load:0x3fff0010,len:1760
load:0x40078000,len:6668
load:0x40080000,len:252
entry 0x40080034
Serial.begin(115200);
Serial.printf("Hello, World!\n\n\n");Like I said - it resets just fine the first few times, but then stops here.
Any idea why??
