I followed the steps described here:
https://esp32.com/viewtopic.php?f=13&t=11265
And so far I have the toolchain working but I see that it's still compiling with the old g++.
$ idf.py -p /dev/ttyUSB0 flash
Checking Python dependencies...
Python requirements from /home/martin/esp/esp-idf/requirements.txt are satisfied.
Adding flash's dependency "all" to list of actions
Executing action: all (aliases: build)
Running cmake in directory /home/martin/esp/esp-idf/examples/get-started/blink/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 --warn-uninitialized /home/martin/esp/esp-idf/examples/get-started/blink"...
Warn about uninitialized values.
-- Found Git: /usr/bin/git (found version "2.17.1")
-- IDF_TARGET not set, using default target: esp32
-- ccache will be used for faster builds
-- The C compiler identification is GNU 5.2.0
-- The CXX compiler identification is GNU 5.2.0
-- Found assembler: /home/martin/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Check for working C compiler: /home/martin/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Check for working C compiler: /home/martin/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc -- works
-- Check for working CXX compiler: /home/martin/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++
~/esp/esp-idf/examples/get-started/blink$ git status
On branch feature/esp32s2beta
In this example I run like describes the forum post:
rm -rf sdkconfig build
idf.py -D IDF_TARGET=esp32s2beta menuconfig
idf.py build
At the end I got it working and it compiled. But it was hard to discover that the build directories and sdkconfig needs to be completely wiped out in order to run.
And also as a user, is a bit confusing that when you open the sdkconfig you see:
# CONFIG_IDF_TARGET_ESP32 is not set
CONFIG_IDF_TARGET="esp32s2beta"
CONFIG_IDF_TARGET_ESP32S2BETA=y
When the ESP32 target is set
Anyways so far working great. Looking forward running some benchmarking tests and even finding a way to compile a MESH Lamp and to set the WiFi per se (Since there is no Bluetooth)
Would like to know if it's possible to make this even easier so it has more user adoption. Looking forward how far I can go and to learn more of ESP-IDF
By the way I have a couple of questions:
- What is the LED GPIO of this, can I blink a LED?
- Where is the Board Schematic so I can discover more?
Thanks a lot in advance!
