Page 1 of 2
Command usage on ESP-WROOM-32 board
Posted: Mon Feb 20, 2017 2:34 am
by xiangcheng
This is resolved. thanks all.
I just received the new board ESP-WROOM-32 board but could not find any command help information. When typing "help" it shows "Please refer to document ssc_commands.xlsx ". when typing "AT" referring from "esp32_at_instruction_set_and_examples_cn", it shows nothing. Please help and thanks a lot.
Please refer to document ssc_commands.xlsx for detail
:>AT
:>AT+GMR
boot log is:
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0000,len:0
load:0x3ffc0000,len:2304
load:0x40078000,len:3788
ho 0 tail 12 room 4
load:0x40098000,len:532
entry 0x4009813c
* hello espressif ESP32! *
* 2nd boot is running! *
* version (V0.1) *
compile time 18:16:58
Re: Command usage on ESP-WROOM-32 board
Posted: Mon Feb 20, 2017 8:36 am
by jimbob
Hello
Does it run other firmware ok instead of the AT interpreter?
Posted: Mon Feb 20, 2017 8:46 am
by rudi ;-)
hi
have you seen this.
but i have also interesst in this list of ssc_command for testing ( and sure in the src of code )
@espressif
know, there is no further support in this, but the firmware is on the DevKit*S
perhabs you can provide the list of commands, cause this will be not the last ask for it from user's
thanks
Posted: Mon Feb 20, 2017 9:23 am
by rudi ;-)
ah have seen, its in the start getting 0.1
cause i have just in time not the modul at work desk,
you must test by self - not sure is this actually version or all command works
perhabs you have a try with this,
all zipped
SSC.zip
(797.34 KiB) Downloaded 1439 times
example:
Posted: Mon Feb 20, 2017 9:24 am
by rudi ;-)
Posted: Mon Feb 20, 2017 9:28 am
by rudi ;-)
Posted: Mon Feb 20, 2017 9:38 am
by rudi ;-)
feedback just now,
ok they work!
rudi :-)
Posted: Mon Feb 20, 2017 10:51 am
by xiangcheng
feedback just now,
ok they work!
rudi :-)
Really appreciated. but do these commands work? Whenever I set STA or AP mode, it seems the WiFi connection is NOT ok. Could you show me this correct commands to let me do wifi connection at SAP or STA mode?
1. STA
sta -S --> scan is OK. but sta -s <my_ap> doesn't work. I have set with op -S -o 1 to set to sta mode.
:>op -Q
+CURMODE:1
+MODE:OK
:>sta -s kkktpl
:>sta -Q
+JAP:DISCONNECTED
2. AP mode
same commands.
:>op -Q
+CURMODE:2
+MODE:OK
:>ap -S
+SAP:OK
:>ap -Q
+APCONFIG:empty_string,empty_string,11,0,0,4,100
:>ap -s test_ap
+AP:ERROR
:>ap -s test_esp -p 12345678 -t 1 -n 6
+AP:ERROR
:>ap -Q
Posted: Tue Feb 21, 2017 3:27 am
by rudi ;-)
hi
you want -SET
you forget to write -S after ap
-s is parameter for ssid
be sure you use big letter and small letter ( -S -s )
other example:
ssid: FIREBOOST
pass: not4upublic
encrypt: 3
channel: 5
ap -S -s FIREBOOST -p not4upublic -t 3 -n 5
and querry
ap -Q
// STATION and SOFTAP Mode
op -S -o 3
// check mode
op -Q
// SCAN AP
sta -S
// Status of Station ( JAP connected or disconnected )
sta -Q
// connect to a JAP
sta -C -s YOURSSID -p YOURPASSWORD
// Disconnect from connected JAP
sta -D
be sure you use big letter if document use big letter
it is differen if you write
op -q
// or
op -Q
..and so on..
hope this helps
in the posted docu all works fine
Posted: Tue Feb 21, 2017 9:39 am
by xiangcheng
Thanks it works now. Seems no throughput test or ping test tool. what's the real throughput for TCP/UDP tx/rx at 11NA/NG mode? And what's the stability and power status if running long time?
hi
you want -SET
hope this helps
