where to find ssc_commands.xlsx?
xiangcheng
Postby xiangcheng » Mon Feb 20, 2017 3:14 am
just post but could not find it. I received board ESP-WROOM-32 and could not find any command info. Could any one help on how to use command to connect one AP?
command:
:>at
:>ap
+AP:ERROR
:>help
supported command:
Please refer to document ssc_commands.xlsx for detail
boot info:
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0000,len:0
load:0x3ffc0000,len:2304
load:0x40078000,len:3788
ho 0 tail 12 room 4
load:0x40098000,len:532
entry 0x4009813c
* hello espressif ESP32! *
* 2nd boot is running! *
* version (V0.1) *
compile time 18:16:58
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size : 4MB
Partition Table:
## Label Usage Type ST Offset Length
0 factory factory app 00 00 00010000 00100000
1 rfdata RF data 01 01 00110000 00040000
2 wifidata WiFi data 01 02 00150000 00040000
End of partition table
Loading app partition at offset 00010000
section 0: paddr=0x00000020 vaddr=0x00000000 size=0x0ffe8 ( 65512)
section 1: paddr=0x00010010 vaddr=0x3f400010 size=0x05b64 ( 23396) map
section 2: paddr=0x00015b7c vaddr=0x3ffba720 size=0x01378 ( 4984) load
section 3: paddr=0x00016efc vaddr=0x40080000 size=0x00400 ( 1024) load
section 4: paddr=0x00017304 vaddr=0x40080400 size=0x126ac ( 75436) load
section 5: paddr=0x000299b8 vaddr=0x00000000 size=0x06658 ( 26200)
section 6: paddr=0x00030018 vaddr=0x400d0018 size=0x325b4 (206260) map
start: 0x400807ac
Initializing heap allocator:
WiFive
Re: where to find ssc_commands.xlsx?
Postby WiFive » Mon Feb 20, 2017 6:12 am
https://esp32.com/viewtopic.php?f=2&t=484&p=5205#p5200
You need to load another firmware before you can do something useful. Suggest to follow getting started guide for esp-idf.
xiangcheng
Postby xiangcheng » Mon Feb 20, 2017 6:54 am
thanks WiFive. Does it mean the default firmware on my board is not golden image? what I want to do is evaluating the SoC and do demos with different chips.
Postby rudi ;-) » Mon Feb 20, 2017 9:30 am
Postby Sprite » Tue Feb 21, 2017 1:41 am
Oops, I see I accidentally allowed this topic twice. Closing this one, please proceed in the other topic.
