Error with make monitor
balix53
Postby balix53 » Mon Sep 16, 2019 11:58 am
I followed the getting started for the esp-idf release v3.3.
I can compile and flash via the make command, however monitor does not work. The message I get is:
$ make monitor
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
Python requirements from C:/Users/balix/esp-idf/requirements.txt are satisfied.
MONITOR
winpty: error: cannot start 'python': Not found in PATH
I tried the following as listed in known issues (https://docs.espressif.com/projects/esp ... on-windows):
- reinstalling winpty
- using simple_monitor
These two solutions do not work either. I still have the same issue.
I can call python from the shell and which python returns /mingw32/bin/python. So I assume that my PATH should be correct ? Otherwise I do not understand how winpty cannot found it.
balix53
Re: Error with make monitor
Postby balix53 » Mon Sep 23, 2019 8:38 am
I managed to work around this issue by reinstalling my toolchain.
Users browsing this forum: MSN [Bot], tharunjoy and 23 guests
