Eclipse indexer issue (Symbol ... could not be resolved) + parallel build on windows
newsettler_AI
Postby newsettler_AI » Tue Sep 17, 2019 3:18 pm
I'm facing issue with Eclipse indexer. I have migrated to IDF v3.3 LTS not so long ago and not sure what is going wrong.
My setup:
  • Windows 10 Home
  • Eclipse 2018-09 (4.9.0)
  • IDF v.3.3 LTS
  • Toolchain (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 5.2.0
As testing project I'm using spiffs
https://github.com/espressif/esp-idf/tr ... age/spiffs
I'm doing everything as described here:
https://docs.espressif.com/projects/esp ... up-eclipse
Project compiles in both Eclipse and toolchain console. But after compilation is done, Eclipse have many (depends on project) errors
"Symbol XXX could not be resolved"
Main error
My pathes:
Toolchain location:
C:\Projects\ESP32\TOOLS\msys32
IDF location:
C:\Projects\ESP32\TOOLS\esp-idf
Project location:
C:\Projects\ESP32\Projects\base2\spiffs
Detailed Eclipse configuration:
C/C++ Build
C/C++ Build
C/C++ Build - Enviroment
[continued in next post]
Last edited by newsettler_AI on Wed Sep 18, 2019 12:12 pm, edited 3 times in total.
newsettler_AI
Re: Eclipse indexer issue with default examples (Symbol ... could not be resolved)
Postby newsettler_AI » Tue Sep 17, 2019 3:24 pm
[continued]
Preprocessor Include Path - Compiler settings
Preprocessor Include Path - Parcer
And here is how looks my Preprocessor Include Path - Settings Entries:
newsettler_AI
Postby newsettler_AI » Tue Sep 17, 2019 3:25 pm
And Indexer settings:
Indexer
Also attaching eclipse settings ( .cproject, .project files and folder .settings)
eclipse_settings.zip
(3.16 KiB) Downloaded 120 times
Please advice what is wrong...
I have tried to make whole Clean-Build path with different Indexer settings:
Diffrerent attempts with Indexer settings
and making in each settings Project -> C/C++ Index -> Rebuild , but still no affect in any configuration.
newsettler_AI
Postby newsettler_AI » Tue Sep 17, 2019 6:53 pm
Interesting thing I noticed...
When I have disabled parallel build everything get as it should! All elements was found and resolved...
So it comes that on Windows(maybe on other systems aswell?) indexer cant properly resolve all if build runs on multiple threads.
So, here is solution that helped me to resolve issue :!:
My Indexer settings:
Now clean project (can be done with enabled parallel build).
Disable parallel build.
Build project againg.
Open some files with "unresolved" issue and it should update on the fly, maybe take 1-3 seconds.
Now all "unresolved" issues should gone.
And then can build project with enabled parallel build.
Users browsing this forum: Baidu [Spider], philipp and 28 guests
