Incorrect EMAC Clock Validation for PSRAM
Posted: Tue Sep 24, 2019 7:00 am
A) I am working on one project where I need to keep both WIFI and Ethernet initialized and altered in run time. Meaning, ESP32 should be working with WIFI but whenever Ethernet adaptor plugged, it should switch to the Ethernet interface and vica-versa.
Here, I am getting "Link Up" & "Link Down" event from emac though there is no ethernet adopter connected.
can you let us know what would be causing this? because of this issue, Internet connectivity over WIFI is not pertained.
B) One another issue I found in emac clock validation.
We are using ESP32 module with PSRAM. Because of this, GPIO16 & GPIO17 occupied by PSRAM and could not be used by EMAC clock configuration. To deal with this, we configured GPIO0_OUT to provide 50MHz clock to emac.
But when we initialize ethernet, it throws below error message and ethernet could not initialized properly.
"GPIO16 and GPIO17 has been occupied by PSRAM, Only ETH_CLOCK_GPIO_IN is supported!"
I believe that there is an issue in emac clock validation where psram availability verified. esp-idf does not have check for GPIO0_out emac clock mode which can be allowable in case of psram presence. But according to below code, this condition not verified and ethernet initialization failed.
Please let us know if you have resolutions of both (A) and (B) issues.
Thanks,
Nirav Agrawal
Code: Untitled.c Select all
periph_module_enable(PERIPH_EMAC_MODULE);
if (emac_config.clock_mode != ETH_CLOCK_GPIO0_IN) {
#if CONFIG_SPIRAM_SUPPORT
if (esp_spiram_is_initialized()) {
ESP_LOGE(TAG, "GPIO16 and GPIO17 has been occupied by PSRAM, Only ETH_CLOCK_GPIO_IN is supported!");
ret = ESP_FAIL;
goto _verify_err;
} else {
ESP_LOGW(TAG, "GPIO16/17 is used for clock of EMAC, Please Make Sure you're not using PSRAM.");
#endif
// 50 MHz = 40MHz * (6 + 4) / (2 * (2 + 2) = 400MHz / 8
rtc_clk_apll_enable(1, 0, 0, 6, 2);
REG_SET_FIELD(EMAC_EX_CLKOUT_CONF_REG, EMAC_EX_CLK_OUT_H_DIV_NUM, 0);
REG_SET_FIELD(EMAC_EX_CLKOUT_CONF_REG, EMAC_EX_CLK_OUT_DIV_NUM, 0);
if (emac_config.clock_mode == ETH_CLOCK_GPIO0_OUT) {
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
REG_WRITE(PIN_CTRL, 6);
ESP_LOGD(TAG, "EMAC 50MHz clock output on GPIO0");
} else if (emac_config.clock_mode == ETH_CLOCK_GPIO16_OUT) {
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO16_U, FUNC_GPIO16_EMAC_CLK_OUT);
ESP_LOGD(TAG, "EMAC 50MHz clock output on GPIO16");
} else if (emac_config.clock_mode == ETH_CLOCK_GPIO17_OUT) {
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO17_U, FUNC_GPIO17_EMAC_CLK_OUT_180);
ESP_LOGD(TAG, "EMAC 50MHz inverted clock output on GPIO17");
}Please let us know if you have resolutions of both (A) and (B) issues.
Thanks,
Nirav Agrawal
