ESP32 PICO RFM69 (SPI) - communication problems
DavidL
Postby DavidL » Tue Oct 01, 2019 12:11 pm
Hello friends,
I use a esp32 pico with an RFM69.
Everything works fine except with the use of energy saving mode.
Solution 1:
Deel Sleep
The frames are sent but not processed by ESP32.
I restart esp32 server to receive a correct frame. Then the others are not processed.
Solution 2:
Light Sleep
Same code except that I use Light Sleep for energy saving.
And it works.
obligation to reduce energy consumption. So Deep Sleep.
SERVER
#include <RHReliableDatagram.h>
#include <RH_RF69.h>
#include <SPI.h>
#define CLIENT_ADDRESS 2
#define SERVER_ADDRESS 1
RH_RF69 driver(5, 26);
RHReliableDatagram manager(driver, SERVER_ADDRESS);
void setup()
  Serial.begin(9600);
  while (!Serial)
    delay(10);
    if (!manager.init())
    Serial.println("init failed");
    delay(10);
uint8_t data[] = "And hello back to you";
uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
void loop()
  manager.temperatureRead();
  if (manager.available())
    uint8_t len = sizeof(buf);
    uint8_t from;
    if (manager.recvfromAck(buf, &len, &from))
      Serial.print("got request from : 0x");
      Serial.print(from, HEX);
      Serial.print(": ");
      Serial.println((char*)buf);
      if (!manager.sendtoWait(data, sizeof(data), from)){
        Serial.println("sendtoWait failed");
    }else{
CLIENT DEEP SLEEP After reboot SERVER, first trame is good (receive and ack) and next KO
#include <SPI.h>
RTC_DATA_ATTR  uint8_t data[] = "Hello World!";
RTC_DATA_ATTR  uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
RTC_DATA_ATTR  uint8_t len = sizeof(buf);
RTC_DATA_ATTR  uint8_t from;
void setup()
RH_RF69 driver(5, 13);
RHReliableDatagram manager(driver, 2);
Serial.begin(9600);
    Serial.println("Sending to rf69_reliable_datagram_server");
  if (manager.sendtoWait(data, sizeof(data), 1))
    if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
      Serial.print("got reply from : 0x");
      Serial.print(": ");
    else
      Serial.println("No reply, is rf69_reliable_datagram_server running?");
  else
    Serial.println("sendtoWait test");
    delay(500);
    esp_sleep_enable_timer_wakeup(5 * 100000);
    esp_deep_sleep_start();
void loop()
CLIENT LIGHT SLEEP Good for all trame (receive and ACK) but consumption
#include <SPI.h>
void setup()
Serial.begin(9600);
void loop()
      Serial.print(": ");
    else
  else
    esp_sleep_enable_timer_wakeup(5000000);
    esp_light_sleep_start();
Users browsing this forum: Bytespider and 2 guests
