Hello all,
I've been working on designing my own custom PCB design using ESP32 PICO MCU. While I'm referring through the reference design files of the ESP32 PICO as shown in the image(in the URL). https://photos.app.goo.gl/u2VXrMAGuHcoyRa2A I am trying to understand why there are many connections with capacitors and other resistors and all. Are these all necessary for minimum config, if yes what pins are precisely needed for programming? Because I'm just trying to interface an MPU6050 6 axis gyro and accelerometer sensor. I want this data to be pushed out using BLE. So, what components do I have to exactly populate on the PCB and what can be left off. Please let me know..!! Thanks in advance
ESP32 PICO Custom PCB design
Re: ESP32 PICO Custom PCB design
C15,c16 may be required for stable voltage
c19,r22 are necessary
C17,c18,L1 may be required for good rf performance
@Wifive, Thank you very much. I would like you whether I can programme ESP32 PICO without using USB connector. Which means apparently I am trying to cut out the CP2102 IC along with the USB connector. Are there any ways where I can programme the chip using Flash pins(I meant Flash_SD0, Flash_SD1, ...pins)?
You can flash it with this.
https://www.gridconnect.com/products/es ... gging-tool
You just need 4 pins. +3.3v, GND, EN & GPIO0.
Thanks for sharing the programmer board. I want to know what connections do I have to make changes in my schematics in order to program my MCU. https://photos.app.goo.gl/NV5BbWwbGKn7n6GSA Is it enough that I can just attach some header pins and program my MCU or do I have to do any additional connections to my board??
And TX0, RX0You can flash it with this.
And make sure gpio2 is not pulled up
Holy cow! how could I have forgotten them. Thanks WiFive for pointing that out.And TX0, RX0You can flash it with this.
Thanks for the replies. I would like to know whether we can program it using an Arduino UNO or something? Do I have to buy a programmer separately just for this?
Users browsing this forum: Applebot, YisouSpider and 5 guests
