Linking BSEC library to ESP-IDF for BME680
Posted: Tue Oct 08, 2019 2:50 pm
by apurva
I am using the BME680 with the ESP32-PoE and I want to use the BSEC library to get the IAQ. I have been stuck at the last step of linking the pre-built libalgobsec.a library. This is what my CMakeLists file in my BSEC components folder looks like:
set(COMPONENT_SRCS "src/bme680.c"
"src/bsec_integration.c")
set(COMPONENT_ADD_INCLUDEDIRS "include")
register_component()
add_library(algobsec STATIC IMPORTED)
set_property(TARGET algobsec PROPERTY IMPORTED_LOCATION ${PROJECT_SOURCE_DIR}/components/BSEC/lib/libalgobsec.a)
target_link_libraries(${COMPONENT_TARGET} PUBLIC algobsec)
This gave me an error - FAILED: bme680_test_with_bsec.elf. The CMakeError.log file gives this output:
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: C:/Users/Apurva/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
Build flags: -mlongcalls
Id flags:
The output was:
1
c:/users/apurva/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find crt1-sim.o: No such file or directory
c:/users/apurva/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find _vectors.o: No such file or directory
c:/users/apurva/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -lsim
c:/users/apurva/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -lhandlers-sim
c:/users/apurva/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -lhal
collect2.exe: error: ld returned 1 exit status
Re: Linking BSEC library to ESP-IDF for BME680
Posted: Thu Oct 10, 2019 8:59 am
by ovonphil
I'm having the same problem. Did you manage to solve it? My output is reporting undefined references to bsec functions during the linking process.
Posted: Thu Oct 10, 2019 2:45 pm
by apurva
Hello! I managed to fix the issue. I separated the BME680 files from the BSEC files. My BSEC component structure is as follows:
- include (folder)
  1. bsec_datatypes.h
  2. bsec_integration.h
  3. bsec_interface.h
- lib (folder)
  1. libalgobsec.h (normal)
- bsec_integration.c
- CMakeLists.txt
- component.mk
The CMakeLists.txt contains:
set(COMPONENT_SRCS
"bsec_integration.c")
set(COMPONENT_ADD_INCLUDEDIRS include)
set(COMPONENT_REQUIRES "BME680")
target_link_libraries(${COMPONENT_TARGET} "-L${CMAKE_CURRENT_LIST_DIR}/lib")
target_link_libraries(${COMPONENT_TARGET} algobsec)
The component.mk contains:
COMPONENT_SRCDIRS := .
COMPONENT_ADD_INCLUDEDIRS := include
LIBS := algobsec
COMPONENT_ADD_LDFLAGS     := -lbt -L $(COMPONENT_PATH)/lib \
                           $(addprefix -l,$(LIBS))
ALL_LIB_FILES := $(patsubst %,$(COMPONENT_PATH)/lib/lib%.a,$(LIBS))
COMPONENT_ADD_LINKER_DEPS := $(ALL_LIB_FILES)
COMPONENT_SUBMODULES += lib
My BME680 component structure is as follows:
- include (folder)
  1. bme680.h
  2. bme680_defs.h
  3. bme680_platforms.h
  4. bme680_types.h
- bme680.c
- bme680_platform.c
- CMakeLists.txt
- component.mk
set(COMPONENT_SRCS "bme680_platform.c"
                   "bme680.c")
Posted: Fri Oct 11, 2019 9:52 am
by ovonphil
Thank you for taking the time to post these details apurva. I've tried to copy your method, file structure and file contents, but Im still not getting anywhere. Could you tell me what you have in the CMakeLists.txt file in the top level directory of the project? And what is bme680_platform.c? Is that your own layer?
Posted: Fri Oct 11, 2019 10:39 am
by ovonphil
It's all building but doesn't appear to be linking. The errors are undefined references to the functions in the binary file, e.g. undefined reference to "bsec_set_configuration"...
Posted: Fri Oct 11, 2019 12:24 pm
by ovonphil
Got it buildng at last. The problem was that I was using the lite version of the library rather than the normal one, so now it builds, but I'm receving all zeroes in the output, so it looks like there is another hurdle to resolve. I know the sensor and my I2C driver are working, because I was previously reading raw values from it in forced mode, without the BSEC layer.
Thanks again for your post apurva - that has helped me to structure the project better, and no doubt get it building!
Posted: Mon Jan 06, 2025 1:32 pm
by Y.Sühan
I also have a similar integration problem. The IDF version I am using is 5.0, and the module I am working with is ESP32-S3. The BME680 module is the one I want to use with BSEC. I am very new to this topic, and I was wondering if it would be possible for you to provide me with an example of BSEC already integrated into ESP-IDF for reference. Thank you in advance!
