ESP32 with ESP-IDF Classic Bluetooth - Mobile Phone - Serial Communication
Edgar1
Postby Edgar1 » Fri Oct 11, 2019 8:20 am
I was looking for sample code to create a simple application for serial communication between the ESP32 and a mobile phone.
It took a long time before I figured out how things work.
Here is some information - for a start without code.
I looked at the
ESP-IDF BT-SPP-ACCEPTOR demo
https://github.com/espressif/esp-idf/tr ... p_acceptor
ESP-IDF BT-SPP-INITATOR demo
https://github.com/espressif/esp-idf/tr ... _initiator
and first I could not figure out which I should use to connect my mobile phone (Android) to an ESP32
After some time I figured out that I can connect from my phone to the Acceptor demo.
I have to pair my phone with the ESP_SPP_ACCEPTOR
After that is done I can open a terminal application on the mobile phone (i.e. Serial Bluetooth) and I can send data from my phone to the ESP32.
If the Acceptor is opened with a monitor program I can see that what I send on the phone is received by the ESP32. It is shown in HEX format.
That works with the Acceptor demo without any changes. It's only necessary to set the following to see the received data.
#define SPP_SHOW_MODE SPP_SHOW_DATA
With that the communication from the phone to the ESP32 worked. But I also want that data is send from the ESP to the mobile phone.
To be able to do that I analyzed how the communication is established and the code for sending and receiving data in the Acceptor and Initiator.
Then I copied the sending code from the Initiator to the Acceptor and the receiving code from the Acceptor to the Initiator.
Now finally that works. I can send and receive data in the Initiator and the Acceptor.
Currently the code which I worked on has lots of additional comment - which I added for my own understanding.
If anybody is interested I can publish that code here.
But maybe it would be better if I do that at GitHub. I have to admit I don't have much experience with them.
Now that this works in principle with the modified Initiator and Acceptor code my next step will be that I will work on the communication between my mobile phone and a modified version of the Acceptor.
Please let me know if you are interested in further info and which info.
entropio
Re: ESP32 with ESP-IDF Classic Bluetooth - Mobile Phone - Serial Communication
Postby entropio » Thu Nov 07, 2019 8:43 pm
You could put the code here in the forum to get out of my doubts I am trying the same as you but apart I must send the data by the uart :D
Ing. Damian Lugo Electronic Design
Edgar1
Postby Edgar1 » Fri Nov 08, 2019 1:48 am
Ok, I will do that. But currently I am a little sick so maybe next week.
emanuel36
Postby emanuel36 » Tue Dec 24, 2019 12:47 pm
Hi, currently I'm trying to do exactly this, could you share your code?
Edgar1
Postby Edgar1 » Wed Dec 25, 2019 2:55 am
Sorry for the long delay.
Below is "my" code. I used initially the ESP-IDF sample code example_spp_acceptor_demo.c and modified it.
This is not clean code, I didn't have time to clean it up yet. But it works.
I pair my phone with the ESP_SPP_ACCEPTOR (ESP32 running with this code).
And then I use on the phone one of the free apps Serial Bluetooth or Bluetooth Terminal.
Code: Untitled.c Select all
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
//#include "nvs.h"
#include "nvs_flash.h"
//#include "freertos/FreeRTOS.h"
//#include "freertos/task.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_bt_main.h"
#include "esp_gap_bt_api.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#define SPP_TAG "SPP_ACCEPTOR_DEMO"
#define SPP_SERVER_NAME "SPP_SERVER"
#define EXAMPLE_DEVICE_NAME "ESP_SPP_ACCEPTOR"
static bool bWriteAfterOpenEvt = true;
static bool bWriteAfterWriteEvt = false;
static bool bWriteAfterSvrOpenEvt = true;
static bool bWriteAfterDataReceived = true;
static const esp_spp_mode_t esp_spp_mode = ESP_SPP_MODE_CB;
//static long data_num = 0;
static const esp_spp_sec_t sec_mask = ESP_SPP_SEC_AUTHENTICATE;
static const esp_spp_role_t role_slave = ESP_SPP_ROLE_SLAVE;
#define SPP_DATA_LEN 20
static uint8_t spp_data[SPP_DATA_LEN];
//Testing
//https://stackoverflow.com/questions/23597259/returning-a-pointer-to-an-array-of-uint8-t-from-a-c-function-get-compiler-erro
uint8_t *createTestBuffer(void){
static const uint8_t buffer[] = { 5, 7, 3, 4, 9, 1, 3 };
uint8_t *rv = malloc(sizeof(buffer));
if (rv != 0)
memmove(rv, buffer, sizeof(buffer));
return rv;
static char charArrayLastReceivedData[18];
static void saveReceivedData(int len, uint8_t *p_data){
char array1[18] = "abcdefg";
char array2[18];
strncpy(array2, array1, 18);
//Better: strncpy_s();
strncpy(charArrayLastReceivedData, array1, 18);
static int getDataToSend(int *len, uint8_t *p_data){
return 0; //ok
static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param){
//Used in app_main() to setup the BT configuration in the ESP32 and used for communication with device
ESP_LOGI(SPP_TAG, "Start of: static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)");
switch (event) {
case ESP_SPP_INIT_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
ESP_LOGI(SPP_TAG, "Call esp_bt_dev_set_device_name(EXAMPLE_DEVICE_NAME)");
esp_bt_dev_set_device_name(EXAMPLE_DEVICE_NAME);
ESP_LOGI(SPP_TAG, "Call esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE)");
esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
ESP_LOGI(SPP_TAG, "Call esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME)");
esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME);
case ESP_SPP_DISCOVERY_COMP_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT");
case ESP_SPP_OPEN_EVT:
//When SPP Client connection open, the event comes
//In use in Initiator
ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT");
ESP_LOGI(SPP_TAG, "bWriteAfterOpenEvt: %d: ", bWriteAfterOpenEvt);
//Added code from Initiator - Start
if (bWriteAfterOpenEvt){
ESP_LOGI(SPP_TAG, "bWriteAfterOpenEvt = true");
ESP_LOGI(SPP_TAG, "Call esp_spp_write(param->srv_open.handle, SPP_DATA_LEN, spp_data)");
//esp_err_tesp_spp_write(uint32_t handle, int len, uint8_t *p_data)
esp_spp_write(param->srv_open.handle, SPP_DATA_LEN, spp_data);
//Test 1
//uint8_t myData[10];
//Test 2
char * c = "Hello";
// "Hello" is in fact just { 'H', 'e', 'l', 'l', 'o', '\0' }
uint8_t * u = (uint8_t *)c;
//uint8_t x = u[1];
// x is 101, which is the ASCII char code of 'e'
esp_spp_write(param->srv_open.handle, 6, u);
//Test, compiles ok
int intTest = 6;
intTest = 2 + 4;
esp_spp_write(param->srv_open.handle, intTest, u);
else{
ESP_LOGI(SPP_TAG, "bWriteAfterOpenEvt = false");
//Added code from Initiator - End
case ESP_SPP_CLOSE_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_CLOSE_EVT");
case ESP_SPP_START_EVT: //Short before connection is established
ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT");
case ESP_SPP_CL_INIT_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT");
case ESP_SPP_DATA_IND_EVT: //When SPP connection received data, the event comes, only for ESP_SPP_MODE_CB
ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len=%d handle=%d", param->data_ind.len, param->data_ind.handle);
ESP_LOGI(SPP_TAG, "Call esp_log_buffer_hex("",param->data_ind.data,param->data_ind.len)");
//ESP_LOG_BUFFER_HEX(tag, buffer, buff_len)
//tag: description tag
//buffer: Pointer to the buffer array
//buff_len: length of buffer in bytes
esp_log_buffer_hex("Received HEX Data",param->data_ind.data,param->data_ind.len);
esp_log_buffer_char("Received String Data",param->data_ind.data,param->data_ind.len);
saveReceivedData(param->data_ind.len, param->data_ind.data);
//New Test - Start
if (bWriteAfterDataReceived){
ESP_LOGI(SPP_TAG, "bWriteAfterDataReceived = true");
//New data
//abc
for (int i = 0; i < SPP_DATA_LEN; ++i) {
//spp_data[i] = i;
spp_data[i] = i + 97;
//ESP_LOGI(SPP_TAG, "Call esp_spp_write(param->write.handle, SPP_DATA_LEN, spp_data)");
//esp_spp_write(param->write.handle, SPP_DATA_LEN, spp_data);
ESP_LOGI(SPP_TAG, "Call esp_spp_write(param->write.handle, 8, Received)");
char * c = "Received";
//uint8_t x = u[1];
esp_spp_write(param->srv_open.handle, 8, u);
else{
ESP_LOGI(SPP_TAG, "bWriteAfterDataReceived = false");
//New Test - End
case ESP_SPP_CONG_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT");
case ESP_SPP_WRITE_EVT:
//When SPP write operation completes, the event comes, only for ESP_SPP_MODE_CB
//Original Acceptor Code - Start
//ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT");
//Original Acceptor Code - End
//Code copied from Initiator - Start
ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT len=%d cong=%d", param->write.len , param->write.cong);
//ToDo: Now the next line is incorrect, it shows not the data which was sent!
esp_log_buffer_hex("HEX Data was sent",spp_data,SPP_DATA_LEN);
ESP_LOGI(SPP_TAG, "if param->write.cong ...");
if (param->write.cong == 0) {
ESP_LOGI(SPP_TAG, "param->write.cong == 0");
if (bWriteAfterWriteEvt){
ESP_LOGI(SPP_TAG, "bWriteAfterWriteEvt = true");
else{
ESP_LOGI(SPP_TAG, "bWriteAfterWriteEvt = false");
else {
ESP_LOGI(SPP_TAG, "param->write.cong <> 0");
//Code copied from Initiator - End
case ESP_SPP_SRV_OPEN_EVT: //After connection is established, short before data is received
//When SPP Server connection open, the event comes
//In use in Acceptor
ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_OPEN_EVT");
ESP_LOGI(SPP_TAG, "bWriteAfterOpenEvt: %d: ", bWriteAfterSvrOpenEvt);
if (bWriteAfterSvrOpenEvt){
ESP_LOGI(SPP_TAG, "bWriteAfterSvrOpenEvt = true");
//ESP_LOGI(SPP_TAG, "Call esp_spp_write(param->srv_open.handle, SPP_DATA_LEN, spp_data)");
//esp_spp_write(param->srv_open.handle, SPP_DATA_LEN, spp_data);
//https://stackoverflow.com/questions/40579902/how-to-turn-a-character-array-into-uint8-t
char * c = "Hello"; // "Hello" is in fact just { 'H', 'e', 'l', 'l', 'o', '\0' }
//uint8_t x = u[1];
ESP_LOGI(SPP_TAG, "Call esp_spp_write(param->srv_open.handle, 5, Hello)");
//esp_spp_write(param->srv_open.handle, 6, u); //Works but shows special character after Hello
esp_spp_write(param->srv_open.handle, 5, u); //Works, but maybe it needs something like CR
else{
ESP_LOGI(SPP_TAG, "bWriteAfterSvrOpenEvt = false");
default:
ESP_LOGI(SPP_TAG, "End of: static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)");
void esp_bt_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param){
ESP_LOGI(SPP_TAG, "Start of: void esp_bt_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)");
switch (event) {
case ESP_BT_GAP_AUTH_CMPL_EVT:{
if (param->auth_cmpl.stat == ESP_BT_STATUS_SUCCESS) {
ESP_LOGI(SPP_TAG, "authentication success: %s", param->auth_cmpl.device_name);
esp_log_buffer_hex(SPP_TAG, param->auth_cmpl.bda, ESP_BD_ADDR_LEN);
ESP_LOGE(SPP_TAG, "authentication failed, status:%d", param->auth_cmpl.stat);
case ESP_BT_GAP_PIN_REQ_EVT:{
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_PIN_REQ_EVT min_16_digit:%d", param->pin_req.min_16_digit);
if (param->pin_req.min_16_digit) {
ESP_LOGI(SPP_TAG, "Input pin code: 0000 0000 0000 0000");
esp_bt_pin_code_t pin_code = {0};
esp_bt_gap_pin_reply(param->pin_req.bda, true, 16, pin_code);
ESP_LOGI(SPP_TAG, "Input pin code: 1234");
esp_bt_pin_code_t pin_code;
pin_code[0] = '1';
pin_code[1] = '2';
pin_code[2] = '3';
pin_code[3] = '4';
esp_bt_gap_pin_reply(param->pin_req.bda, true, 4, pin_code);
//Must be set in sdkconfig.h: CONFIG_BT_SSP_ENABLED == true
//This enables the Secure Simple Pairing.
case ESP_BT_GAP_CFM_REQ_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_CFM_REQ_EVT Please compare the numeric value: %d", param->cfm_req.num_val);
esp_bt_gap_ssp_confirm_reply(param->cfm_req.bda, true);
case ESP_BT_GAP_KEY_NOTIF_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_KEY_NOTIF_EVT passkey:%d", param->key_notif.passkey);
case ESP_BT_GAP_KEY_REQ_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_KEY_REQ_EVT Please enter passkey!");
default: {
ESP_LOGI(SPP_TAG, "event: %d", event);
// 0 ESP_BT_GAP_DISC_RES_EVT
// 1 ESP_BT_GAP_DISC_STATE_CHANGED_EVT
// 2 ESP_BT_GAP_RMT_SRVCS_EVT
// 3 ESP_BT_GAP_RMT_SRVC_REC_EVT
// 4 ESP_BT_GAP_AUTH_CMPL_EVT
// 5 ESP_BT_GAP_PIN_REQ_EVT
// 6 ESP_BT_GAP_CFM_REQ_EVT
// 7 ESP_BT_GAP_KEY_NOTIF_EVT
// 8 ESP_BT_GAP_KEY_REQ_EVT
// 9 ESP_BT_GAP_READ_RSSI_DELTA_EVT
// 10 ESP_BT_GAP_CONFIG_EIR_DATA_EVT
// 11 ESP_BT_GAP_EVT_MAX
return;
ESP_LOGI(SPP_TAG, "End of: void esp_bt_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)");
void startClassicBtSpp(void){
ESP_LOGI(SPP_TAG, "void startClassicBtSpp(void) - Start");
//code
//Dummy data to send
//spp_data[i] = i;
spp_data[i] = i + 65;
//Non-volatile storage (NVS) library is designed to store key-value pairs in flash.
esp_err_t ret = nvs_flash_init(); //Initialize the default NVS partition.
ESP_ERROR_CHECK( ret );
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_BLE)); //release the controller memory as per the mode
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
ESP_LOGI(SPP_TAG, "Call esp_bt_controller_init(&bt_cfg)");
if ((ret = esp_bt_controller_init(&bt_cfg)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "Initialize controller ok");
ESP_LOGI(SPP_TAG, "Call esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT)");
if ((ret = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "Enable controller ok");
ESP_LOGI(SPP_TAG, "Call esp_bluedroid_init()");
if ((ret = esp_bluedroid_init()) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s initialize bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "Initialize bluedroid ok");
ESP_LOGI(SPP_TAG, "Call esp_bluedroid_enable()");
if ((ret = esp_bluedroid_enable()) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s enable bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "Enable bluedroid ok");
ESP_LOGI(SPP_TAG, "Call esp_bt_gap_register_callback(esp_bt_gap_cb)");
if ((ret = esp_bt_gap_register_callback(esp_bt_gap_cb)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s gap register failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "Gap register ok");
ESP_LOGI(SPP_TAG, "Call esp_spp_register_callback(esp_spp_cb)");
if ((ret = esp_spp_register_callback(esp_spp_cb)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s spp register failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "spp register ok");
ESP_LOGI(SPP_TAG, "Call esp_spp_init(esp_spp_mode)");
if ((ret = esp_spp_init(esp_spp_mode)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s spp init failed: %s\n", __func__, esp_err_to_name(ret));
return;
else{
ESP_LOGI(SPP_TAG, "spp init ok");
ESP_LOGI(SPP_TAG, "CONFIG_BT_SSP_ENABLED == true");
/* Set default parameters for Secure Simple Pairing */
ESP_LOGI(SPP_TAG, "Set default parameters for Secure Simple Pairing");
esp_bt_sp_param_t param_type = ESP_BT_SP_IOCAP_MODE;
esp_bt_io_cap_t iocap = ESP_BT_IO_CAP_IO;
esp_bt_gap_set_security_param(param_type, &iocap, sizeof(uint8_t));
* Set default parameters for Legacy Pairing
* Use variable pin, input pin code when pairing
ESP_LOGI(SPP_TAG, "Set default parameters");
esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_VARIABLE;
esp_bt_gap_set_pin(pin_type, 0, pin_code);
ESP_LOGI(SPP_TAG, "void startClassicBtSpp(void) - End");
void app_main(void){
ESP_LOGI(SPP_TAG, "void app_main(void) - Start");
startClassicBtSpp();
ESP_LOGI(SPP_TAG, "void app_main(void) - End\n");
entropio
Postby entropio » Fri Oct 30, 2020 5:55 pm
Hello I have made a program that uses bluetooth classic spp and the uart2, the purpose is to pass data through bluetooth and pass it to uart2 transparently, your code is very similar to mine, the whole trick is in the functions esp_spp_cb () and esp_bt_gap_cb ( ) in the events that they handle, and find the data in the esp_spp_cb_param_t * param structure, where the obtained data is found, I got a bit complicated if you leave the functions and work with the esp_spp_cb_param_t * param structure since it loses the data writing the data from another function was complicated, could you help me.
Edgar1
Postby Edgar1 » Sun Nov 01, 2020 9:58 am
I didn't do anything with this for a long time.
At some stage I changed to BLE. It works differently and in my opinion it's easier to use once you understand it.
I bought two of these for testing.
https://www.nordicsemi.com/Software-and ... 840-Dongle
That was a good, and not expensive, investment.
jmotisariya
Postby jmotisariya » Tue Nov 10, 2020 4:54 pm
Thank you for source code of ESP-IDF @Edgar1.
Can you please help me with the following issue.!
I require to read the string length of 32 characters from android device in my ESP32. I am able to read the string for 32 characters but the string is getting divided into 16 characters. Above that, I am also receiving 5 characters in single callback in my android platform from ESP32. I am required to get the whole string as a single string rather than split into 5 letter per callback in my android platform.
tiger.qi
Postby tiger.qi » Mon Nov 16, 2020 1:34 am
There is an error in running the bt_spp_indiector demo program,anybody know why?
ChrisJ7903
Postby ChrisJ7903 » Sat Oct 05, 2024 11:42 pm
Hi @Edgar1,
It's a very long time since you posted, but I'm hoping you might answer my questions:
Do you remember which ESP32 module you were using? (e.g. was it an ESP32-WROOM-32 ?)
Did you have to re-flash the ESP32 to add Classic Bluetooth functions?
Or did the module come with Classic bluetooth built in?
thank you
