I'm working on a leading edge dimmer, there for i would like to use the MCPWM functionality of the ESP32.
But i'm a bit stuck.
This is what i have so far:
#define GPIO_PWM0A_OUT 0
#define GPIO_PWM0B_OUT 0
#define GPIO_PWM1A_OUT 0
#define GPIO_PWM1B_OUT 0
#define GPIO_PWM2A_OUT 0
#define GPIO_PWM2B_OUT 0
#define GPIO_CAP0_IN 0
#define GPIO_CAP1_IN 0
#define GPIO_CAP2_IN 0
#define GPIO_SYNC1_IN 0
#define GPIO_SYNC2_IN 0
#define GPIO_FAULT0_IN 0
#define GPIO_FAULT1_IN 0
#define GPIO_FAULT2_IN 0
#define GPIO_SYNC0_IN ZCD_Pin
//Setup MCPWM for Dimming
mcpwm_pin_config_t pin_config = {
.mcpwm0a_out_num = GPIO_PWM0A_OUT,
.mcpwm0b_out_num = GPIO_PWM0B_OUT,
.mcpwm1a_out_num = GPIO_PWM1A_OUT,
.mcpwm1b_out_num = GPIO_PWM1B_OUT,
.mcpwm2a_out_num = GPIO_PWM2A_OUT,
.mcpwm2b_out_num = GPIO_PWM2B_OUT,
.mcpwm_sync0_in_num = GPIO_SYNC0_IN,
.mcpwm_sync1_in_num = GPIO_SYNC1_IN,
.mcpwm_sync2_in_num = GPIO_SYNC2_IN,
.mcpwm_fault0_in_num = GPIO_FAULT0_IN,
.mcpwm_fault1_in_num = GPIO_FAULT1_IN,
.mcpwm_fault2_in_num = GPIO_FAULT2_IN,
.mcpwm_cap0_in_num = GPIO_CAP0_IN,
.mcpwm_cap1_in_num = GPIO_CAP1_IN,
.mcpwm_cap2_in_num = GPIO_CAP2_IN};
mcpwm_set_pin(MCPWM_UNIT_0, &pin_config);
// Define PWM_Out in the header file, this is the output pin to the mosfets
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, PWM_Out);
mcpwm_config_t pwm_config;
pwm_config.frequency = 100; //frequency = 100Hz
pwm_config.cmpr_a = 100; //duty cycle of PWMxA = 60.0%
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config); //Configure PWM0A & PWM0B with above settings
mcpwm_set_duty_type(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, MCPWM_DUTY_MODE_0);
mcpwm_start(MCPWM_UNIT_0, MCPWM_TIMER_0);
mcpwm_sync_enable(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_SELECT_SYNC0, 990);I only need to set the mcpwm_sync0_in_num pin.
How can i do that ?
