Digital Input
fabltd
Digital Input
Postby fabltd » Wed Oct 16, 2019 8:11 pm
Hello All
I have a 868Mhz Radio connected to GPIO 14.
The transmitter ( handheld remote) sends a Logic 1 as a 0.88 MS Pulse and logic 0 as 0.44 Pulse.
I have tried every thing I can think of but I cannot seem to read the port quickly enough. I fail to detect the Logic pulses.
The transmitter uses a Sync bit ( Logic 1) of 2.6 MS this can be detected.
I have attached a change Interrupt and with in the ISR I have the following code:
  void IRAM_ATTR ISR(){
  unsigned long timestamp = micros();
  unsigned long pulse_width = timestamp - last_timestamp;
  int pin = digitalRead(14);
  last_timestamp = timestamp;
  last_pulse_width = pulse_width;
  update = true;
  void loop(){
  if (change){
  Serial.println(last_pulse_width);
  change = false;
Is there a better way to read the pin so that I can detect the fast pulses. Help :D
JT
rodmcm
Re: Digital Input
Postby rodmcm » Thu Oct 17, 2019 7:35 am
Have you tried something simple like a print statement in the interrupt routine to see if it's working?
Serial.println(micros());
rodmcm
Re: Digital Input
Postby rodmcm » Thu Oct 17, 2019 7:38 am
I should have read your code better
You have to attach the interrupt to Pin 14 in the setup, not call it in the Interrupt routine
See
attachInterrupt( , ,)
Google
ESP32 with PIR Motion Sensor using Interrupts and Timers
Users browsing this forum: No registered users and 20 guests
