UART baud rate
underwater
UART baud rate
Postby underwater » Sat Feb 25, 2017 6:46 am
I read the AT instruction set and examples and it states the maximum baudrate for the UART is 5000000 baud. Is that a limitation of the hardware or are higher baudrates also possible.
puff
Re: UART baud rate
Postby puff » Mon Feb 27, 2017 5:02 am
Hello underwater,
it is the limitation of AT command firmware. You can get a higher baudrate if you write the code by yourself
Ritu21
Re: UART baud rate
Postby Ritu21 » Tue Dec 04, 2018 7:40 am
Hi ,
What is the maximum limit for baudrate, when configuring through code??
R.
houwenxiang
Re: UART baud rate
Postby houwenxiang » Mon Dec 10, 2018 6:52 am
Hi ,
R.
Hi, 5Mbps is the maximum limit.
wookooho
Ritu21
Re: UART baud rate
Postby Ritu21 » Mon Dec 10, 2018 7:25 am
So, you mean, 655360 bits per second??
loboris
Re: UART baud rate
Postby loboris » Mon Dec 10, 2018 9:30 am
I have tested with 4000000,3500000,3000000,2500000, 2000000 bits/sec on ESP32-WROVER-KIT (with FTDI USBtoSERIAL) and it works.
houwenxiang
Re: UART baud rate
Postby houwenxiang » Wed Dec 12, 2018 3:28 am
I mean 5000000bit/s, in the data format of start+8bit+stop, it can trans 500,000 byte/s.
Do you test with 5000000 bits/sec ?
wookooho
Ritu21
Re: UART baud rate
Postby Ritu21 » Wed Dec 12, 2018 8:24 am
No, I havn't tested it yet.
aakashteggi96
Re: UART baud rate
Postby aakashteggi96 » Mon Apr 26, 2021 7:01 am
you said your own code what does that means ?? im trying to send at-commands using usb-uart to esp32 at 2000000 but unable to communicate..
fabiogrs93
Re: UART baud rate
Postby fabiogrs93 » Fri Oct 29, 2021 4:40 pm
Hello, have you tested using the ESP-IFD Sdk simply set the baud rate to 4000000? Are necessary some special operation to set this value of baud rate? thank you
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User and 1 guest
