[info] lwip demos on Eth Phy ( ESP32 RMII ) runs
Posted: Mon Feb 27, 2017 12:16 am
by rudi ;-)
hi
since we have the RMII on ESP32 working and we drive a Eth Phy Nic,
the pull request is done,
we can now do "same" doings like we do with services on wifi.
we can example run on the Eth Phy a web server, echo server, udp server .. and more
we can play with all lwip examples very easy.
found a repo as example here
there are more lwip examples on internet, try to search for "lwip examples"
i push a picture from my desk , sry for craz output, but we are in work alkoholic now
what you must do that the thing is working:
example http server:
and example TCP echo
copy the c and h file to your LAN8720 / TLK110 main folder
include the header in your main.c file
in the app_main call the init example
#include "tcpecho.h"
#include "httpserver-netconn.h"
void app_main()
    esp_err_t ret = ESP_OK;
    tcpip_adapter_init();
    esp_event_loop_init(NULL, NULL);
#if (CONFIG_PHY_TLK110)
    eth_config_t config;
//    config.phy_addr = PHY31;
    config.phy_addr = PHY1; // tlk eval board
    config.mac_mode = ETH_MODE_RMII;
    config.phy_init = phy_tlk110_init;
    config.gpio_config = eth_gpio_config_rmii;
    config.tcpip_input = tcpip_adapter_eth_input;
    config.phy_check_init = phy_tlk110_check_phy_init;
    config.phy_check_link = phy_tlk110_check_phy_link_status;
    config.phy_get_speed_mode = phy_tlk110_get_speed_mode;
    config.phy_get_duplex_mode = phy_tlk110_get_duplex_mode;
    //Only FULLDUPLEX mode support flow ctrl now!
    config.flow_ctrl_enable = true;
    config.phy_get_partner_pause_enable = phy_tlk110_get_partner_pause_enable;
    config.phy_power_enable = phy_tlk110_power_enable;
#endif
#if (CONFIG_PHY_LAN8720)
    config.phy_addr = PHY0; // mc lan8720 eval board
    config.phy_init = phy_lan8720_init;
    config.phy_check_init = phy_lan8720_check_phy_init;
    config.phy_check_link = phy_lan8720_check_phy_link_status;
    config.phy_get_speed_mode = phy_lan8720_get_speed_mode;
    config.phy_get_duplex_mode = phy_lan8720_get_duplex_mode;
    config.phy_get_partner_pause_enable = phy_lan8720_get_partner_pause_enable;
    config.phy_power_enable = phy_lan8720_power_enable;
#endif
    ret = esp_eth_init(&config);
    if(ret == ESP_OK) {
        nvs_flash_init();
        esp_eth_enable();
        // xTaskCreate(eth_task, "eth_task", 2048, NULL, (tskIDLE_PRIORITY + 2), NULL);
        // initialise_wifi(); // be sure what you do ;-)
	vTaskDelay(3000 / portTICK_PERIOD_MS);
        // init tcp echo server, port will be 7
	tcpecho_init();
	// init http server, port will be 80
	http_server_netconn_init();
	// you can use a http client that do request...
	// xTaskCreate(&http_get_task, "http_get_task", 2048, NULL, 5, NULL);
you have now a http server and a tcp echo server on eth phy rmii from esp32
how cool is that ?
hope the info is welcome and helps
now we go on to build a gateway.. :)
