[Solved] How can I open the same file twice? not the same behaviour as on windows..
gunar.kroeger
Postby gunar.kroeger » Thu Nov 07, 2019 5:39 pm
How can I open the same file once to write a log continuously, and second to read it and upload it through wifi.
I wish to have 2 cursors moving on the file, and not have to fseek back and forth to impelement this feature.
I tested this code with esp-idf-v3.3 and on windows with CodeBlocks
int main(int argc, char *argv[])
    printf("open\n");
    FILE *w = fopen("logtest.txt", "w");
	printf("read open = %x\n", w);
	if(!w)
		return 0;
	fprintf(w, "aaaa");
    fflush(w);
    //fsync(fileno(w));
	FILE *r = fopen("logtest.txt", "r");
	printf("read open = %x\n", r);
	if(!r)
		return 0;
	printf(".%c", fgetc(r));
	printf(".%c\n", fgetc(r));
	fprintf(w, "bbbb");
    fflush(w);
    //fsync(fileno(w));
        return 1;
codeblocks works as expected, but with esp-idf with sdcard using FAT the second fopen call returns NULL.
Is there any flag I have to set or compiler option to make this code work? I've tried with w+ and r+ but got the same result.
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
gunar.kroeger
Re: How can I open the same file twice? not the same behaviour as on windows..
Postby gunar.kroeger » Mon Nov 18, 2019 2:14 pm
should I report this as a bug?
ESP_Angus
Postby ESP_Angus » Tue Nov 19, 2019 11:09 pm
Hi gunar,
This is a limitation of the FatFs library that we use. Set this config option to 2 and you should be able to have the same file open twice:
https://docs.espressif.com/projects/esp ... fs-fs-lock
Note that this comes at a tradeoff of memory usage and efficiency (still relatively low cost compared to ESP32's available resources, though.)
Angus
Users browsing this forum: Google [Bot], Honzik321, MSN [Bot] and 47 guests
