The Ring
idahowalker
The Ring
Postby idahowalker » Fri Nov 08, 2019 4:52 pm
Buffer.
My current thing do is about using a Ring Buffer.
void fSendSerialToBrain( void *pvParameters )
  CAN_frame_t rx_frame;
  xSemaphoreGive ( sema_SendSerialToBrain );
  bool PassTwo = false;
  for (;;)
    xEventGroupWaitBits (eg, evtSendSerialToBrain, pdTRUE, pdTRUE, portMAX_DELAY);
    size_t item_size;
    for (int i = 0; i < RingBufferTriggerSize; i++)
      int *item = (int *)xRingbufferReceive(h_buf_LIDAR_INFO, &item_size, pdMS_TO_TICKS(0)); // reterive item from ring buffer, no wait
      if (item != NULL)
        vRingbufferReturnItem(h_buf_LIDAR_INFO, (void *)item); // remove item from ring buffer
        // prep item for sending over CAN buss
        if (!PassTwo)
          rx_frame.FIR.B.FF = CAN_frame_std;
          rx_frame.MsgID = 1;
          rx_frame.FIR.B.DLC = 8;
          rx_frame.data.u8[0] = *item & 0xFF;
          rx_frame.data.u8[1] = (*item >> 8) & 0xFF;
          rx_frame.data.u8[2] = (*item >> 16) & 0xFF;
          rx_frame.data.u8[3] = (*item >> 24) & 0xFF;
          PassTwo = true;
          rx_frame.data.u8[4] = *item & 0xFF;;
          rx_frame.data.u8[5] = (*item >> 8) & 0xFF;
          rx_frame.data.u8[6] = (*item >> 16) & 0xFF;
          rx_frame.data.u8[7] = (*item >> 24) & 0xFF;
          ESP32Can.CANWriteFrame(&rx_frame); // send items over CAN buss
          PassTwo = false;
  vTaskDelete( NULL );
} // void fSendSerialToBrain( void *pvParameters )
I know how to get the data on the pointer info.
What I'd like to do, if possible, is to read the entire contents of the ring buffer but only remove the first item, instead of removing all the items. I am under the impression that each retrieve requires a vRingbufferReturnItem. It makes sense to me that if I just do a vRingbufferReturnItem on the first item that the first item can be replaced leaving the other items in place but still able to be read?
Users browsing this forum: boarchuz, GeorgeFlorian1 and 9 guests
