return WL_CONNECT from function
azz-zza
Postby azz-zza » Sun Nov 10, 2019 11:16 pm
the question is due to my limited knowledge of C.
What is the function type should i specify if i want to check that the esp is connected after calling the function:
#include <WiFi.h>
<skip>
wl_status_t WIFI_Net_Connect() {
  return WL_CONNECTED;
The complier is upset :
In file included from src/main.cpp:10:0:
include/wireless.h:4:1: error: 'wl_status_t' does not name a type
 wl_status_t WIFI_Net_Connect() ;
Wifitype.h :
typedef enum {
    WL_NO_SHIELD        = 255,   // for compatibility with WiFi Shield library
    WL_IDLE_STATUS      = 0,
    WL_NO_SSID_AVAIL    = 1,
    WL_SCAN_COMPLETED   = 2,
    WL_CONNECTED        = 3,
    WL_CONNECT_FAILED   = 4,
    WL_CONNECTION_LOST  = 5,
    WL_DISCONNECTED     = 6
} wl_status_t;
I understand that switching the return type to "int" will work, but kind of not obviuos for support.
At the same time in WiFiSta.h:
class WiFiSTAClass {
<skip>
    static wl_status_t status();
    static void _setStatus(wl_status_t status);
And stackoverflow seemed to "allow" what im trying to do (https://stackoverflow.com/questions/742 ... ction-in-c):
TLDR:
enum Foo { BAR, BAZ };
enum Foo testFunc(void)
    return BAR;
Or, with a typedef:
typedef enum Foo { BAR, BAZ } Foo;
Foo testFunc(void)
    return BAR;
So what am i missing ?
thank you .
Users browsing this forum: Bing [Bot] and 13 guests
