Exception decode problem
Posted: Mon Nov 11, 2019 3:51 pm
I am struggling to debug an exception. I do not believe that the exception log correctly reports the calling sequence. Often the log reports the execution line as being the functions closing brace. Often the log reports a function name on the left which does not match the line number.
Most importantly, I cannot find the bug!
The exception happens when my higher level logic attempts to open a device which failed its 'probe'. I believe that the following report causes an exception through my use of a UDP logger (see code below).
If I don't register the logger then I don't get the exception.
I added a semaphore to prevent multiple threads logging at the same time (but suspect that the log handler is already protected) but this does not help.
It would help to understand what 'find_value' is doing and why it might go wrong.
Commenting
allows the application to work. I have used my UDP logger for a year or so without issue.
The exception (with Semaphore):
The UDP logger code:
Commenting
sendto(udpSocket, buffer, strlen(buffer), 0, (struct sockaddr *)&s, sizeof(struct sockaddr_in));The exception (with Semaphore):
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4017b208 PS : 0x00060c30 A0 : 0x800e50c0 A1 : 0x3ffefd80
0x4017b208: find_value at C:/msys32/home/Pete/esp/esp-idf/components/pthread/pthread_local_storage.c:192
A2 : 0x10293849 A3 : 0x00000003 A4 : 0x00000000 A5 : 0x00000001
A6 : 0x00060823 A7 : 0x00000005 A8 : 0x800896eb A9 : 0x3ffefd60
A10 : 0x3ffe3a38 A11 : 0x00001800 A12 : 0x3ffae768 A13 : 0x00000001
A14 : 0x00000034 A15 : 0x3ffe3db0 SAR : 0x00000004 EXCCAUSE: 0x0000001c
EXCVADDR: 0x10293849 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0x00000000
ELF file SHA256: a4d49bc51be0af2cb1c901f96b0c2e0e595c9d89dc8ed319e311e0cb589017ea
Backtrace: 0x4017b208:0x3ffefd80 0x400e50bd:0x3ffefda0 0x401806c3:0x3ffefdc0 0x400866c6:0x3ffefde0 0x40086bad:0x3ffefe00 0x40086a3a:0x3ffefe40 0x40086ab6:0x3ffefea0 0x4
011dbb8:0x3ffefed0 0x40082925:0x3ffeff10 0x40174d6e:0x3ffeff60 0x40131f38:0x3ffeffa0 0x401324e0:0x3ffeffc0 0x40131a7e:0x3ffeffe0 0x401067fa:0x3fff0100 0x4008ad59:0x3fff
0130
0x400e50bd: pthread_getspecific at C:/msys32/home/Pete/esp/esp-idf/components/pthread/pthread_local_storage.c:206
0x401806c3: sys_thread_sem_get at C:/msys32/home/Pete/esp/esp-idf/components/lwip/port/esp32/freertos/sys_arch.c:491
0x400866c6: netconn_apimsg at C:/msys32/home/Pete/esp/esp-idf/components/lwip/lwip/src/api/api_lib.c:950 (discriminator 4)
0x40086bad: netconn_send at C:/msys32/home/Pete/esp/esp-idf/components/lwip/lwip/src/api/api_lib.c:950 (discriminator 4)
0x40086a3a: lwip_sendto at C:/msys32/home/Pete/esp/esp-idf/components/lwip/lwip/src/api/sockets.c:3532
0x40086ab6: lwip_sendto_r at C:/msys32/home/Pete/esp/esp-idf/components/lwip/lwip/src/api/sockets.c:3532
0x4011dbb8: sendto at C:/msys32/home/Pete/esp/esp-idf/components/lwip/lwip/src/include/lwip/sockets.h:591
(inlined by) udp_log_vprintf at C:/msys32/home/.../src/udplogger.c:54
0x40082925: esp_log_write at C:/msys32/home/Pete/esp/esp-idf/components/log/log.c:412The UDP logger code:
static int udp_log_vprintf(const char *fmt, va_list arguments)
struct sockaddr_in s;
printf("Taking..\n");
xSemaphoreTake(udpLogSemaphore, portMAX_DELAY);
printf("Taken..\n");
memset(&s, '\0', sizeof(struct sockaddr_in));
s.sin_family = AF_INET;
s.sin_port = (in_port_t)htons(UDP_LOG_PORT);
s.sin_addr.s_addr = htonl(INADDR_BROADCAST);
vsnprintf((char*)buffer, UDP_LOG_BUFFER_SIZE, fmt, arguments);
int size = vprintf(fmt, arguments);
xSemaphoreGive(udpLogSemaphore);
return size;
} /*-- udp_log_vprintf() --*/
