I am trying to run the openssl server exmaple from https://github.com/espressif/esp-idf/bl ... l_server.c
The server works fine with the certificates mentioned in the exmaple.
I am testing using
openssl s_client -connect <Ip address of ssl server>:443
However when i try to create my own certificates using openssl or using the make file mentioned in ESP8266 SSL User Manual
Version 1.4
I get errors as follows
6812:error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01:rsa_pk1.c:103:
6812:error:04067072:rsa routines:RSA_EAY_PUBLIC_DECRYPT:padding check failed:rsa_eay.c:705:
6812:error:1408D07B:SSL routines:ssl3_get_key_exchange:bad signature:s3_clnt.c:2004:
Has anybody faced similar issues.
openssl server : issue with certificates
Re: openssl server : issue with certificates
Just for information the certificate (cacert.pem) in the example is server certificate and not CA certificate.
Is the new certificate definitely in PEM format? Are you able to post it here or PM me a link to it?
Angus
Angus
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, Google [Bot] and 1 guest
