Is there a way to keep DISABLE_DL_ENCRYPT unset while keeping the flash secure?
In ESP-IDF V4.0 we added "development mode" for flash encryption which keeps DISABLE_DL_ENCRYPT unburned and allows writing new encrypted flash contents without needing the flash encryption key. This is not considered secure for production devices, but for the record you can use the same approach on earlier ESP-IDF if you configure it to not burn the DISABLE_DL_ENCRYPT efuse and then use "esptool.py .. write_flash --encrypt ..." to write new encrypted flash.
There are two reasons this setup is not secure:
1) A time-of-check-time-of-use attack as described by WiFive, possibility of substituting different flash contents after verification is done, while the firmware is running.
2) On current ESP32 revisions,
fault injection attacks can be used to bypass secure boot. However this attack is not useful if flash encryption is permanently enabled. Therefore we recommend permanently enabling flash encryption when secure boot is in use. ESP32-D0WD-V3 will patch the fault injection vulnerability, but still advised to keep flash encryption fully enabled due to (1).
Depending on the size of your production deployment, the other option is to pre-generate and burn each device's flash encryption key before first boot, and record these keys somewhere.
