How to migrate from tcpip_adapter_* to esp_netif_`*
Today I updated to the last version of esp-idf and wanted to build my project. There was a message "tcpip_adapter_init () is deprecated please use esp_netif_init ()". Ok, I did it and my project was built, but there was a crash. So I edited around until my project ran again. I would like to share the necessary steps with you:
replace in your sources "tcpip_adapter_init();" with
"esp_netif_init();
sta_netif = esp_netif_create_default_wifi_sta();
assert( sta_netif );
replace "WIFI_IF_STA" with "ESP_IF_WIFI_STA" and "WIFI_IF_AP" with "ESP_IF_WIFI_AP"
replace "TCPIP_ADAPTER_IF_STA" with "sta_netif" and "TCPIP_ADAPTER_IF_AP" with "ap_netif"
replace "tcpip_adapter_" to "esp_netif_"
replace "TCPIP_ADAPTER_" with "ESP_NETIF_"
set in your main wifi source file
/* esp netif object representing the WIFI station */
esp_netif_t *sta_netif = NULL;
esp_netif_t *ap_netif = NULL;
in other files using these variables add
extern esp_netif_t *sta_netif;
extern esp_netif_t *ap_netif;
Maybe it will help you.
Viele Gruesse
Axel
"esp_netif_init();
Viele Gruesse
Axel
Re: How to migrate from tcpip_adapter_* to esp_netif_`*
So looking at using a TCP client socket and following the examples it uses esp_netif.h but the IDE cant find it so esp_netif_init(); also fails
using the version 4 release - so has anyone come across this ?
TIA Danny
TIA Danny
ESP-Marius
- Espressif staff
Which examples are you looking at? If you are using release 4.0 then this doesn't have esp_netif (it will be a part of 4.1), so the examples for this version should still use the tcpip_adapter.So looking at using a TCP client socket and following the examples it uses esp_netif.h but the IDE cant find it so esp_netif_init(); also fails
TIA Danny
I just changed to v4.1 and my project is a complete mess now
I am looking in the compilation errors and replacing 1 by 1 but it's a pain. It's hard to search in the documentation because I don't know what to search for.
It might be good if you write some article about it because this is a big change. Also, the v4 examples are not comprehensive enough. The getting_started one has only two events..
Im stuck for hours on this error:
I declared it as:
then initialized it:
../components/WifiManager/WifiManager.cpp:647:13: error: invalid use of incomplete type 'esp_netif_t' {aka 'struct esp_netif_obj'}
sta_netif->ip_info.ip.addr = new_ip;
In file included from /home/anio/esp/esp-idf/components/esp_netif/include/esp_netif.h:22,
from /home/anio/esp/esp-idf/components/esp_event/include/esp_event_legacy.h:22,
from /home/anio/esp/esp-idf/components/esp_event/include/esp_event.h:26,
from /home/anio/esp/esp-idf/components/esp_wifi/include/esp_wifi.h:64,
from ../components/WifiManager/WifiManager.cpp:22:
/home/anio/esp/esp-idf/components/esp_netif/include/esp_netif_types.h:33:8: note: forward declaration of 'esp_netif_t' {aka 'struct esp_netif_obj'}
struct esp_netif_obj;
static esp_netif_t * sta_netif = NULL;Code: Select all
sta_netif = esp_netif_create_default_wifi_sta();Re: How to migrate from tcpip_adapter_* to esp_netif_`*
Well, i found the problem. I've used the esp_netif_t type in a wrong way. Now i have another problem, i cant link anything from esp_netif. The linker complains against anything netif related: This component is used in my custom component which has CMakeLists.txt file where i tested with PRIV_REQUIRES and REQUIRES:
/home/anio/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/WifiManager/libWifiManager.a(WifiManager.cpp.obj):(.literal._ZN11WifiManagerC2Ev+0x48): undefined reference to `esp_netif_init()'
idf_component_register(SRCS WifiManager.cpp json/json.c
REQUIRES hm_config
PRIV_REQUIRES esp_wifi esp_netif
PRIV_INCLUDE_DIRS ./json
INCLUDE_DIRS . )
Any help please? I am stuck at this all day. The esp_netif component seems to be compiled but can't be linked. I tried all combinations to include headers and REQUIRE components.
Well, i dont know whats been changed in the master in the last sever hours but it fixed it.
Additionally i had to put the include in extern "C":
Please fix it in the repo
extern "C" {
#include "esp_wifi.h"
}Re: How to migrate from tcpip_adapter_* to esp_netif_`*
Just started to look at the espidf framework.
I am on windows VSCode.
Platformio.ini
I was using their example at https://docs.platformio.org/en/latest/t ... lysis.html
I will include my current code, but the bottom line when I used tcpip_adapter_init() it works and if I use esp_netif_init it can not get an IP. The log shows a connect but my device after timeout says it can not obtain IP.
This may not be a bug but my limited understanding of the framework and wifi library.
I saw the depreciation message, so as part of my learning I was going to fix it.
I assumed it was just a matter of switching names for functions. If I understand that these two functions only handle the hardware layer, I would think the upper layers (DHCP) would have been the same, correct?
Here is a log of sucssufull (tcpip_adapter_init()) connect and DHCP assigned IP.
Hre is a log of unsucssufull (esp_netif_init()) connect and DHCP assigned IP.
The only difference is unremarked the tcpip_adaper vs esp_netif
Here is the code:
Platformio.ini
[env:esp32doit-devkit-v1]
platform = espressif32
board = wemosbat
framework = espidf
upload_port = com9
monitor_speed=115200
monitor_port = com9I will include my current code, but the bottom line when I used tcpip_adapter_init() it works and if I use esp_netif_init it can not get an IP. The log shows a connect but my device after timeout says it can not obtain IP.
I (18529) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (18529) wifi:station: a0:cc:2b:1c:4f:8e join, AID=1, bgn, 20
␛[0;32mI (18589) wifi softAP: station a0:cc:2b:1c:4f:8e join, AID=1␛[0m
W (18769) wifi:<ba-add>idx:4 (ifx:1, a0:cc:2b:1c:4f:8e), tid:6, ssn:0, winSize:64
␛[0;32mI (19179) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2␛[0m
I (386639) wifi:station: a0:cc:2b:1c:4f:8e leave, AID = 1, bss_flags is 658547, bss:0x3ffba33c
I (386639) wifi:new:<1,0>, old:<1,0>, ap:<1,1>, sta:<255,255>, prof:1
W (386639) wifi:<ba-del>idx
␛[0;32mI (386639) wifi softAP: station a0:cc:2b:1c:4f:8e leave, AID=1␛[0mCode: Select all
I (19329) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (19339) wifi:station: a0:cc:2b:1c:4f:8e join, AID=1, bgn, 20
␛[0;32mI (19419) wifi softAP: station a0:cc:2b:1c:4f:8e join, AID=1␛[0m
W (19569) wifi:<ba-add>idx:4 (ifx:1, a0:cc:2b:1c:4f:8e), tid:6, ssn:0, winSize:64
I (55739) wifi:station: a0:cc:2b:1c:4f:8e leave, AID = 1, bss_flags is 658547, bss:0x3ffba33c
Here is the code:
/* WiFi softAP Example
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#define EXAMPLE_ESP_WIFI_SSID "PaulTest"
#define EXAMPLE_ESP_WIFI_PASS "abcd1234"
#define EXAMPLE_MAX_STA_CONN (3)
static const char *TAG = "wifi softAP";
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_id == WIFI_EVENT_AP_STACONNECTED) {
wifi_event_ap_staconnected_t* event = (wifi_event_ap_staconnected_t*) event_data;
ESP_LOGI(TAG, "station "MACSTR" join, AID=%d",
MAC2STR(event->mac), event->aid);
} else if (event_id == WIFI_EVENT_AP_STADISCONNECTED) {
wifi_event_ap_stadisconnected_t* event = (wifi_event_ap_stadisconnected_t*) event_data;
ESP_LOGI(TAG, "station "MACSTR" leave, AID=%d",
void wifi_init_softap()
//tcpip_adapter_init();
esp_netif_init();
ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
wifi_config_t wifi_config = {
.ap = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
.password = EXAMPLE_ESP_WIFI_PASS,
.max_connection = EXAMPLE_MAX_STA_CONN,
.authmode = WIFI_AUTH_WPA_WPA2_PSK
if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
void app_main()
//Initialize NVS
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_AP");
wifi_init_softap();
}Who is online
Users browsing this forum: PerplexityBot and 8 guests
