actually I've some problems to run several commands (flash, flash_erase). The ESP32-WROOM is soldered on a breakoutboard. If I
run flash, program is terminating with Invalid head of packet after some writing on the Chip (baudrate 115200). The output is:
There is more appaering a liittle strange. The output of esptool chip_id is:Serial port COM10
Connecting........_
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Crystal is 40MHz
MAC: 24:6f:28:21:e7:54
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Compressed 24752 bytes to 14767...
Wrote 24752 bytes (14767 compressed) at 0x00001000 in 1.3 seconds (effective 149.2 kbit/s)...
A fatal error occurred: Timed out waiting for packet header
esptool.py failed with exit code 2
But why is here no chip-ID ?Serial port COM10
Connecting........
Uploading stub...
Running stub...
Stub running...
Warning: ESP32 has no Chip ID. Reading MAC instead.
Hard resetting via RTS pin...
And the output of esptool flash_id is:
But why is Detected flash size: Unknown? Doesn't the modul have flash or is it corrupted? Is that the reason for "Invalid head of packet "?Serial port COM10
Connecting....
Uploading stub...
Running stub...
Stub running...
Manufacturer: 00
Device: 0000
Need help.
Kind regards
