ESP32 tcp server-client problem
Schouilette
Postby Schouilette » Sun Nov 24, 2019 8:32 pm
Hello, I try to build a remote sensor with esp32. I have two tasks, first with sensor management and second with TCP server, and with this server I have some troubles. It runs like a server
wifiServer.begin()
, waits for data from my PC
WiFiClient client=wifiServer.avilable()
, and I can even read message from PC via
client.available()
but when I read data from the first task and then tried to send it by WiFi, I can't.
MY code
const char* ssid = "sensor";
const char* password =  "sensor1";
const int tcpPort = 56606;
const char* host = "192.168.137.1";
WiFiServer wifiServer(tcpPort);
 //Connect to the WiFi network
    WiFi.begin(ssid, password);
    Serial.println("");
    // Wait for connection
    while (WiFi.status() != WL_CONNECTED)
        delay(500);
        Serial.print(".");
    Serial.println("");
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
    /*This initializes wifi server*/
   wifiServer.begin();
    /* create the queue which size can contains 5 elements of Data */
    xQueue1 = xQueueCreate(1000, sizeof(Data));
    xQueue2 = xQueueCreate(5, sizeof(Commands));
    void loop()
      vTaskDelay(20);
<here should be the first task but it works fine and it not related with wifi>
void sendTask( void * parameter )
      /*basic variables of freertos to keep data transfer status +create a struct dane*/
      BaseType_t xStatus;
      const TickType_t xTicksToWait = pdMS_TO_TICKS(5);
      Data dane;
      Commands message;
int j=1;
      int allSamples=0;
      bool Read_flag=false;
      int sampleNumber=0;
      /* JSON parser initialization*/
   StaticJsonDocument<1900> doc;
   for(;;){
          WiFiClient client = wifiServer.available();
          if(!Read_flag)
           uint8_t data[100];
           if (client)
            { Serial.println(client);
             TIMERG0.wdt_wprotect=TIMG_WDT_WKEY_VALUE;
             TIMERG0.wdt_feed=1;
             TIMERG0.wdt_wprotect=0;
             Serial.println("new client");
             /*check client is connected   */
             if (client.connected())
                if (client.available()) {
                    int len = client.read(data, 100);
                    if(len < 100)
                       data[len] = '\0';
                    else
                       data[100] = '\0';
                    Serial.print("client sent: ");
                    Serial.println((char *)data);
                    delay(20);
                    const int capacity = 200;
                    StaticJsonDocument<capacity> command;
                    DeserializationError err = deserializeJson(command,data);
                    if(err)
                        Serial.print(F("deserializeJson() failed with code "));
                        Serial.println(err.c_str());
                     else
                        serializeJson(command,Serial);
                        Serial.println();
                        Read_flag=true;
                        delay(10);
                        int accel= command["accel"];
                        int gyro = command["gyro"];
                        int magnet = command["magnet"];
                        int time = command["time"];
                        Serial.println(accel);
                        Serial.println(gyro);
                        Serial.println(time);
                        setupSensor(accel,gyro,magnet);
                        delay(100);
                        Serial.println("sensor range set");
                        message.measureTime=time;
                        message.flag=true;
                        allSamples=time*50;
                        xStatus =xQueueSendToFront(xQueue2, &message, xTicksToWait);
                        Serial.println("command sent");
                        delay(100);
                    client.println("I got message");
                    client.stop();
        if(Read_flag)
         <some boring stuff with Json parser>
          xStatus = xQueueReceive( xQueue1, &dane, xTicksToWait );
          if(xStatus==pdPASS)
                   serializeJson(doc,Serial);
                   doc.clear();
                   sampleNumber=sampleNumber+5;
                   if(client)
                    {Serial.println("we have clinet");
                      {client.println("my JSON Stuff");
I also tried to use client.connect(IP,port) method to establish a connection with PC but then I get "Software caused connection abort"- error. And then I still dont know how to handle with it. Any hints?
Users browsing this forum: No registered users and 132 guests
