I had some problems with the play_mp3 instance:
The coder init failed displays when I use the make flash monitor command.
The connection serial port failed when I burned it using flash_download_tools
play_mp3:error coder init failed
- c87164bdbf0900dc4ae8ffce225c9a35.jpg (285.44 KiB) Viewed 5057 times
- 360截图20191127103407459.jpg (73.93 KiB) Viewed 5057 times
- 企业微信截图_15746764198763.png (45.88 KiB) Viewed 5057 times
- shabtronic
Re: play_mp3:error coder init failed
looks like the HAL didn't init or the wrong board is selected.
Have you tried idf.py menuconfig to select the right board?
- shabtronic
That looks like the LyratD-MSC board, but your logs are showing HAL for Lyrat-V4.3 board.
Users browsing this forum: trendictionbot and 1 guest
