IO Extension Board Recommendation for DevKitC
tugrulguclu
Postby tugrulguclu » Mon Dec 02, 2019 3:40 pm
Hi
I recently started to use ESP32 DEVKit-C (https://www.ebay.co.uk/itm/282413957033)
I was wondering if there are any ready to use boards so I can connect to DEVKit-C and R/W to some I/O points using some LEDs and buttons.
Also Could you let me know if it is possible to use Ecipse and gdb to debug my programs running on the DevKit-C. As far as I understand
DevKit-C does not have Jtag support which makes debugging impossible
BR
ESP_Sprite
Re: IO Extension Board Recommendation for DevKitC
Postby ESP_Sprite » Tue Dec 03, 2019 2:13 am
It doesn't have a dedicated JTAG port, but the JTAG signals are still available on GPIOs. As long as your program doesn't reconfigure those GPIOs, you can hook up your J-link to that.
ID89679475
Postby ID89679475 » Tue Dec 03, 2019 11:52 am
I have the same or very similar 38 pin board and I use the Olimax Tiny-H JTAG debugger on it.
There is a pin out here
https://components101.com/microcontroll ... 32-devkitc
Then a video on setting up debugging with Eclipse CDT here, skip to half way
https://www.youtube.com/watch?v=DqnZy4d03_s
You need TMS, TDI, TCK, TDO and GND so you will need to find those on your JTAG debugger pin out and connect them to the ESP32 board pins as shown on the pin out above.
Users browsing this forum: No registered users and 47 guests
