ESP-IDF and FreeRTOS
drmacro
Postby drmacro » Tue Dec 17, 2019 8:19 pm
I've been reading up in the FreeRTOS documentation about how to use things like, for example, the startup hook daemon.
It says to set configUSE_DAEMON_TASK_STARTUP_HOOK = 1 in the FreeRTOSConfig.h file.
This value does not appear in ./framework-espidf/components/freertos/include/freertos/FreeRTOS.h or FreeRTOSConfig.h.
Does the ESP-IDF not include these features?
Dazza0
Re: ESP-IDF and FreeRTOS
Postby Dazza0 » Wed Dec 18, 2019 7:18 am
ESP-IDF does not include this feature because this feature was added in FreeRTOS V9.0.0rc1. ESP-IDF FreeRTOS is based on FreeRTOS v8.2
drmacro
Postby drmacro » Wed Dec 18, 2019 1:52 pm
So, ESP-IDF is 2 versions behind freertos.
I searched this forum and couldn't find any discussion of freertos referring to plans for updating freertos.
Makes learning freertos a bit more challenging trying to translate tutorials and examples backward to version 8. :(
I started looking at this because I wanted to use the daemon hook to ensure startup sequences get executed before task start to run... :?
Oh well...
Postby Sprite » Thu Dec 19, 2019 2:44 am
Note that you may get the same effect (code run before FreeRTOS starts) by defining your function as a constructor:
void __attribute__((constructor)) my_function(void) {
Make sure that the C file where you put this function in has something (another function or a variable or symbol) that gets referenced by the rest of the code, though, otherwise the linker will ignore your file thinking it's never used.
drmacro
Postby drmacro » Thu Dec 19, 2019 3:17 pm
I'll have to google that...I'm not familiar with the use of constructors in non-object oriented languages...
Postby Sprite » Fri Dec 20, 2019 5:56 am
It may be a gcc extension to C, I don't know, but it works the same as static c++ constructors. The net effect is that functions marked like this are collected by the linker and their addresses are put in a list (__init_array_start to _end) in the final binary. In the startup code in esp-idf/components/esp32/cpu_start.c, we then execute all of them (in do_global_ctors()).
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bing [Bot] and 4 guests
