Migrating from legacy to CMake build
PeterR
Postby PeterR » Wed Dec 18, 2019 6:34 pm
Have ended up playing 'toolchain' pinball; you know you want to add a feature but your toolchain has an issue & so you have to switch to another toolchain (all I have to do is...) and then you find a whole new world of pain :)
I have a legacy GNU makefile build and now need to migrate to CMake (ESP-IDF 4.1 legacy build seems C++11 broken).
I have not found a simple legacy GNU to CMake 'translation' tutorial.
The problem is that the examples are single instance e.g. examples show single extra directory:
set(EXTRA_COMPONENT_DIRS $ENV{IDF_PATH}/examples/common_components/protocol_examples_common)
but I need to convert:
EXTRA_COMPONENT_DIRS += $(PROJECT_PATH)/components/WebApp/image
EXTRA_COMPONENT_DIRS += $(PROJECT_PATH)/components/NMEA/Application
In other words I need to understand how to list directories or add to the appropriate variable.
The makefile commands I need to translate are (above)+:
Add a pre-built library:
# The following three lines link in the pre-built NMEA library.
LIBS := nmea
COMPONENT_ADD_LDFLAGS += -L$(COMPONENT_PATH)/lib \
                          $(addprefix -l,$(LIBS))
Add multiple include paths
COMPONENT_PRIV_INCLUDEDIRS := include  ../../../database/include ../../../third-party/include
PeterR
Re: Migrating from legacy to CMake build
Postby PeterR » Wed Dec 18, 2019 8:37 pm
Awesume! Will try tommorow. Was not looking forwards to that hastle.
Santa will visit you this year ;)
Angus
Postby Angus » Thu Dec 19, 2019 4:12 am
Hi Peter,
The automatic conversion script and the docs page chegewara linked are good places to start.
But also:
We still support the legacy build system. If you open a github issue or something to report exactly what's broken then we will fix it.
EDIT: Just scrolled a bit further and saw this, guess the same thing. Will get someone to look into it.
PeterR
Postby PeterR » Thu Dec 19, 2019 11:33 am
Cool, I could do with some help!
Needless to say the conversion tool just sulks for a while before crashing!
$ ./esp-idf/tools/cmake/convert_to_cmake.py ./Application
cygpath: can't convert empty path
Converting ./Application...
Converted C:\msys32\home\Pete\esp\Application\components\NMEA\Target/CMakeLists.txt
  File "./esp-idf/tools/cmake/convert_to_cmake.py", line 195, in <module>
    main()
  File "./esp-idf/tools/cmake/convert_to_cmake.py", line 191, in main
    convert_project(args.project)
  File "./esp-idf/tools/cmake/convert_to_cmake.py", line 123, in convert_project
    p = subprocess.check_output(cmd).strip()
  File "C:/msys32/mingw32/lib/python2.7/subprocess.py", line 224, in check_output
    raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command '['cygpath', '-w', u'']' returned non-zero exit status 1
Angus
Postby Angus » Thu Dec 19, 2019 10:56 pm
Hi PeterR,
Looks like it's tripping up on some whitespace in the COMPONENT_PATHS list generated by Make, there must be two spaces between one of the entries.
Could you please try applying the following patch and see if it starts working as expected?
diff --git a/tools/cmake/convert_to_cmake.py b/tools/cmake/convert_to_cmake.py
index 0ba7fa62f5..2ac147006a 100755
--- a/tools/cmake/convert_to_cmake.py
+++ b/tools/cmake/convert_to_cmake.py
@@ -78,14 +78,14 @@ def get_component_variables(project_path, component_path):
             return None
         srcs = []
-        for obj in make_vars["COMPONENT_OBJS"].split(" "):
+        for obj in make_vars["COMPONENT_OBJS"].split():
             src = find_src(obj)
             if src is not None:
                 srcs.append(src)
         make_vars["COMPONENT_SRCS"] = " ".join(srcs)
     else:
         component_srcs = list()
-        for component_srcdir in make_vars.get("COMPONENT_SRCDIRS", ".").split(" "):
+        for component_srcdir in make_vars.get("COMPONENT_SRCDIRS", ".").split():
             component_srcdir_path = os.path.abspath(os.path.join(component_path, component_srcdir))
             srcs = list()
@@ -114,7 +114,7 @@ def convert_project(project_path):
     if "PROJECT_NAME" not in project_vars:
         raise RuntimeError("PROJECT_NAME does not appear to be defined in IDF project Makefile at %s" % project_path)
-    component_paths = project_vars["COMPONENT_PATHS"].split(" ")
+    component_paths = project_vars["COMPONENT_PATHS"].split()
     # Convert components as needed
     for p in component_paths:
BTW, something which isn't mentioned about the conversion tool but isn't is that it doesn't determine the "requirements" of a particular component (ie the dependency tree). If you have a component that uses headers from other components, the new component CMakeLists.txt files will need to be manually edited to add these dependencies or the headers won't be found when building. More about how to do that, here:
https://docs.espressif.com/projects/esp ... quirements
Will edit the build docs to mention this.
EDIT: Changed the patch
PeterR
Postby PeterR » Fri Dec 20, 2019 10:55 am
Thanks. The patch did not want to apply but manually removing the " " seems to work.
I am sure that I will have some detailed question latter which I will raise in another post.
bradcla
Postby bradcla » Fri Jun 18, 2021 11:46 pm
When I run "convert_to_cmake.py", I get a "Python was not found" message. However, when I type "py" from the same directory, I see Python startup and produce a "Python 3.9.5." message. Any ideas what could be going wrong?
nottledim
Postby nottledim » Sat Feb 12, 2022 1:58 pm
The `convert_to_cmake.py` program does not exist in latest esp-idf so I've copied it from github. Unfortunately it doesn't work:
Converting /home/dick/src/esp/projects/fouterlec-lcd...
  File "/home/dick/src/esp/esp-idf/tools/cmake/convert_to_cmake.py", line 205, in <module>
    main()
  File "/home/dick/src/esp/esp-idf/tools/cmake/convert_to_cmake.py", line 201, in main
  File "/home/dick/src/esp/esp-idf/tools/cmake/convert_to_cmake.py", line 117, in convert_project
    component_paths = project_vars['COMPONENT_PATHS'].split()
KeyError: 'COMPONENT_PATHS'
And line 117 of the program says:
and that's the only reference to COMPONENT_PATHS in the program. I've no idea where it is supposed to come from! Is there a quick fix I could use?
So what's the best way of converting a legacy Make project to the latest idf? Is there a document which gives instructions as to what to do?
Users browsing this forum: Amazon [Bot], ChatGPT-User and 4 guests
