POST request ESP32 with SIM7000
Posted: Sun Dec 29, 2019 9:34 am
Hi, I'm new and not able to make a POSTt request.
I'm working with the arduino IDE and attached to the ESP32 a SIM7000E.
I 've tried the "SIM7000-LTE-Shield-master"->"ESP32_LTE_Demo" , but not being able to make it work (POST request).
Here it is what I have:
Code:
Serial monitor response:
Code:
void loop() {
Serial.print(F("FONA> "));
while (! Serial.available() ) {
if (fona.available()) {
Serial.write(fona.read());
// Post data to website
uint16_t statuscode;
int16_t length;
char url[150];
char data[150];
flushSerial();
Serial.println(F("NOTE: in beta! Use simple websites to post!"));
Serial.println(F("URL to post (e.g. httpbin.org/post):"));
Serial.print(F("http://")); readline(url, 79);
Serial.println(url);
Serial.println(F("Data to post (e.g. \"foo\" or \"{\"simple\":\"json\"}\"):"));
readline(data, 79);
Serial.println(data);
Serial.println(F("****"));
if (!fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)) {
Serial.println("Failed!");
while (length > 0) {
while (fona.available()) {
char c = fona.read();
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
loop_until_bit_is_set(UCSR0A, UDRE0); // Wait until data register empty.
UDR0 = c;
#else
Serial.write(c);
#endif
length--;
if (! length) break;
Serial.println(F("\n****"));
fona.HTTP_POST_end();
// flush input
flushSerial();
}Code: Select all
12:10:28.794 -> NOTE: in beta! Use simple websites to post!
12:10:28.794 -> URL to post (e.g. httpbin.org/post):
12:10:28.794 -> http://www.atesens.com/post
12:10:40.286 -> Data to post (e.g. "foo" or "{"simple":"json"}"):
12:10:43.242 -> password
12:10:43.242 -> ****
12:10:43.276 -> ---> AT+HTTPTERM
12:10:43.311 -> <--- OK
12:10:43.346 -> ---> AT+HTTPINIT
12:10:43.381 -> <--- OK
12:10:43.416 -> ---> AT+HTTPPARA="CID"
12:10:43.449 -> <--- OK
12:10:43.482 -> ---> AT+HTTPPARA="UA"
12:10:43.515 -> <--- OK
12:10:43.582 -> ---> AT+HTTPPARA="URL"
12:10:43.615 -> <--- OK
12:10:43.649 -> ---> AT+HTTPPARA="REDIR"
12:10:43.682 -> <--- OK
12:10:43.751 -> ---> AT+HTTPSSL=1
12:10:43.785 -> <--- ERROR
12:10:43.785 -> Failed!
