esp-idf-tools-setup-2.2.exe Installation has failed with exit code 1
I have been trying to get the IDF setup for several days and have not been able to get the setup tool to run without error. I have searched for and tried all the suggestions that I can find with no luck. I keep getting this error and don't know what to do to fix it.
2020-01-02 07:44:14.159 Running command: C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0\python.exe "C:\Users\Ed\.espressif\idf_tools_fallback.py" --idf-path C:\Users\Ed\Desktop\esp-idf-2 --tools "C:\Users\Ed\.espressif\tools_fallback.json" install-python-env
File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0\lib\runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0\lib\runpy.py", line 85, in _run_code
exec(code, run_globals)
File "C:\Users\Ed\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\LocalCache\local-packages\Python37\site-packages\virtualenv.py", line 2634, in <module>
main()
File "C:\Users\Ed\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\LocalCache\local-packages\Python37\site-packages\virtualenv.py", line 870, in main
symlink=options.symlink,
File "C:\Users\Ed\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\LocalCache\local-packages\Python37\site-packages\virtualenv.py", line 1162, in create_environment
install_python(home_dir, lib_dir, inc_dir, bin_dir, site_packages=site_packages, clear=clear, symlink=symlink)
File "C:\Users\Ed\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\LocalCache\local-packages\Python37\site-packages\virtualenv.py", line 1532, in install_python
shutil.copyfile(executable, py_executable)
File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0\lib\shutil.py", line 120, in copyfile
with open(src, 'rb') as fsrc:
OSError: [Errno 22] Invalid argument: 'C:\\Users\\Ed\\AppData\\Local\\Microsoft\\WindowsApps\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\python.exe'
Using base prefix 'C:\\Program Files\\WindowsApps\\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0'
New python executable in C:\Users\Ed\.espressif\python_env\idf3.2_py3.7_env\Scripts\python.exe
Creating a new Python environment in C:\Users\Ed\.espressif\python_env\idf3.2_py3.7_env
File "C:\Users\Ed\.espressif\idf_tools_fallback.py", line 1387, in <module>
main(sys.argv[1:])
File "C:\Users\Ed\.espressif\idf_tools_fallback.py", line 1383, in main
action_func(args)
File "C:\Users\Ed\.espressif\idf_tools_fallback.py", line 1189, in action_install_python_env
stdout=sys.stdout, stderr=sys.stderr)
File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0\lib\subprocess.py", line 363, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['C:\\Users\\Ed\\AppData\\Local\\Microsoft\\WindowsApps\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\python.exe', '-m', 'virtualenv', '--no-site-packages', 'C:\\Users\\Ed\\.espressif\\python_env\\idf3.2_py3.7_env']' returned non-zero exit status 1.
main()
main(sys.argv[1:])
action_func(args)
Re: esp-idf-tools-setup-2.2.exe Installation has failed with exit code 1
It looks like you may be trying to use the new tools installer with IDF v3.2?
For v3.2, the getting started guide for Windows is here: https://docs.espressif.com/projects/esp ... setup.html. It involves using an MSYS based environment.
Do you need to use specifically IDF v3.2 (e.g. because of some dependency, such as ESP-MDF)?
If yes, then you have to follow the guide linked above, for IDF v3.2.
If no, then please try again with a newer version of IDF, such as release/v4.0 branch. You can learn more about the IDF versions here: https://docs.espressif.com/projects/esp ... sions.html
Still getting it with with v4.0. I was trying to install the 3.2 because of a build issue I had that other reported as corrected with the v3.2 IDF.
2020-01-02 08:24:11.557 Running command: C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.7_3.7.1520.0_x64__qbz5n2kfra8p0\python.exe C:\Users\Ed\Desktop\esp-idf\tools\idf_tools.py install-python-env
main()
New python executable in C:\Users\Ed\.espressif\python_env\idf4.0_py3.7_env\Scripts\python.exe
Creating a new Python environment in C:\Users\Ed\.espressif\python_env\idf4.0_py3.7_env
File "C:\Users\Ed\Desktop\esp-idf\tools\idf_tools.py", line 1372, in <module>
main(sys.argv[1:])
File "C:\Users\Ed\Desktop\esp-idf\tools\idf_tools.py", line 1368, in main
action_func(args)
File "C:\Users\Ed\Desktop\esp-idf\tools\idf_tools.py", line 1184, in action_install_python_env
subprocess.CalledProcessError: Command '['C:\\Users\\Ed\\AppData\\Local\\Microsoft\\WindowsApps\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\python.exe', '-m', 'virtualenv', '--no-site-packages', 'C:\\Users\\Ed\\.espressif\\python_env\\idf4.0_py3.7_env']' returned non-zero exit status 1.
main()
main(sys.argv[1:])
action_func(args)
and it also fails on the release/v4.0 IDF so I don't think this has anything to do with the IDF version.
Was able to get around this problem by switching to Python 2.7. Guess it isn't working with the version of Python I had (3.7.5)
Was the Python 3.7 installed using python.org installer, or as a Windows Store app? We have tested the installer with python.org distributions, but I think we haven't checked how it behaves with the Windows Store app, yet.
I don't remember how it was installed. There is no entry for it in the Windows programs control panel.
sametkocatepe
hi,
I have faced with this problem right now,
I have tried every thing that i can.
installing, uninstalling pythons, 2.7, 3.7, 3.8
tried many times but no success.
In addition, espressif has messed up everything. here are some confusions:
1. no eclipse support (I have seen somewhere) for v4.0, but there is an eclipse plugin which does not works for me. https://github.com/espressif/idf-eclipse-plugin
2. esp-mdf uses old esp-idf. currently trying to install this.
3.there was not literally install guide for anything (except for esp-idf v3.3 it was really good)
4. I have installed ESP8266-RTOS-SDK on windows by my efforts (your install guide was not work)
in every guides there are abeyances, in all, they have some problems.
I think you should review your tools, documents and others.
I had the same issue on Win7 .
Exactly this python2.x and 3.x
I also noticed that python3.4+(64bit) is not installing correctly on Win7
When I switched to Win10 , All works out of the box with no Issues .
And python 3.7 (64bit) is installing fine .
I think IDF is only supporting python3.7 (64bit)
Check if that is the issue cause the log you put shows the errors related to python .
I am getting the same kind of trouble, and I don't see a solution in this thread, but please correct me if I am wrong?
Best regards,
Peter
Best regards,
Peter
Users browsing this forum: PerplexityBot, PetalBot, Qwantbot, YisouSpider and 8 guests
