COMPONENT_REQUIRES not working in conditional config?
slompf
Postby slompf » Sun Jan 05, 2020 8:01 pm
I'm using my own custom component. Now I wanted to require components only in a specific config case. That doesn't seem to work:
Using this config (part):
set(COMPONENT_REQUIRES nvs_flash )
message("components 1: " "${COMPONENT_REQUIRES}")
message("config :" ${CONFIG_ESP32_HAP_STACK_IP})
if(CONFIG_ESP32_HAP_STACK_IP)
    list(APPEND COMPONENT_REQUIRES mdns)
    message("components 2: " "${COMPONENT_REQUIRES}")
endif()
leads to the following output. As you can see, mdns is not listed in the components list:
components 1: nvs_flash
config :y
components 2: nvs_flash;mdns
-- Components: app_trace app_update bootloader bootloader_support cxx driver efuse esp32 esp32_hap esp_common esp_eth esp_event esp_ringbuf esp_rom esp_wifi espcoredump esptool_py freertos heap log lwip main mbedtls newlib nvs_flash partition_table pthread soc spi_flash tcpip_adapter vfs wpa_supplicant xtensa
Changing the config to that:
list(APPEND COMPONENT_REQUIRES mdns) # This line was moved!!!
endif()
makes it work:
config :y
-- Components: app_trace app_update bootloader bootloader_support console cxx driver efuse esp32 esp32_hap esp_common esp_eth esp_event esp_ringbuf esp_rom esp_wifi espcoredump esptool_py freertos heap log lwip main mbedtls mdns newlib nvs_flash partition_table pthread soc spi_flash tcpip_adapter vfs wpa_supplicant xtensa
So even if the list is extended, the config system does not take it into account. Why? :shock:
Best regards,
Torsten
Angus
Re: COMPONENT_REQUIRES not working in conditional config?
Postby Angus » Sun Jan 05, 2020 11:25 pm
Hi Torsten,
That's right, unfortunately the requirements list can't depend on config as it gets expanded before config (this is a "chicken and egg" problem).
The v4.x build system docs have some guidelines for writing requirements, that includes this limitation:
https://docs.espressif.com/projects/esp ... quirements
(This is using the "new" component registration functions added in v4.0, setting a COMPONENT_REQUIRES variable does the same thing but the limitation is the same.)
We have had some internal discussion about making "soft requirements", ie "if component Y is included in the build anyhow then component X should depend on it", but there's no supported way to do this yet.
slompf
Postby slompf » Mon Jan 06, 2020 7:42 am
Ok, got that. Thank you very much.
Users browsing this forum: Google [Bot], Qwantbot, Semrush [Bot] and 1 guest
