ESP-IDF used as Submodule like ESP-ADF
mikemoy
Postby mikemoy » Tue Jan 14, 2020 3:40 am
In another thread @chegewara had what I thought was a great idea. But I am not sure how to implement it.
He said:
Lets look at esp-adf project for example. Esp-idf is used as submodule with particular commit:
https://github.com/espressif/esp-adf
I believe you can build any project you want the same way and instead of having global esp-idf, you can have esp-idf per project.
I like this idea. The reason being that looking in the future I can see a potential problem arising where projects that are built today and released using say v3.3.1. But later ESP-IDF will be on another version say v4.x.x. Should my customer want to make changes a year later I need to build that project built on v3.3.1 but my current setup is on v4.x.x which wont work.
Did all that makes sense ;-) How can I copy v3.3.1 into the each project so I know its all self contained much like what ESP-ADF does
chegewara
Re: ESP-IDF used as Submodule like ESP-ADF
Postby chegewara » Tue Jan 14, 2020 8:40 am
1) create project and git init
2) ad esp-idf as submodule https://stackoverflow.com/questions/420 ... repository
3) go to esp-idf and git commit to version you want
4) git add . & git push
https://github.com/chegewara/commit-test
Remember to configure CMakeLists.txt to use esp-idf from subfolder.
mikemoy
Postby mikemoy » Tue Jan 14, 2020 3:26 pm
Thank you for the example. But this did not go smooth sailing for me on the PC.
My default Windows IDF_PATH is C:\Users\Mike\ESP32\esp-idf
Its not clear to me in your example how its pointing to the new submodule.
The CMakeLists.txt file contains:
# The following lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
cmake_minimum_required(VERSION 3.5)
project(hello-world)
The way i read this is that it would be still using the defaul path and not pointing to the included ESP-IDF folder.
Am i just not seeing the light here or what ?
mrrosen
Postby mrrosen » Tue Jan 14, 2020 6:51 pm
For one of my projects, I did this exact thing however, this was right during the shift to cmake so I did it in the old Makefile system; like so (where I created the esp-idf as a submodule in the idf directory):
export IDF_PATH = $(PWD)/idf
PROJECT_NAME := my_project
include $(IDF_PATH)/make/project.mk
Pretty sure you could do that same thing with cmake by setting the IDF_PATH environment variable at the start of the file:
set(ENV{IDF_PATH} ${CMAKE_CURRENT_LIST_DIR}/idf)
project(my_project)
chegewara
Postby chegewara » Wed Jan 15, 2020 12:14 am
https://github.com/espressif/esp-adf/bl ... .txt#L6-L8
I didnt try it yet, but i believe you need to set IDF_PATH without if, just this line:
set(ENV{IDF_PATH} "${PROJECT_PATH}/esp-idf/")
set(EXTRA_COMPONENT_DIRS ${PROJECT_PATH}/components)
mikemoy
Postby mikemoy » Wed Jan 15, 2020 4:24 am
Thanks guys for the help. Didn't work for me. I got much closer with
At the moment I just don't have the time to dig into this.
chegewara
Postby chegewara » Fri Jan 17, 2020 11:56 am
Ok, ive been overthinking it, but it is very simple. I am using PIO and from PIO terminal i had to do this:
. ./esp-idf/export.sh
idf.py build
It was with esp-idf v3.3 as submodule described earlier.
PS no changes needed in CMakeLists.txt i mentioned earlier, just forget it
phatpaul
Postby phatpaul » Wed Aug 10, 2022 8:51 pm
I had been doing this since IDF 3 with make. I had a custom build script.
When I ported to IDF 4 with CMake, I created a new init scripts to set the environment.
(My CMakeLists.txt doesn't need anything special for this b/c my init script sets IDF_PATH in the environment. It still uses include("$ENV{IDF_PATH}/tools/cmake/project.cmake"))
I made a windows version and a linux of the script. It expects the esp-idf to be a git submodule in the project repo/tools/esp-idf/.
You can just double-click the _START_IDF_ENV.cmd file to start a cmd window.
On linux you have to type: source sourceme_IDF_ENV.sh
Code: _START_IDF_ENV.cmd Select all
@REM Script for launching ESP-IDF environment on Windows
@REM Author: Paul Abbott, 2022
@ECHO OFF
TITLE ESP-IDF
SETLOCAL EnableDelayedExpansion
: %CD% gives current dir
SET THISDIR=%CD%
: %~dp0 gives the directory of this batch file (with a trailing \)
SET SCRIPTDIR=%~dp0
:: if using IDF installed globally ::
: SET "IDF_INIT_SCRIPT=C:\Espressif\idf_cmd_init.bat"
:: See C:\Espressif\esp_idf.json for installed IDF version strings
:: Version 4.4
: SET "IDF_VERS_STRING=esp-idf-8de2bd0d9cffd2eca3d3f8442939a034"
:: Version 4.3
: SET "IDF_VERS_STRING=esp-idf-7a3cc3545977e8fdecfa73521e1f3180"
:: if using IDF inside repo as submodule::
SET "IDF_INIT_SCRIPT=%SCRIPTDIR%..\tools\esp-idf\install.bat"
SET "IDF_INIT_SCRIPT2=%SCRIPTDIR%..\tools\esp-idf\export.bat"
IF NOT EXIST %IDF_INIT_SCRIPT% (
MORE %SCRIPTDIR%readme.md
ECHO Script %IDF_INIT_SCRIPT% does not exist!.
GOTO :DIE
CALL %IDF_INIT_SCRIPT% %IDF_VERS_STRING%
IF !ERRORLEVEL! NEQ 0 goto :DIE
IF NOT EXIST %IDF_INIT_SCRIPT% GOTO :DONE
CALL %IDF_INIT_SCRIPT2%
:DONE
GOTO :SHELL
:DIE
: Color the screen red
COLOR 4f
ECHO ERROR!
PAUSE
GOTO :QUIT
:QUIT
: Restore the Color of the screen
COLOR 07
GOTO :eof
:SHELL
COLOR 07
ECHO/
ECHO idf build flash monitor -p COM15
ECHO/
cmd /k
Code: sourceme_IDF_ENV.sh Select all
#!/bin/bash
# Script for setting up ESP_IDF environment on Ubuntu
# use it like this: `source sourceme_IDF_ENV.sh`
# Author: Paul Abbott, 2022
SCRIPT_VER="1.0"
SCRIPT_DIR=$(realpath "$(dirname "${BASH_SOURCE[0]}")")
PWD=$(pwd)
# this only works when sourced (not run as a script), because it is adding variables into the local shell
[[ "${BASH_SOURCE[0]}" == "${0}" ]] && echo "Error, must source this script! Try: \"source ${BASH_SOURCE[0]}\"" && exit 1
source $SCRIPT_DIR/../tools/esp-idf/export.sh
alias idf="idf.py"
# These commands will not execute, but will be in the history for convenience.
history -s idf build
history -s idf build flash monitor -p /dev/ttyUSB0
phatpaul
Postby phatpaul » Wed Aug 10, 2022 9:03 pm
The scripts I posted above work OK, as long as you have the correct version of esp-idf checked-out as git submodule working copy. But I find it is common that a dev forgot to do git submodule update --init --recursive after pulling other changes that expect a different esp-idf.
So I added another script that checks that all submodules are at their expected versions. This one is called by CMake.
(I adapted this code from https://github.com/iree-org/iree/pull/6568)
Code: CMakeLists.txt Select all
# Check if git submodules have been initialized.
# This will only run if python3 is available.
find_package(Python3 COMPONENTS Interpreter QUIET)
if(Python3_FOUND)
message("check_submodules")
execute_process(
COMMAND ${Python3_EXECUTABLE} ../tools/check_submodules.py
WORKING_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}
RESULT_VARIABLE ret
if(NOT ret EQUAL "0")
message(FATAL_ERROR "check_submodule_init.py failed, see the logs above")
endif()
endif()
project(poco-fw-ota)
Code: check_submodules.py Select all
# Copyright 2021 The IREE Authors
# Licensed under the Apache License v2.0 with LLVM Exceptions.
# See https://llvm.org/LICENSE.txt for license information.
# SPDX-License-Identifier: Apache-2.0 WITH LLVM-exception
import os
import subprocess
import sys
def run():
# No-op if we're not in a git repository.
try:
subprocess.check_call(['git', 'rev-parse', '--is-inside-work-tree'],
stdout=subprocess.DEVNULL,
stderr=subprocess.DEVNULL)
except:
return
output = os.popen("git submodule status --recursive")
submodules = output.readlines()
for submodule in submodules:
if (submodule.strip()[0] == "-"):
print(
"Error: The git submodule '%s' is not initialized. Please run `git submodule update --init --recursive`"
% (submodule.split()[1]))
sys.exit(1)
if (submodule.strip()[0] == "+"):
print(
"Warning: The git submodule '%s' is at a different version than expected. Please run `git submodule update --init --recursive`"
if __name__ == "__main__":
run()
BTW:
I'm curious if the new idf-component-manager is a better tool for this though. It looks like it can set the required IDF version in your manifest file.
https://docs.espressif.com/projects/esp ... nager.html
Users browsing this forum: Amazon [Bot] and 2 guests
