JTAG Debugging "Failed to verify app image @0x10000 <8194>"
aaquilina
Postby aaquilina » Wed Mar 08, 2017 5:11 pm
I'm debugging using JTAG and recently, more often than not, I get the error "Failed to verify app image @0x10000 <8194>" when trying to reprogram for debug. I then try to flash the ESP32 with the hello world program over serial and it succeeds without fail. After a while of a series of reprogramming, unplugging, plugging and resetting, I manage to get it to debug for a short while until this happens again. Full disclosure: I'm using VisualGDB with VisualStudio for debugging but this has been working for the past month and a half. I've also emailed them to see if the issue might be from their side. Any thought? :?
WiFive
Re: JTAG Debugging "Failed to verify app image @0x10000 <8194>"
Postby WiFive » Wed Mar 08, 2017 5:28 pm
Have you considered setting flash voltage in efuse to bypass mtdi strapping pin?
aaquilina
Postby aaquilina » Wed Mar 08, 2017 5:32 pm
Not yet :D ! How would I do this?
Angus
Postby Angus » Wed Mar 08, 2017 11:10 pm
To expand on WiFive's answer, the exact command is:
components/esptool_py/esptool/espefuse.py set_flash_voltage 3.3V
(MTDI pin will be ignored on reset when setting flash voltage, it will always be 3.3V.)
aaquilina
Postby aaquilina » Thu Mar 09, 2017 1:24 pm
I've managed to set the flash voltage. However, I still getting the same errors while using VisualGDB JTAG debugger. I need to identify where the issue is coming from. Whether it's a VisualGDB issue, JTAG issue or a code issue. Luckily, I have another ESP32 Board with the same issue if anyone has any other suggestion or maybe a follow up?
The ESP32 also outputs this feed when I try debug sometimes. The issue is that I cant really identify a pattern in the different outputs.
f.h-f.s.
Postby f.h-f.s. » Fri Mar 10, 2017 9:34 am
I've had a similar problem using VisualGDB, They responded on their forum saying to edit the Debug setting Flash timeout in VisualGDB project properties. I set it to 10000.
Or
open with notepad: "YourProjectNameHere-Debug.vgdbsettings" located in your project folder and add
        <KeyValue>
          <Key>com.sysprogs.esp32.openocd.alg_timeout</Key>
          <Value>10000</Value>
        </KeyValue>
inside the </Entries> </DebugMethodProperties> tags.
My problem was, the debugger moved on to the next bit of programming before it was done. Atleast thats what I think it did. Hope it helps.
aaquilina
Postby aaquilina » Fri Mar 10, 2017 9:45 am
Thanks for your input. Unfortunately, I already tried this. Its strange because I used the board for a month before it started doing this. I ordered some new boards to test whether its caused by the boards at all. Are you still using VisualGDB?
aaquilina
Postby aaquilina » Fri Mar 10, 2017 10:44 am
It turns out the second serial output that I posted is caused by something else, so it seems to be two different errors. The second I believe is caused by me hard coding a rather large website (815KB) into a header file. I will start a separate post on this issue. Thanks for your help so far. This also means that the efuse burning may have in fact fixed my issue. I will confirm later today if it occurs again.
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, Google [Bot] and 1 guest
