FastLed
Posted: Mon Jan 20, 2020 12:30 pm
by stevepenrhiw
Hi
I'm trying to get the FastLed library working on an ESP-devkitC. My understanding is that FastLed has been ported to the esp32, but no work has been done maintaining it for a couple of years.
The library source uses a header file "esp32-hal.h", which I believe is part of esp-idf but I cannot find. Has this file been replaced by another file.
Steve
Re: FastLed
Posted: Mon Jan 20, 2020 5:38 pm
by ESP_igrr
Hi Steve, the file you mention is part of esp32-arduino package. It is not included in ESP-IDF. You can try using Arduino as ESP-IDF component: https://github.com/espressif/arduino-es ... mponent.md
Re: FastLed
Posted: Mon Jan 20, 2020 8:18 pm
by stevepenrhiw
Hi
That's just the job. I'm making progress again. It also answers a couple other questions I had about the FastLED library.
Thanks for the fast response.
Steve
Re: FastLed
Posted: Fri Feb 28, 2020 9:01 am
by bbulkow
I have just ported the FastLED 3.3.4 code as a component that works with ESP-IDF 4.0.
The repository is here: https://github.com/bbulkow/FastLED-idf . If you like it, star it, thanks. Pull requests accepted as well.
There are copious notes in the README, and I'll continue improving it --- but seems to be working nicely here, so enjoy.
Re: FastLed
Posted: Mon Mar 28, 2022 12:18 am
by CamargoF
I download your example and its compile on ESP-IDF (ESP32) VScode extension without any problem, but when I try to you it on the project I migrate from Arduino there are too many error as shown below:
Code: Untitled.txt Select all
../components/FastLED-idf/FastLED.h:270:62: error: 'RGB_ORDER' was not declared in this scope
case P9813: { static P9813Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER> c; return addLeds(&c, data, nLedsOrOffset, nLedsIfOffset); }
../components/FastLED-idf/FastLED.h:270:62: note: suggested alternative: 'BYTE_ORDER'
BYTE_ORDER
../components/FastLED-idf/FastLED.h:270:71: error: template argument 3 is invalid
../components/FastLED-idf/FastLED.h:270:129: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:213:25: note: candidate: 'static CLEDController& CFastLED::addLeds(CLEDController*, CRGB*, int, int)'
static CLEDController &addLeds(CLEDController *pLed, struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0);
../components/FastLED-idf/FastLED.h:213:25: note: no known conversion for argument 1 from 'int*' to 'CLEDController*'
../components/FastLED-idf/FastLED.h:235:130: note: candidate: 'template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, <declaration error>, unsigned int SPI_DATA_RATE> CLEDController& CFastLED::addLeds(CRGB*, int, int)'
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER, uint32_t SPI_DATA_RATE > CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
../components/FastLED-idf/FastLED.h:235:130: note: template argument deduction/substitution failed:
../components/FastLED-idf/FastLED.h:270:129: note: candidate expects 3 arguments, 4
provided
../components/FastLED-idf/FastLED.h:249:95: note: candidate: 'template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)'
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN > static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
../components/FastLED-idf/FastLED.h:249:95: note: template argument deduction/substitution failed:
provided
../components/FastLED-idf/FastLED.h:263:113: note: candidate: 'template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, <declaration error> > static
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER > static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
../components/FastLED-idf/FastLED.h:263:113: note: template argument deduction/substitution failed:
provided
../components/FastLED-idf/FastLED.h:313:25: note: candidate: 'template<template<unsigned char DATA_PIN, <declaration error> > class CHIPSET, unsigned char DATA_PIN, <declaration error> > static CLEDController& CFastLED::addLeds(CRGB*, int, int)'
../components/FastLED-idf/FastLED.h:313:25: note: template argument deduction/substitution failed:
provided
../components/FastLED-idf/FastLED.h:319:25: note: candidate: 'template<template<unsigned char DATA_PIN, <declaration error> > class CHIPSET, unsigned char DATA_PIN> static
../components/FastLED-idf/FastLED.h:319:25: note: template argument deduction/substitution failed:
provided
../components/FastLED-idf/FastLED.h:325:25: note: candidate: 'template<template<unsigned char DATA_PIN> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)'
../components/FastLED-idf/FastLED.h:325:25: note: template argument deduction/substitution failed:
provided
../components/FastLED-idf/FastLED.h:375:25: note: candidate: 'template<template<<declaration error> > class CHIPSET> static CLEDController& CFastLED::addLeds(CRGB*, int, int)'
../components/FastLED-idf/FastLED.h:375:25: note: template argument deduction/substitution failed:
provided
../components/FastLED-idf/FastLED.h:272:64: error: 'RGB_ORDER' was not declared in this scope
case APA102: { static APA102Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER> c; return addLeds(&c, data, nLedsOrOffset, nLedsIfOffset); }
../components/FastLED-idf/FastLED.h:272:64: note: suggested alternative: 'BYTE_ORDER'
BYTE_ORDER
../components/FastLED-idf/FastLED.h:272:73: error: template argument 3 is invalid
../components/FastLED-idf/FastLED.h:272:131: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:272:131: note: candidate expects 3 arguments, 4
provided
provided
provided
provided
provided
provided
provided
../components/FastLED-idf/FastLED.h:273:64: error: 'RGB_ORDER' was not declared in this scope
case SK9822: { static SK9822Controller<DATA_PIN, CLOCK_PIN, RGB_ORDER> c; return addLeds(&c, data, nLedsOrOffset, nLedsIfOffset); }
../components/FastLED-idf/FastLED.h:273:64: note: suggested alternative: 'BYTE_ORDER'
BYTE_ORDER
../components/FastLED-idf/FastLED.h:273:73: error: template argument 3 is invalid
../components/FastLED-idf/FastLED.h:273:131: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:273:131: note: candidate expects 3 arguments, 4
provided
provided
provided
provided
provided
provided
provided
../components/FastLED-idf/FastLED.h: In static member function 'static CLEDController& CFastLED::addLeds(CRGB*, int, int)':
../components/FastLED-idf/FastLED.h:314:28: error: 'RGB_ORDER' was not declared in this scope
static CHIPSET<DATA_PIN, RGB_ORDER> c;
../components/FastLED-idf/FastLED.h:314:28: note: suggested alternative: 'BYTE_ORDER'
BYTE_ORDER
../components/FastLED-idf/FastLED.h:314:37: error: template argument 2 is invalid
../components/FastLED-idf/FastLED.h:315:56: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:315:56: note: candidate expects 3 arguments, 4 provided
../components/FastLED-idf/FastLED.h:320:28: error: 'RGB' was not declared in this scope
static CHIPSET<DATA_PIN, RGB> c;
../components/FastLED-idf/FastLED.h:320:28: note: suggested alternative: 'CRGB'
CRGB
../components/FastLED-idf/FastLED.h:320:31: error: template argument 2 is invalid
../components/FastLED-idf/FastLED.h:321:56: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:321:56: note: candidate expects 3 arguments, 4 provided
../components/FastLED-idf/FastLED.h:370:18: error: 'RGB_ORDER' was not declared in this scope
static CHIPSET<RGB_ORDER> c;
../components/FastLED-idf/FastLED.h:370:18: note: suggested alternative: 'BYTE_ORDER'
BYTE_ORDER
../components/FastLED-idf/FastLED.h:370:27: error: template argument 1 is invalid
../components/FastLED-idf/FastLED.h:371:56: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:371:56: note: candidate expects 3 arguments, 4 provided
../components/FastLED-idf/FastLED.h:376:18: error: 'RGB' was not declared in this scope
static CHIPSET<RGB> c;
../components/FastLED-idf/FastLED.h:376:18: note: suggested alternative: 'CRGB'
CRGB
../components/FastLED-idf/FastLED.h:376:21: error: template argument 1 is invalid
../components/FastLED-idf/FastLED.h:377:56: error: no matching function for call to 'CFastLED::addLeds(int*, CRGB*&, int&, int&)'
../components/FastLED-idf/FastLED.h:377:56: note: candidate expects 3 arguments, 4 provided
The calls I used to do on my code are:
Code: Untitled.c Select all
FastLED.setBrightness(fitaledGetBrightnessPainel());
FastLED.setCorrection(TypicalLEDStrip);
FastLED.addLeds<WS2812B, FITA_LED0_PINO_DADO, RGB>(fitaPixels, fitaSize);
FastLED.show();
I tried to replace the FastLed component on my project as well as copy my source file to your example project (that was compiling without any error before), but the errors move from one project to another one.
I am a little bit disappointed since FastLED works fine on Arduino.
I appreciate if you could indicate how to fix it, or to recommend another library to use with ESP-IDF.
Best regards,
FC
