Need Example to configure and start WPS mode into ESP32-IDF RTOS SDK
Posted: Thu Mar 09, 2017 10:43 am
I am working on ESP32-IDF 2.0 RC1 RTOS SDK and I want to enable and start WPS mode into Station Mode. I have written some cdoe but not sure it will be worked or not.
Please find following code to start WPS mode.
Let me know if anyone has configured WPS mode in PBC or PIN mode configuration and started it successfully without any issue. Also provide me if any sample program for that
void WifiInIt()
esp_err_t error_code = 0;
tcpip_adapter_init();
wifi_event_group = xEventGroupCreate();
ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_FLASH) );
/// Added for WPS support only
error_code = esp_wifi_set_mode(WIFI_MODE_STA);
if(error_code)
printf("esp_wifi_set_mode is failed to execute...\n");
else
printf("esp_wifi_set_mode is executed successfully...\n");
/// End edit
}Code: Select all
int app_main(void)
nvs_flash_init();
WifiInIt();
/// Added code to check WPS support only
//error_code = esp_wifi_wps_enable(WPS_TYPE_PIN); /// WPS PIN Configuration Type
error_code = esp_wifi_wps_enable(WPS_TYPE_PBC); /// WPS PBC (Push Button Configuration) Type
if(error_code)
printf("esp_wifi_wps_enable is failed to execute...\n");
else
printf("esp_wifi_wps_enable is executed successfully...\n");
Delay(5000);
/* 120 milliseconds blocking time*/
error_code = esp_wifi_wps_start(120);
if(error_code)
printf("esp_wifi_wps_start is failed to execute...\n");
else
printf("esp_wifi_wps_start is executed successfully...\n");
Delay(5000);
/// End edit
return 0;
