A2dp sink not working :(
mooalot
Postby mooalot » Sun Jan 26, 2020 4:50 am
Im using the master branch for the a2dp sink example, but I cant get it to work.
I believe the hardware is setup correctly because I have used dac_output_voltage() function to output a sine wave. The sine wave outputs on my speaker just fine.
When I try to connect my phone, however, there is no audio output.
I think I followed this guide exactly https://github.com/espressif/esp-idf/tr ... /a2dp_sink
I changed the menuconfig to the internal 8 bit dac output and I made sure that bluetooth classic and a2dp were enabled.
The output is just silence, but the monitor shows that it is receiving the audio packets and AVRC controls as it should:
I (57927) BT_AV: Audio packet count 400
I (58487) RCTG: Volume is set locally to: 19%
I (60257) BT_AV: Audio packet count 500
Help... :oops:
dimfred
Re: A2dp sink not working :(
Postby dimfred » Tue Mar 31, 2020 3:29 pm
+1, same problem here.
dimfred
Postby dimfred » Tue Mar 31, 2020 6:30 pm
Got it working by switching replacing:
in i2s_config_t
communication_format=I2S_COMM_FORMAT_I2S_MSB
to
communication_format : I2S_COMM_FORMAT_PCM
my sound was terrible then, so I added https://github.com/espressif/esp-idf/issues/1614 what @macaba mentioned to improve the quality, it still sucks but better than nothing ^^
I am using v4.1 btw
For me this says that the a2dp_sink example is kinda buggy or I am doing something wrong, idk.
Hope this helps
mooalot
Postby mooalot » Fri Apr 03, 2020 6:00 pm
Thanks! That helped a ton! Too bad its only an 8 bit dac
