ESP-MESH Programming Guide Code Questions
I'm learning to build a mesh network by following the ESP-MESH Programming Guide provided by Espressif. I copied all the code snippets from that guide to my project, but the compiler is giving me a bunch of errors which I don't know how to solve. I'm thinking that I don't have the correct libraries included. If someone could help me take a look, that would be awesome. Thanks!
- Code Error 2.png (30.06 KiB) Viewed 10621 times
- Code Error 1.png (65.41 KiB) Viewed 10621 times
- main.c
- (2.87 KiB) Downloaded 687 times
Re: ESP-MESH Programming Guide Code Questions
Hi
1. It is recommended that you use esp-mdf sdk to learn the mesh function.
2. Modified your code, it can be successfully compiled on esp-idf master.
thanks.
thanks.
- main.c
- (3.11 KiB) Downloaded 597 times
