Using MCPWM periferal to generate desired pattern
gunar.kroeger
Postby gunar.kroeger » Mon Jan 27, 2020 8:58 pm
Hi all,
We have to generate this pulse sequence on 2 pins:
this sequence should be repeated indefinitely.
What we are achieving is either another sequence being generated (1,0,1,0,0) or the correct sequence, but unsynchronized between the 2 channels. In this last case, every time we reset the board, the delay between the pulses in pin 1 and pin 2 is different. There is no "drift" of this delay during execution.
What is the correct code initialization to obtain exactly the pulses from the attached image?
  1. /*
  2.  * ChargePump.c
  3.  *
  4.  *  Created on: 27 de jan de 2020
  5.  *      Author: joao.istchuk
  6.  */
  7. #define LOG_LOCAL_LEVEL ESP_LOG_VERBOSE
  8. #include "ChargePump.h"
  9.
  10. #define RMT_NS      12.5
  11. //times in nanoseconds
  12. #define TLO         25000 / RMT_NS
  13. #define THI         25000 / RMT_NS
  14.
  15. static void rmt_tx_init(void);
  16.
  17. extern Pins pins;
  18.
  19. static bool chage_pump_instaled = false;
  20.
  21. static rmt_item32_t items[] = {
  22.     // Setup
  23.     {{{ THI, 1, TLO, 0 }}},
  24.     {{{ TLO/2, 0, 0, 0 }}},
  25.     {{{ 0, 0, 0, 0 }}}
  26. };
  27.
  28. static rmt_item32_t items2[] = {
  29.     // Setup
  30.     {{{ THI, 1, TLO, 0 }}},
  31.     {{{ TLO/2, 0, 0, 0 }}},
  32.     {{{ 0, 0, 0, 0 }}}
  33. };
  34.
  35.
  36. void chargePumpInit()
  37. {
  38.     rmt_tx_init();
  39.     chage_pump_instaled = true;
  40. }
  41.
  42. void chargePumpDisable()
  43. {
  44.     if(chage_pump_instaled)
  45.     {
  46.         rmt_tx_stop(RMT_CHANNEL_0);
  47.         rmt_tx_stop(RMT_CHANNEL_1);
  48.     }
  49. }
  50.
  51. void chargePumpEnable()
  52. {
  53.     if(chage_pump_instaled)
  54.     {
  55.         rmt_tx_start(RMT_CHANNEL_0,true);
  56.         rmt_tx_start(RMT_CHANNEL_1,true);
  57.     }
  58. }
  59.
  60. /*
  61.  * Initialize the RMT Tx channel
  62.  */
  63. static void rmt_tx_init(void)
  64. {
  65.     rmt_config_t config;
  66.     config.rmt_mode = RMT_MODE_TX;
  67.     config.mem_block_num = 1;
  68.     config.tx_config.loop_en = 1;
  69.     // enable the carrier to be able to hear the Morse sound
  70.     // if the RMT_TX_GPIO is connected to a speaker
  71.     config.tx_config.carrier_en = 0;
  72.     config.tx_config.idle_output_en = 0;
  73.     config.tx_config.idle_level = 0;
  74.     config.tx_config.carrier_duty_percent = 50;
  75.     // set audible career frequency of 611 Hz
  76.     // actually 611 Hz is the minimum, that can be set
  77.     // with current implementation of the RMT API
  78.     config.tx_config.carrier_freq_hz = 611;
  79.     config.tx_config.carrier_level = 1;
  80.     // set the maximum clock divider to be able to output
  81.     // RMT pulses in range of 500ns
  82.     config.clk_div = 1;
  83.
  84.     config.channel = RMT_CHANNEL_0;
  85.     config.gpio_num = pins.cp_ctrl_1;
  86.
  87.     ESP_ERROR_CHECK(rmt_config(&config));
  88.     ESP_ERROR_CHECK(rmt_driver_install(config.channel, 0, 0));
  89.
  90.     config.channel = RMT_CHANNEL_1;
  91.     config.gpio_num = pins.cp_ctrl_2;
  92.
  93.     ESP_ERROR_CHECK(rmt_config(&config));
  94.     ESP_ERROR_CHECK(rmt_driver_install(config.channel, 0, 0));
  95.
  96.     ESP_ERROR_CHECK(rmt_fill_tx_items(RMT_CHANNEL_0,items,sizeof(items)/sizeof(items[0]),0));
  97.     ESP_ERROR_CHECK(rmt_fill_tx_items(RMT_CHANNEL_1,items2,sizeof(items2)/sizeof(items2[0]),0));
  98.
  99.     portDISABLE_INTERRUPTS();
  100.     rmt_tx_start(RMT_CHANNEL_0,false);
  101.     rmt_tx_start(RMT_CHANNEL_1,false);
  102. //  rmt_write_items(RMT_CHANNEL_0, items,   sizeof(items)/sizeof(items[0]), false);
  103. //  rmt_write_items(RMT_CHANNEL_1, items2,  sizeof(items)/sizeof(items[0]), false);
  104.     portENABLE_INTERRUPTS();
  105.
  106. }
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
gunar.kroeger
Re: RMT peripheral synchronized channels
Postby gunar.kroeger » Thu Jan 30, 2020 1:58 pm
I see there is a MCPWM component that is much better suited for this.
Still, for future applications this might be usefull to know.
gunar.kroeger
Postby gunar.kroeger » Mon Feb 10, 2020 2:48 pm
Actually I still am not able to generate that signal. Could someone help me out?
I don't understand how to configure the deadtime properly.
static void mcpwm_example_gpio_initialize()
	ESP_LOGI(TAG, "initializing mcpwm gpio...\n");
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, pins.cp_ctrl_1);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0B, pins.cp_ctrl_2);
	ESP_LOGI(TAG, "Testing brushed motor...\n");
    //1. mcpwm gpio initialization
    mcpwm_example_gpio_initialize();
    //2. initial mcpwm configuration
    ESP_LOGI(TAG, "Configuring Initial Parameters of mcpwm...\n");
    mcpwm_config_t pwm_config;
    pwm_config.frequency = 10000;    //frequency = 1000Hz,
    pwm_config.cmpr_a = 0;    //duty cycle of PWMxA = 0
    pwm_config.cmpr_b = 0;    //duty cycle of PWMxb = 0
    pwm_config.counter_mode = MCPWM_UP_COUNTER;
    pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
    mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);    //Configure PWM0A & PWM0B with above settings
	mcpwm_set_signal_low(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A);
	mcpwm_set_signal_low(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_B);
	mcpwm_deadtime_enable(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_BYPASS_RED, 500, 500); //red*100ns,  fed*100ns
    mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, 25);
    mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_B, 25);
    mcpwm_set_duty_type(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, MCPWM_DUTY_MODE_0);  //call this each time, if operator was previously in low/high state
    mcpwm_set_duty_type(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_B, MCPWM_DUTY_MODE_0);  //call this each time, if operator was previously in low/high state
jmcornil
Re: Using MCPWM periferal to generate desired pattern
Postby jmcornil » Wed Feb 12, 2020 2:59 pm
Hello
did you try to use MCPWM and an XOR gate ?
  • with TIMER_0, you cant get the first signal : (1 0 0 0) for pin 1
  • with TIMER_1, you can get the two signals : (1 1 0 0) and (1 1 1 0) of which the XOR gives pin 2
Is it not good for you ?
Best regards
gunar.kroeger
Postby gunar.kroeger » Wed Feb 12, 2020 5:02 pm
It isn't. The PCB has already been fabricated.
Honestly the docs for MCPWM were the most confusing yet. Like what the hell is a "compliment of rising edge delay"?
For example, if I set the MCPWM_UP_DOWN_COUNTER, mcpwm_set_frequency sets double the value, and there are many other things like this in this API that make it impossible for me to quickly get something working.
I eventually gave up on this and used timers and interrupts for now. If someone could better explain this API or when it is rewritten to be more user friendly I might try again.
jmcornil
Postby jmcornil » Thu Feb 13, 2020 9:18 am
Hello
I think than it is OK with the following init.
I use MCPWM but with only one timer : TIMER_0
The three Operator are linked to TIMER_0
  • On GPIO_PWM0A_OUT, I get your pin1 signal
  • On GPIO_PWM1A_OUT, I get your pin2 signal
  • The third pin is just for me to control
I used huge prescaler for i have no oscillo here and I can just test with leds.
I let you adjust PMW_CLK_PRESCALER and PMW_TIMER_PRESCALER macros.
#define GPIO_PWM0A_OUT 17   //Set GPIO 17 as PWM0A
#define GPIO_PWM1A_OUT 18   //Set GPIO 18 as PWM1A
#define GPIO_PWM2A_OUT 19   //Set GPIO 19 as PWM2A
#define PMW_CLK_PRESCALER   128-1   // Prescal I for pwm
#define PMW_TIMER_PRESCALER 150-1   // Prescal II for pwm
#define PMW_TIMER_PERIOD 40000UL    // Period of the pwm
enum{MCPWM_CMPA,MCPWM_CMPB};
void MCPWM_Init(){
	mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_PWM0A_OUT);
   	mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_PWM1A_OUT);
    	mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM2A, GPIO_PWM2A_OUT);
	// MCPWM  Prescaler Initialisation
	// First The clock prescale
	mcpwm_ll_set_clock_prescale(&MCPWM0, PMW_CLK_PRESCALER);
	// Timer0 initialisation
	mcpwm_ll_timer_set_prescale(&MCPWM0, MCPWM_TIMER_0, PMW_TIMER_PRESCALER);
	mcpwm_ll_timer_set_count_mode(&MCPWM0, MCPWM_TIMER_0, 1);  // 1 pour incrémenter le timer
	mcpwm_ll_timer_set_period(&MCPWM0, MCPWM_TIMER_0, PMW_TIMER_PERIOD);
	// Choix des timers pour chacun des trois opérateur
	enum { OP0, OP1, OP2};
	mcpwm_ll_operator_select_timer(&MCPWM0, OP0, MCPWM_TIMER_0);
	// I let OP1 and OP2 on timer_0
	mcpwm_ll_operator_select_timer(&MCPWM0, OP1, MCPWM_TIMER_0);
	mcpwm_ll_operator_select_timer(&MCPWM0, OP2, MCPWM_TIMER_0);
	// Operator 0 initialisation
	mcpwm_ll_operator_set_compare(&MCPWM0, OP0, MCPWM_CMPA, 10000);
	mcpwm_ll_gen_set_zero_action (&MCPWM0, OP0, MCPWM_GEN_A, MCPWM_ACTION_FORCE_HIGH);
	mcpwm_ll_gen_set_cmp_action  (&MCPWM0, OP0, MCPWM_GEN_A, MCPWM0A, MCPWM_ACTION_FORCE_LOW,MCPWM_ACTION_NO_CHANGE);
	// Operator 1 initialisation
	mcpwm_ll_operator_set_compare(&MCPWM0, OP1, MCPWM_CMPA, 20000);
	mcpwm_ll_operator_set_compare(&MCPWM0, OP1, MCPWM_CMPB, 30000);
	mcpwm_ll_gen_set_zero_action (&MCPWM0, OP1, MCPWM_GEN_A, MCPWM_ACTION_FORCE_LOW);
	mcpwm_ll_gen_set_cmp_action  (&MCPWM0, OP1, MCPWM_GEN_A, MCPWM0A, MCPWM_ACTION_FORCE_HIGH,MCPWM_ACTION_NO_CHANGE);
	mcpwm_ll_gen_set_cmp_action  (&MCPWM0, OP1, MCPWM_GEN_A, MCPWM0B, MCPWM_ACTION_FORCE_LOW,MCPWM_ACTION_NO_CHANGE);
	// Operator 2 initialisation (just to see)
	mcpwm_ll_operator_set_compare(&MCPWM0, OP2, MCPWM_CMPA, 30000);
	mcpwm_ll_gen_set_zero_action (&MCPWM0, OP2, MCPWM_GEN_A, MCPWM_ACTION_FORCE_HIGH);
	mcpwm_ll_gen_set_cmp_action  (&MCPWM0, OP2, MCPWM_GEN_A, MCPWM0A, MCPWM_ACTION_FORCE_LOW,MCPWM_ACTION_NO_CHANGE);
	// Timer(s) start
	mcpwm_ll_timer_start(&MCPWM0,MCPWM_TIMER_0);
Best regards
Users browsing this forum: huang.yan, MSN [Bot] and 64 guests
