JTAG debugging is not working: Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
ice.bob
Postby ice.bob » Thu Jan 30, 2020 10:42 pm
Hello guys,
I totally do not get it. So I have been using the blink example as a starter to program the ESP32WROVER-B (ESP-WROVER-KitV4.1) module. All the JTAG jumpers are correctly set, also the udev rules within my Ubuntu 19.10 machine.
I can successfully compile and flash the bare "blink" example (
idf.py -p /dev/ttyUSB1 cleanfull build flash monitor
). JTAG debugging is also working using
openocd -f board/esp32-wrover-kit-3.3v.cfg
. As soon as I extend the code base for a minimum debugging is not working any more. I get the following error:
$ openocd -f board/esp32-wrover-kit-3.3v.cfg
Open On-Chip Debugger  v0.10.0-esp32-20191114 (2019-11-14-14:15)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
Error: type 'esp32' is missing virt2phys
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Can anybody tell me why? Because it compile correctly and the monitor output is also correct. Thus, the app works like charm. But I cannot debug it via JTAG :-(
main.c
// FreeRTOS includes
#include "freertos/task.h"
// ESP32 settings
#include "nvs_flash.h"
// Error/debugging library
#include "esp_err.h"
#define LOG_LOCAL_LEVEL ESP_LOG_VERBOSE
#include "esp_log.h"
// Driver
#include "driver/gpio.h"
// Global definitions and variables
static const char* Log_Tag = "main";
#define BLINK_GPIO 14
// Initialize nonvolatile storage
esp_err_t nvs_init(void)
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES)
    return ret;
// Actual task
void blink_task(void *pvParameter)
    /* Configure the IOMUX register for pad BLINK_GPIO (some pads are
       muxed to GPIO on reset already, but some default to other
       functions and need to be switched to GPIO. Consult the
       Technical Reference for a list of pads and their default
       functions.) => make BLINK_GPIO as IO pin.
    gpio_pad_select_gpio(BLINK_GPIO);
    // Set the GPIO as a push/pull output
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
    while (1)
        vTaskDelay(500 / portTICK_RATE_MS);
        ESP_LOGD(Log_Tag, "Blink");
void app_main()
    // Init parts on PCB
    ESP_ERROR_CHECK(nvs_init());
    // attach blink_task to a CPU core.
    xTaskCreate(&blink_task, "blink_task", configMINIMAL_STACK_SIZE, NULL, 5, NULL);
Actually I just added the nvs part. Does anybody can get it to work?
Re: JTAG debugging is not working: Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Postby Sprite » Fri Jan 31, 2020 12:26 pm
Perhaps you're using GPIO12-15 for something else? If you reconfigure those, jtag doesn't work anymore.
ice.bob
Postby ice.bob » Sun Feb 02, 2020 10:08 am
How do I reconfigure them? As I sated before. The normal blink example works perfectly in terms of JTAG debugging. But my code (see first post) cannot be debugged via JTAG at all. Did I reconfigure the pins 12-15 without knowing it?
Postby Sprite » Mon Feb 03, 2020 9:40 am
So yes, you do.
Users browsing this forum: Barkrowler, Perplexity-User, PerplexityBot, Qwantbot, Semrush [Bot] and 4 guests
