ESP-IDF vs ESP-MDF
Gardin
ESP-IDF vs ESP-MDF
Postby Gardin » Wed Feb 05, 2020 2:20 pm
So I started to study esp wifi mesh capabilities and found that there is an specific idf called ESP-MDF to build mesh applications.
What are the main differences between esp-idf and esp-mdf?
I know that esp-mdf is based on top of the esp-idf v3.2.2-42-g4a9f33944 but why not use an newer version of esp-idf?
Isn't it possible to build mesh applications with the bleeding version of esp-idf since there is an example folder for that?
For those wondering why I just don't use the older version of esp-idf that comes with esp-mdf is it because there are some new timers api that are not available in those...
mpetersen
Re: ESP-IDF vs ESP-MDF
Postby mpetersen » Wed Feb 26, 2020 5:44 pm
@Gardin,
Have you learned anything since this posting?
I am wondering the same thing as I consider an ESP32-based Mesh application.
Out of curiosity which platform have you chosen to use for your Mesh eval?
I'm looking at the devKit-C as well as the M5Stack (a well integrated ESP32-based platform - in a box).
Thanks,
Mike
Gardin
Postby Gardin » Sat Mar 07, 2020 4:55 pm
Hi Mike,
I did not studied/learn nothing theoretical about these. But due to the presence of the examples and the name of the framework, using esp-mdf was the obvious choice. (But I'm still curious about the differences, just didn't had the time play around...)
As the platform I'm using a common DevKit-C development board.
RichPiano
Postby RichPiano » Sat May 01, 2021 7:22 am
Even though this question is one year old, I have exactly the same question as OP. Did you two learn something new already? I'm having trouble getting esp-mdf to compile, probably because I'm using the master branch of esp-idf. But I don't even know if its worth the trouble downgrading?
Would be nice if an ESP official could say something about it.
mpetersen
Postby mpetersen » Mon May 03, 2021 3:55 pm
I second that comment, "would be nice to have an official response" and/or build-tip for sample mesh application.
Gardin
Postby Gardin » Mon Jan 03, 2022 11:08 am
Hello guys, I did not advance in the studies about ESP-MDF.
For those who are asking the same question I think that a good solution would be to test both ESP-IDF and ESP-MDF to check the one that better suits your project.
Cheers,
Gabriel Gardin.
