Hi, For example let's says if I'm looking at height measurements which says it has a resolution in 0.01 meters, but I want 0.001 meter
https://www.bluetooth.com/wp-content/up ... height.xml
What to do if resolution in GATT not high enough?
SteaLTH_INSteaD
Re: What to do if resolution in GATT not high enough?
Maybe you can use non standard/SIG characteristic and send float value with resolution for C standard float?
IIRC you can also use descriptors to describe value in characteristic, with exponential number etc.
Users browsing this forum: Amazon [Bot], Bing [Bot], PerplexityBot and 0 guests
