Filling pipeline with software generate sine wave
colinives
Postby colinives » Thu Mar 05, 2020 3:37 pm
Hi there,
I'm looking at as many examples I can but can't find the trick. My application needs to provide users with alternating tones in each ear via bluetooth. I think I've sorted the A2DP part with audio files but need to create tones 'on the fly' with varying frequencies which I plan to create with is DDS sine wave generator. I expect to feed a ring buffer with generated stereo samples assuming downstream decoding at 44100 16bits/sample but don't know how to feed the input stream.
Any pointers gratefully received.
Re: Filling pipeline with software generate sine wave
Postby Sprite » Fri Mar 06, 2020 8:44 am
You could modify this example: https://github.com/espressif/esp-idf/tr ... 2dp_source
The audio is generated in this function, so you could just replace that by a read from a queue or ring buffer. Have another task push the sine wave data into this queue/ringbuffer and you're done.
colinives
Postby colinives » Sat Mar 07, 2020 8:19 pm
Thank you so much for your reply,
I guess I missed it as it doesn’t use a pipeline/stream.
Can I assume that the format is:
Sample Rate: 44100
Data size: 16 bits
Format: L-R. 16 bit little-endian?
Thank you again.
Colin
Postby Sprite » Mon Mar 09, 2020 9:56 am
From the existing function, it seems the samples are 16-bit little endian, but I'm not familiar enough with that code to tell you more about the other parameters, sorry.
colinives
Postby colinives » Tue Mar 10, 2020 10:33 am
Thank you.
I can confirm that I have success delivering various tones to standard A2Dp headset at a sample rate of 44100.
The big problem now is that the after 110 seconds from connecting the A2DP disconnects - then reconnects for another 110 seconds and repeats. I have looked around the code and cannot find any built-in time limit lined to the a2dp source example. Is there a limit built in somewhere for the example code?
Thank you.
julienD
Postby julienD » Sun Feb 05, 2023 5:08 pm
Did you find some solution to this timeout?
Julien
Users browsing this forum: Amazon [Bot] and 4 guests
