Static IP address using esp-netif
Foxtrot813
Postby Foxtrot813 » Wed Mar 11, 2020 11:39 pm
Hi , I've been trying to make the ESP32 IP address static (ie. 192.168.15.12), but I can't make sense of the documentation.
The getting started wifi station example unfortunately uses DHCP...
I think I should use this function
esp_err_t esp_netif_set_ip_info(esp_netif_t *esp_netif, const esp_netif_ip_info_t *ip_info);
below the
esp_netif_create_default_wifi_sta()
but the ESP-IDF Programming Guide isn't clear on how should I implement neither esp_netif nor ip_info. I'm not even sure if this function alone would make the IP static.
Any help, please? Thanks!
PeterR
Re: Static IP address using esp-netif
Postby PeterR » Thu Mar 12, 2020 12:37 am
Not entirely sure what you mean. You want a static IP address on a station? Don't you want the station to be a DHCP client?
Anyway the documentation is not easy to understand.
Have a look at the difference between:
ESP_NETIF_DEFAULT_ETH();
and the wifi AP default initialiser & in particular .flags. .flags determines DHCP, static, auto etc.
So create a const structure close to the ESP_NETIF_DEFAULT_ETH settings (which is DHCP client) before you:
   esp_netif_config_t cfg = MY_NETIF;
    eth_netif = esp_netif_new(&cfg);
Sorry not to be more explicit but short on time.
Foxtrot813
Postby Foxtrot813 » Thu Mar 12, 2020 1:22 am
Sorry, I mean I want to ESP32 have a fixed IP address in station mode.
I'm developing an Android application to communicate with the ESP32 with TCP sockets, thus I need to know the ESP32 IP address to establish a connection.
I remember that with ESP8266 and Arduino you could achieve this:
IPAddress ip(192, 168, 15, 11);
IPAddress gateway(192, 168, 15, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.begin(ssid, password);
WiFi.config(ip, gateway, subnet);
So I'm trying to do a similar thing with ESP32 and IDF, but seems way too hard to figure out.
Foxtrot813
Postby Foxtrot813 » Thu Mar 12, 2020 9:34 am
Ok, now I got it working!
I've done this
 esp_netif_t *my_sta = esp_netif_create_default_wifi_sta();
    esp_netif_dhcpc_stop(my_sta);
    esp_netif_ip_info_t ip_info;
    IP4_ADDR(&ip_info.ip, 192, 168, 15, 22);
   	IP4_ADDR(&ip_info.gw, 192, 168, 15, 1);
   	IP4_ADDR(&ip_info.netmask, 255, 255, 255, 0);
    esp_netif_set_ip_info(my_sta, &ip_info);
I'll paste the full initialization code below, hope it helps someone (the original code was generated with the getting started wifi station)
void wifi_init_sta(void)
    s_wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .password = EXAMPLE_ESP_WIFI_PASS
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
            WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
            pdFALSE,
            pdFALSE,
            portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
                 EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
        ESP_LOGE(TAG, "UNEXPECTED EVENT");
    ESP_ERROR_CHECK(esp_event_handler_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler));
    ESP_ERROR_CHECK(esp_event_handler_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler));
    vEventGroupDelete(s_wifi_event_group);
PeterR
Postby PeterR » Thu Mar 12, 2020 10:45 am
That works as well. I forgot that .flags is a capability description and so you can simply stop DHCP.
ESP has mDNS which you can use to tell others about your IP address. This would allow you to remain a DHCP client.
sja2c2a
Postby sja2c2a » Thu Dec 09, 2021 8:41 am
:D 感谢
1076934228
Postby 1076934228 » Tue Mar 15, 2022 2:16 pm
THANK YOU!This post solved my problem. :lol:
calogero
Postby calogero » Fri Mar 03, 2023 7:08 pm
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "sdkconfig.h"
#include "esp_log.h"
#include "esp_err.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "nvs_flash.h"
#include <netdb.h>
static const char *TAG = "wifi";
wifi_config_t wifi_sta_config;
wifi_config_t wifi_ap_config;
static void wifi_sta_event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data) {
    if (event_base == WIFI_EVENT) {
        switch (event_id) {
            case WIFI_EVENT_STA_START:
                //ESP_LOGI(TAG, "WIFI_EVENT_STA_START");
                esp_wifi_connect();
            case WIFI_EVENT_STA_DISCONNECTED:
                //ESP_LOGI(TAG, "WIFI_EVENT_STA_DISCONNECTED");
                esp_wifi_connect();
    else if (event_base == IP_EVENT) {
        switch (event_id) {
            case IP_EVENT_STA_GOT_IP: {
                ip_event_got_ip_t* event = event_data;
                ESP_LOGI(TAG, "Station connected with IP: "IPSTR", GW: "IPSTR", Mask: "IPSTR".",
                    IP2STR(&event->ip_info.ip),
                    IP2STR(&event->ip_info.gw),
                    IP2STR(&event->ip_info.netmask));
static void wifi_ap_event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data) {
    switch (event_id) {
        case IP_EVENT_AP_STAIPASSIGNED: {
            ip_event_ap_staipassigned_t* event = event_data;
            ESP_LOGI(TAG, "SoftAP client connected with IP: "IPSTR".",
                IP2STR(&event->ip));
void WIFI_INIT() {
    // NVS: Required by WiFi Driver
    ESP_ERROR_CHECK(ret);
void AP_INIT_IP(char *ssid, char *password, char *ip, char *gw, char *nmask) {
    esp_netif_t *esp_netif_ap = esp_netif_create_default_wifi_ap();
    esp_netif_ip_info_t IP_settings_ap;
    IP_settings_ap.ip.addr=ipaddr_addr(ip);
    IP_settings_ap.netmask.addr=ipaddr_addr(nmask);
    IP_settings_ap.gw.addr=ipaddr_addr(gw);
    esp_netif_dhcps_stop(esp_netif_ap);
    esp_netif_set_ip_info(esp_netif_ap, &IP_settings_ap);
    esp_netif_dhcps_start(esp_netif_ap);
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT, IP_EVENT_AP_STAIPASSIGNED, &wifi_ap_event_handler, NULL, NULL));
    strcpy((char *)wifi_ap_config.ap.ssid, ssid);
    strcpy((char *)wifi_ap_config.ap.password, password);
    wifi_ap_config.ap.authmode = WIFI_AUTH_WPA2_PSK;
    wifi_ap_config.ap.max_connection = 4;
void AP_INIT(char *ssid, char *password) {
void STA_INIT_IP(char *ssid, char *password, char *ip, char *gw, char *nmask) {
    esp_netif_t *esp_netif_sta = esp_netif_create_default_wifi_sta();
    esp_err_t ret = esp_netif_dhcpc_stop(esp_netif_sta);
    if(ret == ESP_OK) ESP_LOGI(TAG, "esp_netif_dhcpc_stop OK");
    else ESP_LOGI(TAG, "esp_netif_dhcpc_stop ERROR");
    esp_netif_ip_info_t IP_settings_sta;
    IP_settings_sta.ip.addr=ipaddr_addr(ip);
    IP_settings_sta.netmask.addr=ipaddr_addr(nmask);
    IP_settings_sta.gw.addr=ipaddr_addr(gw);
    esp_netif_set_ip_info(esp_netif_sta, &IP_settings_sta);
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_sta_event_handler, NULL, NULL));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_sta_event_handler, NULL, NULL));
    strcpy((char *)wifi_sta_config.sta.ssid, ssid);
    strcpy((char *)wifi_sta_config.sta.password, password);
void STA_INIT(char *ssid, char *password) {
void WIFI_START(wifi_mode_t mode) {
    ESP_ERROR_CHECK(esp_wifi_set_mode(mode));
    if (mode==WIFI_MODE_APSTA || mode==WIFI_MODE_STA) ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_sta_config));
    if (mode==WIFI_MODE_APSTA || mode==WIFI_MODE_AP) ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_ap_config));
    ESP_ERROR_CHECK(esp_wifi_start());
void app_main(void) {
    WIFI_INIT();
    STA_INIT_IP("wifi_ssid","password","192.168.1.19","192.168.1.1","255.255.255.0");
    AP_INIT_IP("esp32_AP","password","192.168.254.1","192.168.254.1","255.255.255.0");
    WIFI_START(WIFI_MODE_APSTA); // WIFI_MODE_APSTA | WIFI_MODE_STA | WIFI_MODE_AP
    WIFI_INIT();
    AP_INIT("esp32_AP","password");
    WIFI_INIT();
    STA_INIT("wifi_ssid","password");
    WIFI_INIT();
    WIFI_START(WIFI_MODE_STA); // WIFI_MODE_APSTA | WIFI_MODE_STA | WIFI_MODE_AP
    WIFI_INIT();
    AP_INIT("wifi_ssid","password");
    WIFI_START(WIFI_MODE_AP); // WIFI_MODE_APSTA | WIFI_MODE_STA | WIFI_MODE_AP
Users browsing this forum: markkuk and 1 guest
