[IDFGH-2941] ELF file is in wrong place after running cmake --build .
skibbidy
Postby skibbidy » Thu Mar 19, 2020 5:32 am
I am using the idf as a lib in my cmake project (idf.cmake). It seems the majority of the build runs through, but during the end of `cmake --build .` I get an error my ELF cannot be found, even when it exists down build/main/MYPROJECT.ELF. It appears either my ELF is in the wrong place or what generates the build/main/CMakeFiles/gen_project_binary.dir/build.make is incorrect.
[100%] Generating binary image from built executable
esptool.py v2.8
  File "/home/myuser/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 3201, in <module>
    _main()
  File "/home/myuser/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 3194, in _main
    main()
  File "/home/myuser/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 2965, in main
    operation_func(args)
  File "/home/myuser/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 2466, in elf2image
    e = ELFFile(args.input)
  File "/home/myuser/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 1951, in __init__
    with open(self.name, 'rb') as f:
[b]IOError: [Errno 2] No such file or directory: 'MYPROJECT.elf'
[/b]main/CMakeFiles/gen_project_binary.dir/build.make:60: recipe for target '.bin_timestamp' failed
make[2]: *** [.bin_timestamp] Error 1
CMakeFiles/Makefile2:99: recipe for target 'main/CMakeFiles/gen_project_binary.dir/all' failed
make[1]: *** [main/CMakeFiles/gen_project_binary.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
build/main/CMakeFiles/gen_project_binary.dir/build.make looks like this originally
.bin_timestamp: main/MYPROJECT.elf
        @$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --blue --bold --progress-dir=/home/myuser/work/MYPROJECT/build/CMakeFiles --progress-num=$(CMAKE_PROGRESS_1) "Generating binary image from built executable"
[b]        python /home/myuser/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 2MB --elf-sha256-offset 0xb0 -o /home/myuser/work/MYPROJECT/build/MYPROJECT.bin MYPROJECT.elf
[/b]        /usr/bin/cmake -E echo "Generated /home/myuser/work/MYPROJECT/build/MYPROJECT.bin"
        /usr/bin/cmake -E md5sum /home/myuser/work/MYPROJECT/build/MYPROJECT.bin > /home/myuser/work/MYPROJECT/build/.bin_timestamp
but when I change the MYPROJECT.ELF to main/MYPROJECT.ELF at the end of the python call, as below, and run `cmake --build .` it works correctly
python /home/scarlson/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 2MB --elf-sha256-offset 0xb0 -o /home/scarlson/work/SimPill/build/SIMPILL.bin main/SIMPILL.elf
My file structure is:
- components/
--comp1/
---CMakeLisst.txt
---comp1_main.c
-main/
--CMakeLists.txt
--main.c
-build/
sdkconfig
CMakeLists.txt
the top level cmake is simple
CMakeLists.txt:
cmake_minimum_required(VERSION 3.5)
project(MYPROJECT C)
set(elf_file ${CMAKE_PROJECT_NAME}.elf)
set(INCLUDE_DIRS ${CMAKE_HOME_DIRECTORY}/include)
# You could in theory have more than one subdirectory for
# piecemeal builds
add_subdirectory(main)
The Cmake nested in main is
main/CMakeLists.txt:
set(SUPPORTED_TARGETS esp32)
include($ENV{IDF_PATH}/tools/cmake/idf.cmake)
idf_build_component(${CMAKE_HOME_DIRECTORY}/components/comp1)
idf_build_process(esp32
	COMPONENTS esp32 freertos esptool_py comp1
	SDKCONFIG ${CMAKE_BINARY_DIR}/sdkconfig
	BUILD_DIR ${CMAKE_BINARY_DIR})
add_executable(${elf_file} main.c)
target_link_libraries(${elf_file} idf::esp32 idf::freertos idf::spi_flash)
idf_build_executable(${elf_file})
set(CMAKE_EXPORT_COMPILE_COMMANDS 1)
to build I run this in the build directory:
cmake .. -DCMAKE_TOOLCHAIN_FILE=$IDF_PATH/tools/cmake/toolchain-esp32.cmake -DTARGET=esp32 -G 'Unix Makefiles'
cmake --build .
Also my build directory looks like this, note the MYPROJECT.elf at in the main/ dir, not in the top level build dir
myuser@ubuntu:~/work/MYPROJECT/build$ ls main/
bootloader-prefix  CMakeFiles  cmake_install.cmake  config.env  Makefile  mconf-idf-prefix  MYPROJECT.elf
bootloader      CMakeFiles           compile_commands.json  esp-idf         flash_bootloader_args  flash_partition_table_args  kconfig_bin      ldgen_libraries.in  Makefile         sdkconfig
CMakeCache.txt  cmake_install.cmake  config                 flash_app_args  flasher_args.json      flash_project_args          ldgen_libraries  main                partition_table
Why might the build.make be incorrectly generated or my ELF placed in the wrong place?
TIA
chegewara
Re: ELF file is in wrong place after running cmake --build .
Postby chegewara » Thu Mar 19, 2020 5:47 pm
Usually elf file ends up in build folder next to bin file, and as you can see there is no path to main in this command:
Thats why you need to do this if your elf file is in main subfolder:
skibbidy
Postby skibbidy » Thu Mar 19, 2020 8:02 pm
I understand what you are saying, but when I change it to
set(elf_file main/${CMAKE_PROJECT_NAME}.elf)
it complains the tart name is invalid
CMake Error at main/CMakeLists.txt:48 (add_executable):
  The target name "main/SIMPILL.elf" is reserved or not valid for certain
  CMake features, such as generator expressions, and may result in undefined
  behavior.
is it not possible to have a main directory (or src, whatever)? I thought it was
chegewara
Postby chegewara » Sat Mar 21, 2020 9:05 pm
I think that @Angus can help more in here.
skibbidy
Postby skibbidy » Sun Mar 22, 2020 7:47 pm
@chegewara Thanks for the help.
For now I have a workaround at least (move main.c). However this does not follow normal cmake repo structure, I would like to keep this project consistent since the esp32 is not my only target board...
@Angus Any help is appreciated.
Alvin
Re: [IDFGH-2941] ELF file is in wrong place after running cmake --build .
Postby Alvin » Mon Mar 23, 2020 3:44 am
Moderator's note: edit the topic title for issue tracking, thanks.
renz
Postby renz » Mon Mar 30, 2020 1:08 am
It's not that the ELF file is in the wrong place, but rather the process that creates a bin out of the elf file wrongly assumes it to be in the top level build directory. Can you create an issue for this in the ESP-IDF GitHub repo so the fix can be tracked?
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot], Qwantbot and 7 guests
