According to Figure 8 (Recommended PCB Land Pattern of ESP32-WROOM-32D) of the ESP32-WROOM-32D datasheet, the ground plane on the bottom of the module consists of nine SMD pads that are each 1.33 mm x 1.33 mm in size. However, Figure 5 (ESP32-WROOM-32D & ESP32-WROOM-32U Peripheral Schematics) of the same datasheet shows a schematic with a single pin (P_GND). This results in a mismatch between my PCB design (9 pads) and schematic (1 pin), which cannot be connected.
Please let me know the correct PCB and schematic configuration for this situation. Thanks in advance.
Regards, Mark
ESP32-WROOM-32D Ground Plane PCB vs. Schematic
Re: ESP32-WROOM-32D Ground Plane PCB vs. Schematic
The ground pad on the module is a single pad but the recommended ground plane on the host pcb is the divided pad with vias. I think this is for thermal considerations and to prevent solder wicking or pooling.
Additionally, at least most PCB programs I used see pads that have the same pin number as one pad; perhaps you can use that.
I am using Eagle. That should be doable. I will give it a go. Thanks for your time and assistance.Additionally, at least most PCB programs I used see pads that have the same pin number as one pad; perhaps you can use that.
Regards, Mark
Users browsing this forum: Perplexity-User, PetalBot, Semrush [Bot], YisouSpider and 5 guests
