E (10062) esp_ota_ops: OTA image has invalid magic byte (expected 0xE9, saw 0x45)
sreedhar
Postby sreedhar » Sun Mar 22, 2020 10:43 pm
HI Guys.
I am getting below error while executing simple OTA. Please help.
I (5772) simple_ota_example: Starting OTA example
I (7482) esp_https_ota: Starting OTA...
I (7482) esp_https_ota: Writing to partition subtype 16 at offset 0x110000
E (10062) esp_https_ota: Error: esp_ota_write failed! err=0x5379
E (10072) simple_ota_example: Firmware upgrade failed
I am using IDF V4. on ESP32 WROOM 32 .
Regards,
Sreedhar
Re: E (10062) esp_ota_ops: OTA image has invalid magic byte (expected 0xE9, saw 0x45)
Postby Sprite » Mon Mar 23, 2020 5:41 pm
0x45 is an ascii character ('E'). Are you sure that whatever you set as the firmware update endpoint actually serves a valid OTA image?
sreedhar
Postby sreedhar » Mon Mar 23, 2020 6:26 pm
Hi ESP_Sprite,
I copied over the bin file from build folder to endpoint folder. I am using the same example file as new firmware with just an additional printf statement.
Regards,
Sreedhar
chegewara
Postby chegewara » Mon Mar 23, 2020 9:20 pm
The point its it can be redirecting link with http code 30x, it can be any text returned etc.
Usually issue was when downloaded content was some html with "<" (0x3C). In your case its very unusual, because its "E" (0x45).
sreedhar
Postby sreedhar » Sat Mar 28, 2020 11:02 pm
Could anyone guide me how to implement " simple_ota_example" properly.
Regards,
Sreedhar
Users browsing this forum: Barkrowler, Bing [Bot] and 1 guest
