Hi there,
i wonder whether the interface motor PWM which is mentioned in esp_wroom32_datasheet v1.4 on page 9 is already supported. If so, is there any example of using the api and the provided timers?
Thanks for your answers in advance.
Best regards
DL88AI88
interface motor pwm - already supported and provided example?
Re: interface motor pwm - already supported and provided example?
Hi there,
is there any example or api description of (datasheet v1.5 page 10)
PWM0_OUT0~2 (shouldn't it be PWM0_OUT_IN0~2 ?)
PWM1_OUT_IN0~2
PWM0_FLT_IN0~2
PWM1_FLT_IN0~2
PWM0_CAP_IN0~2
PWM1_CAP_IN0~2
PWM0_SYNC_IN0~2
PWM1_SYNC_IN0~2
It is only said that AnyGPIOs *
Three channels of 16-bit timers generate PWM waveforms;
each has a pair of output signals.
Three fault detection signals.
Three event capture signals.
Three sync signals.
But how do they work together?
best regards
DL88AI888
PWM1_OUT_IN0~2
PWM0_FLT_IN0~2
PWM1_FLT_IN0~2
PWM0_CAP_IN0~2
PWM1_CAP_IN0~2
PWM0_SYNC_IN0~2
PWM1_SYNC_IN0~2
Three sync signals.
best regards
DL88AI888
There are no drivers/docs for epwm/mpwm yet
but you can try ledc like nkolban shows
Hi there,
thanks for the hints.
Actually, I saw Neil's video about ledc pwm which is quite informative (as well as Neil's book is).
I read through the esp8266 reference manual as well for a motor pwm library.
Is there a special reason why this interface is not provided yet?
For me and many other potential customers motor pwm would be a great step forward for the esp32 of being a fully functional embedded device.
Maybe I can place some wishes for the library here
one should define settings like
pwmmotor_frequency_khz (kiloHertz)
pwmmotor_frequency_hz (Hertz)
pwmmotor_period_s (seconds)
pwmmotor_period_ms (milliseconds)
pwmmotor_period_us (microseconds)
pwmmotor_pulsewidth_s (seconds)
pwmmotor_pulsewidth_ms (milliseconds)
pwmmotor_pulsewidth_us (microseconds)
This would be nice.
Any chance that we see an interface soon?
Best regards
DL88AI88
This would be nice.
Best regards
DL88AI88
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 1 guest
