esp-idf-tools-setup-2.3.exe安装出现错误
kaisey
Postby kaisey » Wed Mar 25, 2020 1:24 am
我从官网下了esp-idf-tools-setup-2.3.exe安装出现错误
File "D:\.espressif\idf_tools_fallback.py", line 1487, in <module>
main(sys.argv[1:])
File "D:\.espressif\idf_tools_fallback.py", line 1483, in main
action_func(args)
File "D:\.espressif\idf_tools_fallback.py", line 1199, in action_install_python_env
subprocess.check_call([sys.executable, '-m', 'pip', 'install', '--user', 'virtualenv'],
File "C:\Users\Administrator\AppData\Local\Programs\Python\Python38\lib\subprocess.py", line 364, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['C:\\Users\\Administrator\\AppData\\Local\\Programs\\Python\\Python38\\python.exe', '-m', 'pip', 'install', '--user', 'virtualenv']' returned non-zero exit status 2.
2020-03-25 09:15:54.007 --------
2020-03-25 09:15:54.007 Message box (OK):
Installation has failed with exit code 1
2020-03-25 09:22:10.931 User chose OK.
2020-03-25 09:22:10.962 Message box (Yes/No):
Installation log has been created, it may contain more information about the problem.
Display the installation log now?
2020-03-25 09:22:16.477 User chose Yes.
2020-03-25 09:22:16.571 CurStepChanged raised an exception.
ESP_igrr
Re: esp-idf-tools-setup-2.3.exe安装出现错误
Postby ESP_igrr » Wed Mar 25, 2020 6:09 am
If you have downloaded IDF v4.0 release version, please do "git fetch origin release/v4.0" and "git checkout release/v4.0" to update to the latest IDF release/v4.0 release version. This issue has been fixed in the following commit: https://github.com/espressif/esp-idf/co ... f2373cf2d0
kaisey
Postby kaisey » Sat Apr 04, 2020 1:04 am
按您给的方法还是不行,好像是PYTHON的环境变量有问题,但是我PYTHON都卸载了,也重新手动安装了
2020-04-04 08:51:33.536 Log opened. (Time zone: UTC+08:00)
2020-04-04 08:51:33.551 Setup version: Inno Setup version 6.0.2 (u)
2020-04-04 08:51:33.551 Original Setup EXE: C:\Users\ASUS\Desktop\esp-idf-tools-setup-2.3.exe
2020-04-04 08:51:33.551 Setup command line: /SL5="$90318,350580993,721408,C:\Users\ASUS\Desktop\esp-idf-tools-setup-2.3.exe"
2020-04-04 08:51:33.551 Windows version: 6.1.7601 SP1 (NT platform: Yes)
2020-04-04 08:51:33.551 64-bit Windows: Yes
2020-04-04 08:51:33.551 Processor architecture: x64
2020-04-04 08:51:33.551 User privileges: None
2020-04-04 08:51:33.551 Administrative install mode: No
2020-04-04 08:51:33.551 Install mode root key: HKEY_CURRENT_USER
2020-04-04 08:51:33.551 64-bit install mode: Yes
2020-04-04 08:51:33.551 Created temporary directory: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp
2020-04-04 08:51:33.567 -- DLL function import --
2020-04-04 08:51:33.567 Function name: idpAddFile
2020-04-04 08:51:33.567 DLL name: files:idp.dll
2020-04-04 08:51:33.567 Extracting temporary file: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\idp.dll
2020-04-04 08:51:33.567 Dest DLL name: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\idp.dll
2020-04-04 08:51:33.567 Importing the DLL function.
2020-04-04 08:51:33.629 Successfully imported the DLL function. Delay loaded? No
2020-04-04 08:51:33.629 -- DLL function import --
2020-04-04 08:51:33.629 Function name: idpAddFileComp
2020-04-04 08:51:33.629 DLL name: files:idp.dll
2020-04-04 08:51:33.629 Dest DLL name: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\idp.dll
2020-04-04 08:51:33.629 Importing the DLL function.
2020-04-04 08:51:33.629 Function name: idpAddMirror
2020-04-04 08:51:33.629 Function name: idpAddFtpDir
2020-04-04 08:51:33.629 Function name: idpAddFtpDirComp
2020-04-04 08:51:33.629 Function name: idpClearFiles
2020-04-04 08:51:33.629 Function name: idpFilesCount
2020-04-04 08:51:33.629 Function name: idpFtpDirsCount
2020-04-04 08:51:33.629 Function name: idpFileDownloaded
2020-04-04 08:51:33.629 Function name: idpFilesDownloaded
2020-04-04 08:51:33.629 Function name: idpDownloadFile
2020-04-04 08:51:33.629 Function name: idpDownloadFiles
2020-04-04 08:51:33.629 Function name: idpDownloadFilesComp
2020-04-04 08:51:33.629 Function name: idpDownloadFilesCompUi
2020-04-04 08:51:33.629 Function name: idpStartDownload
2020-04-04 08:51:33.629 Function name: idpStopDownload
2020-04-04 08:51:33.629 Function name: idpSetLogin
2020-04-04 08:51:33.629 Function name: idpSetProxyMode
2020-04-04 08:51:33.629 Function name: idpSetProxyName
2020-04-04 08:51:33.629 Function name: idpSetProxyLogin
2020-04-04 08:51:33.629 Function name: idpConnectControl
2020-04-04 08:51:33.629 Function name: idpAddMessage
2020-04-04 08:51:33.629 Function name: idpSetInternalOption
2020-04-04 08:51:33.629 Function name: idpSetDetailedMode
2020-04-04 08:51:33.629 Function name: idpSetComponents
2020-04-04 08:51:33.629 Function name: idpReportError
2020-04-04 08:51:33.629 Function name: idpTrace
2020-04-04 08:51:33.629 Function name: idpAddFileSize
2020-04-04 08:51:33.629 Function name: idpGetFileSize
2020-04-04 08:51:33.629 Function name: idpGetFilesSize
2020-04-04 08:51:33.629 Function name: proc_start
2020-04-04 08:51:33.629 DLL name: files:cmdlinerunner.dll
2020-04-04 08:51:33.629 Extracting temporary file: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\cmdlinerunner.dll
2020-04-04 08:51:33.645 Dest DLL name: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\cmdlinerunner.dll
2020-04-04 08:51:33.645 Importing the DLL function.
2020-04-04 08:51:33.645 Successfully imported the DLL function. Delay loaded? No
2020-04-04 08:51:33.645 -- DLL function import --
2020-04-04 08:51:33.645 Function name: proc_get_exit_code
2020-04-04 08:51:33.645 DLL name: files:cmdlinerunner.dll
2020-04-04 08:51:33.645 Function name: proc_get_output
2020-04-04 08:51:33.645 Function name: proc_end
2020-04-04 08:51:33.645 Function name: SetEnvironmentVariableW
2020-04-04 08:51:33.645 DLL name: kernel32.dll
2020-04-04 08:51:33.645 Dest DLL name: kernel32.dll
2020-04-04 08:51:33.739 Found link in "For more infojects/esp-idf/en/latest/versions.html": "https://docs.espressif.com/projects/esp ... sions.html"
2020-04-04 08:51:36.375 OnPythonPagePrepare
2020-04-04 08:51:36.375 Nothing found in -2147483647\Software\Python
2020-04-04 08:51:36.375 In -2147483646\Software\Python\PythonCore
2020-04-04 08:51:36.375 In -2147483646\Software\Python\PythonCore\3.7
2020-04-04 08:51:36.375 Adding Python version=3.7 name=Python 3.7 (64-bit) executable=C:\Python37\python.exe
2020-04-04 08:51:36.375 In -2147483646\Software\Wow6432Node\Python\PythonCore
2020-04-04 08:51:36.375 In -2147483646\Software\Wow6432Node\Python\PythonCore\2.7
2020-04-04 08:51:36.375 No (Default) key, skipping
2020-04-04 08:51:38.621 OnPythonPageValidate index=0
2020-04-04 08:51:38.621 OnPythonPageValidate: PythonPath=C:\Python37\ PythonExecutablePath=C:\Python37\python.exe
2020-04-04 08:51:38.637 OnGitPagePrepare
2020-04-04 08:51:39.043 Git path: C:\Program Files\Git\cmd\git.exe
2020-04-04 08:51:39.043 Running /C "C:\Program Files\Git\cmd\git.exe" --version >gitver.txt
2020-04-04 08:51:39.277 Git version: 2.15.0.windows.1
2020-04-04 08:51:39.277 Adding Git version=2.15.0.windows.1 name=2.15.0.windows.1 executable=C:\Program Files\Git\cmd\git.exe
2020-04-04 08:51:39.277 Git path: C:\Program Files\Git\bin\git.exe
2020-04-04 08:51:39.277 Running /C "C:\Program Files\Git\bin\git.exe" --version >gitver.txt
2020-04-04 08:51:39.464 Git version: 2.15.0.windows.1
2020-04-04 08:51:39.464 Adding Git version=2.15.0.windows.1 name=2.15.0.windows.1 executable=C:\Program Files\Git\bin\git.exe
2020-04-04 08:51:41.149 OnGitPageValidate index=0
2020-04-04 08:51:41.149 OnIDFPagePrepare
2020-04-04 08:51:42.521 OnIDFPageValidate index=0
2020-04-04 08:51:42.521 OnIDFDownloadPagePrepare
2020-04-04 08:51:43.738 Downloaded https://dl.espressif.com/dl/esp-idf/idf_versions.txt to C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\idf_versions.txt
2020-04-04 08:51:43.738 Versions count: 5
2020-04-04 08:51:43.738 Version 0: v4.0
2020-04-04 08:51:43.738 Version 1: v3.3.1
2020-04-04 08:51:43.738 Version 2: release/v4.0
2020-04-04 08:51:43.738 Version 3: release/v3.3
2020-04-04 08:51:43.738 Version 4: master
2020-04-04 08:51:50.821 OnIDFDownloadPageValidate index=0
2020-04-04 08:51:52.708 Checking PSMODULEPATH for Windows Defender module...
2020-04-04 08:51:52.724 CheckWinDefenderAvailable: NO
2020-04-04 08:51:53.753 Summary message:
Using Python 3.7:
Using Git 2.15.0.windows.1:
Will download ESP-IDF v4.0 into:
e:\esp-idf
IDF tools directory (IDF_TOOLS_PATH):
E:\.espressif
2020-04-04 08:51:54.611 GetIDFZIPFileVersion(v4.0)=v4.0
2020-04-04 08:51:54.611 E:\.espressif\releases\esp-idf-v4.0.zip already exists
2020-04-04 08:51:54.611 Calling RestartManager's RmGetList.
2020-04-04 08:51:54.627 RmGetList finished successfully.
2020-04-04 08:51:54.627 RestartManager found no applications using one of our files.
2020-04-04 08:51:54.627 Starting the installation process.
2020-04-04 08:51:54.627 Directory for uninstall files: E:\.espressif
2020-04-04 08:51:54.705 Will append to existing uninstall log: E:\.espressif\unins000.dat
2020-04-04 08:51:54.721 -- File entry --
2020-04-04 08:51:54.721 Dest filename: E:\.espressif\unins000.exe
2020-04-04 08:51:54.721 Non-default bitness: 32-bit
2020-04-04 08:51:54.721 Time stamp of our file: 2020-04-04 08:51:33.005
2020-04-04 08:51:54.721 Dest file exists.
2020-04-04 08:51:54.721 Time stamp of existing file: 2020-04-04 07:40:29.874
2020-04-04 08:51:54.721 Version of our file: 51.1052.0.0
2020-04-04 08:51:54.721 Version of existing file: 51.1052.0.0
2020-04-04 08:51:54.721 Installing the file.
2020-04-04 08:51:54.721 Leaving temporary file in place for now.
2020-04-04 08:51:54.721 Dest filename: E:\.espressif\idf_tools_fallback.py
2020-04-04 08:51:54.721 Time stamp of our file: 2020-02-11 09:02:54.000
2020-04-04 08:51:54.721 Time stamp of existing file: 2020-02-11 09:02:54.000
2020-04-04 08:51:54.721 Version of our file: (none)
2020-04-04 08:51:54.736 Version of existing file: (none)
2020-04-04 08:51:54.736 Installing the file.
2020-04-04 08:51:54.830 Successfully installed the file.
2020-04-04 08:51:54.830 -- File entry --
2020-04-04 08:51:54.830 Dest filename: E:\.espressif\tools_fallback.json
2020-04-04 08:51:54.830 Time stamp of our file: 2020-02-11 09:02:42.000
2020-04-04 08:51:54.830 Dest file exists.
2020-04-04 08:51:54.830 Time stamp of existing file: 2020-02-11 09:02:42.000
2020-04-04 08:51:54.830 Version of our file: (none)
2020-04-04 08:51:54.845 Version of existing file: (none)
2020-04-04 08:51:54.845 Installing the file.
2020-04-04 08:51:54.845 Successfully installed the file.
2020-04-04 08:51:54.845 -- File entry --
2020-04-04 08:51:54.845 Dest filename: E:\.espressif\idf_cmd_init.bat
2020-04-04 08:51:54.845 Time stamp of our file: 2020-02-11 09:02:42.000
2020-04-04 08:51:54.845 Dest file exists.
2020-04-04 08:51:54.845 Time stamp of existing file: 2020-02-11 09:02:42.000
2020-04-04 08:51:54.845 Version of our file: (none)
2020-04-04 08:51:54.845 Dest filename: E:\.espressif\dist\binutils-esp32s2ulp-win32-2.28.51-esp-20191205.zip
2020-04-04 08:51:54.861 Time stamp of our file: 2020-02-11 17:56:46.000
2020-04-04 08:51:54.861 Dest file exists.
2020-04-04 08:51:54.861 Time stamp of existing file: 2020-02-11 17:56:46.000
2020-04-04 08:51:54.861 Version of our file: (none)
2020-04-04 08:51:54.877 Version of existing file: (none)
2020-04-04 08:51:54.877 Installing the file.
2020-04-04 08:51:55.781 Successfully installed the file.
2020-04-04 08:51:55.781 -- File entry --
2020-04-04 08:51:55.781 Dest filename: E:\.espressif\dist\binutils-esp32ulp-win32-2.28.51-esp-20191205.zip
2020-04-04 08:51:55.781 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:51:55.781 Dest file exists.
2020-04-04 08:51:55.781 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:51:55.781 Version of our file: (none)
2020-04-04 08:51:55.797 Version of existing file: (none)
2020-04-04 08:51:55.797 Installing the file.
2020-04-04 08:51:56.733 Successfully installed the file.
2020-04-04 08:51:56.733 -- File entry --
2020-04-04 08:51:56.733 Dest filename: E:\.espressif\dist\binutils-esp32ulp-win32-2.28.51-esp32ulp-20180809.zip
2020-04-04 08:51:56.733 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:51:56.733 Dest file exists.
2020-04-04 08:51:56.733 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:51:56.733 Version of our file: (none)
2020-04-04 08:51:56.749 Version of existing file: (none)
2020-04-04 08:51:56.749 Installing the file.
2020-04-04 08:51:57.544 Successfully installed the file.
2020-04-04 08:51:57.544 -- File entry --
2020-04-04 08:51:57.544 Dest filename: E:\.espressif\dist\ccache-3.7-w64.zip
2020-04-04 08:51:57.544 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:51:57.544 Dest file exists.
2020-04-04 08:51:57.544 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:51:57.544 Version of our file: (none)
2020-04-04 08:51:57.560 Version of existing file: (none)
2020-04-04 08:51:57.560 Installing the file.
2020-04-04 08:51:57.591 Successfully installed the file.
2020-04-04 08:51:57.591 -- File entry --
2020-04-04 08:51:57.591 Dest filename: E:\.espressif\dist\cmake-3.13.4-win64-x64.zip
2020-04-04 08:51:57.591 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:51:57.591 Dest file exists.
2020-04-04 08:51:57.591 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:51:57.591 Version of our file: (none)
2020-04-04 08:51:57.653 Version of existing file: (none)
2020-04-04 08:51:57.653 Installing the file.
2020-04-04 08:52:00.368 Successfully installed the file.
2020-04-04 08:52:00.368 -- File entry --
2020-04-04 08:52:00.368 Dest filename: E:\.espressif\dist\idf-exe-v1.0.1.zip
2020-04-04 08:52:00.368 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.368 Dest file exists.
2020-04-04 08:52:00.368 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.368 Version of our file: (none)
2020-04-04 08:52:00.399 Version of existing file: (none)
2020-04-04 08:52:00.399 Installing the file.
2020-04-04 08:52:00.399 Successfully installed the file.
2020-04-04 08:52:00.399 -- File entry --
2020-04-04 08:52:00.399 Dest filename: E:\.espressif\dist\mconf-v4.6.0.0-idf-20190628-win32.zip
2020-04-04 08:52:00.399 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.399 Dest file exists.
2020-04-04 08:52:00.399 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.399 Version of our file: (none)
2020-04-04 08:52:00.415 Version of existing file: (none)
2020-04-04 08:52:00.415 Installing the file.
2020-04-04 08:52:00.508 Successfully installed the file.
2020-04-04 08:52:00.508 -- File entry --
2020-04-04 08:52:00.508 Dest filename: E:\.espressif\dist\ninja-1.9.0-win64.zip
2020-04-04 08:52:00.508 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.508 Dest file exists.
2020-04-04 08:52:00.508 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.508 Version of our file: (none)
2020-04-04 08:52:00.508 Version of existing file: (none)
2020-04-04 08:52:00.508 Installing the file.
2020-04-04 08:52:00.539 Successfully installed the file.
2020-04-04 08:52:00.539 -- File entry --
2020-04-04 08:52:00.539 Dest filename: E:\.espressif\dist\openocd-esp32-win32-0.10.0-esp32-20190313.zip
2020-04-04 08:52:00.539 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.539 Dest file exists.
2020-04-04 08:52:00.539 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.539 Version of our file: (none)
2020-04-04 08:52:00.571 Version of existing file: (none)
2020-04-04 08:52:00.571 Installing the file.
2020-04-04 08:52:00.773 Successfully installed the file.
2020-04-04 08:52:00.773 -- File entry --
2020-04-04 08:52:00.773 Dest filename: E:\.espressif\dist\openocd-esp32-win32-0.10.0-esp32-20191114.zip
2020-04-04 08:52:00.773 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.773 Dest file exists.
2020-04-04 08:52:00.773 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.773 Version of our file: (none)
2020-04-04 08:52:00.789 Version of existing file: (none)
2020-04-04 08:52:00.789 Installing the file.
2020-04-04 08:52:00.945 Successfully installed the file.
2020-04-04 08:52:00.945 -- File entry --
2020-04-04 08:52:00.945 Dest filename: E:\.espressif\dist\placeholder
2020-04-04 08:52:00.945 Time stamp of our file: 2020-02-10 20:13:36.000
2020-04-04 08:52:00.945 Dest file exists.
2020-04-04 08:52:00.945 Time stamp of existing file: 2020-02-10 20:13:36.000
2020-04-04 08:52:00.945 Version of our file: (none)
2020-04-04 08:52:00.945 Version of existing file: (none)
2020-04-04 08:52:00.945 Installing the file.
2020-04-04 08:52:00.945 Dest filename: E:\.espressif\dist\xtensa-esp32-elf-gcc8_2_0-esp-2019r2-win32.zip
2020-04-04 08:52:00.945 Time stamp of our file: 2020-02-11 17:56:48.000
2020-04-04 08:52:00.945 Time stamp of existing file: 2020-02-11 17:56:48.000
2020-04-04 08:52:01.007 Version of existing file: (none)
2020-04-04 08:52:01.007 Installing the file.
2020-04-04 08:52:09.884 Successfully installed the file.
2020-04-04 08:52:09.884 -- File entry --
2020-04-04 08:52:09.884 Dest filename: E:\.espressif\dist\xtensa-esp32-elf-win32-1.22.0-80-g6c4433a-5.2.0.zip
2020-04-04 08:52:09.884 Time stamp of our file: 2020-02-11 17:56:50.000
2020-04-04 08:52:09.884 Dest file exists.
2020-04-04 08:52:09.884 Time stamp of existing file: 2020-02-11 17:56:50.000
2020-04-04 08:52:09.884 Version of our file: (none)
2020-04-04 08:52:09.931 Version of existing file: (none)
2020-04-04 08:52:09.931 Installing the file.
2020-04-04 08:52:20.726 Successfully installed the file.
2020-04-04 08:52:20.726 -- File entry --
2020-04-04 08:52:20.726 Dest filename: E:\.espressif\dist\xtensa-esp32s2-elf-gcc8_2_0-esp-2019r2-win32.zip
2020-04-04 08:52:20.726 Time stamp of our file: 2020-02-11 17:56:50.000
2020-04-04 08:52:20.726 Dest file exists.
2020-04-04 08:52:20.726 Time stamp of existing file: 2020-02-11 17:56:50.000
2020-04-04 08:52:20.726 Version of our file: (none)
2020-04-04 08:52:20.757 Version of existing file: (none)
2020-04-04 08:52:20.757 Installing the file.
2020-04-04 08:52:30.429 Successfully installed the file.
2020-04-04 08:52:30.429 -- File entry --
2020-04-04 08:52:30.429 Dest filename: E:\.espressif\dist\tools_WD_excl.ps1
2020-04-04 08:52:30.429 Time stamp of our file: 2020-02-11 09:02:42.000
2020-04-04 08:52:30.429 Dest file exists.
2020-04-04 08:52:30.429 Time stamp of existing file: 2020-02-11 09:02:42.000
2020-04-04 08:52:30.429 Version of our file: (none)
2020-04-04 08:52:30.570 Version of existing file: (none)
2020-04-04 08:52:30.570 Installing the file.
2020-04-04 08:52:30.570 Successfully installed the file.
2020-04-04 08:52:30.570 -- File entry --
2020-04-04 08:52:30.570 Dest filename: E:\.espressif\dist\tools_WD_clean.ps1
2020-04-04 08:52:30.570 Time stamp of our file: 2020-02-11 09:02:42.000
2020-04-04 08:52:30.570 Dest file exists.
2020-04-04 08:52:30.570 Time stamp of existing file: 2020-02-11 09:02:42.000
2020-04-04 08:52:30.570 Version of our file: (none)
2020-04-04 08:52:30.616 Version of existing file: (none)
2020-04-04 08:52:30.616 Installing the file.
2020-04-04 08:52:30.616 Successfully installed the file.
2020-04-04 08:52:30.616 -- Registry entry --
2020-04-04 08:52:30.616 Key: HKEY_CURRENT_USER\Environment
2020-04-04 08:52:30.616 Value name: IDF_TOOLS_PATH
2020-04-04 08:52:30.616 Creating or opening the key.
2020-04-04 08:52:30.616 Deleting the value.
2020-04-04 08:52:30.616 Creating or setting the value.
2020-04-04 08:52:30.616 Successfully created or set the value.
2020-04-04 08:52:30.616 Saving uninstall information.
2020-04-04 08:52:30.616 Renaming uninstaller.
2020-04-04 08:52:30.616 Deleting uninstall key left over from previous non administrative install.
2020-04-04 08:52:30.616 Creating new uninstall key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9E068D99-5C4B-4E5F-96A3-B17CF291E6BD}_is1
2020-04-04 08:52:30.632 Writing uninstall key values.
2020-04-04 08:52:30.632 Detected previous administrative 64-bit install? No
2020-04-04 08:52:30.632 Detected previous administrative 32-bit install? No
2020-04-04 08:52:30.804 Installation process succeeded.
2020-04-04 08:52:30.804 Setting PATH for this process: C:\Python37\;C:\Program Files\Git\cmd\;C:\Python37\Scripts\;C:\Python37\;e:\st_toolset\asm;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;d:\Program Files (x86)\IDM Computer Solutions\UltraEdit;D:\MATLAB\R2016a\runtime\win64;D:\MATLAB\R2016a\bin;D:\MATLAB\R2016a\polyspace\bin;C:\Program Files\Git\cmd;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;E:\TortoiseSVN\bin;C:\Go\bin;C:\Program Files\CMake\bin;D:\cygwin64\home\ASUS\tools\bin;C:\msys64\home\ASUS\tools\bin;C:\Program Files (x86)\GNU Tools ARM Embedded\5.4 2016q3\bin;C:\Cadence\SPB_16.5\OpenAccess\bin\win32\opt;C:\Cadence\SPB_16.5\tools\Capture;C:\Cadence\SPB_16.5\tools\PSpice\Library;C:\Cadence\SPB_16.5\tools\PSpice;C:\Cadence\SPB_16.5\tools\specctra\bin;C:\Cadence\SPB_16.5\tools\fet\bin;C:\Cadence\SPB_16.5\tools\libutil\bin;C:\Cadence\SPB_16.5\tools\bin;C:\Cadence\SPB_16.5\tools\pcb\bin;C:\Program Files\Mercurial;C:\Program Files\Git\bin;E:\Microsoft VS Code\bin;
2020-04-04 08:52:30.804 PYTHONPATH=
2020-04-04 08:52:30.804 Extracting temporary file: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\7za.exe
2020-04-04 08:52:30.882 Extracting ESP-IDF reference repository: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\7za.exe x -oC:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp -r -aoa "E:\.espressif\releases\esp-idf-v4.0.zip"
2020-04-04 08:52:30.882 Reference repository path: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\esp-idf-v4.0
2020-04-04 08:54:14.637 Done, exit code=0
2020-04-04 08:54:14.637 --------
2020-04-04 08:54:14.637 Running command: C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\7za.exe x -oC:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp -r -aoa "E:\.espressif\releases\esp-idf-v4.0.zip"
7-Zip (a) 19.00 (x64) : Copyright (c) 1999-2018 Igor Pavlov : 2019-02-21
Scanning the drive for archives:
1 file, 415318076 bytes (397 MiB)
Extracting archive: E:\.espressif\releases\esp-idf-v4.0.zip
Path = E:\.espressif\releases\esp-idf-v4.0.zip
Type = zip
Physical Size = 415318076
Everything is Ok
Folders: 2381
Files: 11484
Compressed: 415318076
2020-04-04 08:54:14.637 Copying C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\esp-idf-v4.0 to e:\esp-idf
2020-04-04 08:54:57.177 Done, exit code=0
2020-04-04 08:54:57.177 --------
2020-04-04 08:54:57.177 Running command: cmd.exe /c ""xcopy" /s /e /i /h /q "C:\Users\ASUS\AppData\Local\Temp\is-4HFR2.tmp\esp-idf-v4.0" "e:\esp-idf""
复制了 11484 个文件
2020-04-04 08:54:57.177 Resetting the repository: C:\Program Files\Git\cmd\git.exe -C e:\esp-idf reset --hard
2020-04-04 08:55:06.865 Done, exit code=0
2020-04-04 08:55:06.865 --------
2020-04-04 08:55:06.865 Running command: C:\Program Files\Git\cmd\git.exe -C e:\esp-idf reset --hard
HEAD is now at 463a9d8b7 Merge branch 'bugfix/ci_deploy_tags_v4.0' into 'release/v4.0
2020-04-04 08:55:06.865 Resetting the submodules: C:\Program Files\Git\cmd\git.exe -C e:\esp-idf reset --hard
2020-04-04 08:55:42.807 Done, exit code=0
2020-04-04 08:55:42.807 --------
2020-04-04 08:55:42.807 Running command: C:\Program Files\Git\cmd\git.exe -C e:\esp-idf submodule foreach git reset --hard
Entering 'components/asio/asio
HEAD is now at 55efc179 Merge branch 'idf' into 'master
Entering 'components/bootloader/subproject/components/micro-ecc/micro-ecc
HEAD is now at d037ec8 Add note that uECC_VLI_NATIVE_LITTLE_ENDIAN affects key compatiblit
Entering 'components/bt/controller/lib
HEAD is now at 5a2416f component/bt: allow adv stop again and fix tx prog crash(79dd6f18
Entering 'components/bt/host/nimble/nimble
HEAD is now at b2ae70c3 Merge branch 'nimble/minor_fix' into 'nimble-1.1.0-idf
Entering 'components/coap/libcoap
HEAD is now at cfec0d0 configure.ac: bumped version number to 4.2.
Entering 'components/esp_wifi/lib_esp32
HEAD is now at c3fa441 Fix WiFi beacon timeout and connect fail when coexist with BT/BLE(581f4224
Entering 'components/esptool_py/esptool
HEAD is now at de30f21 Version 2.
Entering 'components/expat/expat
HEAD is now at a7bc26b Set release date for 2.2.
Entering 'components/json/cJSON
HEAD is now at 3c89356 Merge pull request #355 from DaveGamble/release-1.7.1
Entering 'components/libsodium/libsodium
HEAD is now at 70170c28 Inden
Entering 'components/lwip/lwip
HEAD is now at c9e3b53c optimize tcp random clos
Entering 'components/mbedtls/mbedtls
HEAD is now at f5f2e5926 Merge branch 'fix/warnings_in_NimBLE_build_failure' into 'mbedtls-2.16.2-idf
Entering 'components/mqtt/esp-mqtt
HEAD is now at 566b034 Merge branch 'bugfix/err_event_mqtt_related' into 'master
Entering 'components/nghttp/nghttp2
HEAD is now at 3bcc416e Update manual page
Entering 'components/protobuf-c/protobuf-c
HEAD is now at dac1a65 Merge pull request #283 from protobuf-c/edmonds/changelog/1.3.
Entering 'components/spiffs/spiffs
HEAD is now at f5e26c4 fixes #16
Entering 'components/unity/unity
HEAD is now at 7d2bf62 Merge pull request #363 from Deltrix/patch-
Entering 'examples/build_system/cmake/import_lib/main/lib/tinyxml2
HEAD is now at 7e8e249 Merge pull request #707 from SwiftEngineering/issue_70
2020-04-04 08:55:54.741 idf_tools.py exists in IDF directory
2020-04-04 08:55:54.741 UseBundledIDFToolsPy: version=v4.0, using bundled idf_tools.py
2020-04-04 08:55:54.741 Using the bundled idf_tools.py copy
2020-04-04 08:55:54.741 idf_tools.py command: C:\Python37\python.exe "E:\.espressif\idf_tools_fallback.py" --idf-path e:\esp-idf
2020-04-04 08:55:54.741 Installing tools:C:\Python37\python.exe "E:\.espressif\idf_tools_fallback.py" --idf-path e:\esp-idf install
2020-04-04 08:56:03.461 Done, exit code=0
2020-04-04 08:56:03.461 --------
2020-04-04 08:56:03.461 Running command: C:\Python37\python.exe "E:\.espressif\idf_tools_fallback.py" --idf-path e:\esp-idf install
Installing tools: xtensa-esp32-elf, esp32ulp-elf, cmake, openocd-esp32, mconf, ninja, idf-exe, ccache
Skipping xtensa-esp32-elf@esp-2019r2-8.2.0 (already installed)
Skipping esp32ulp-elf@2.28.51.20170517 (already installed)
Skipping cmake@3.13.4 (already installed)
Skipping openocd-esp32@v0.10.0-esp32-20190313 (already installed)
Skipping mconf@v4.6.0.0-idf-20190628 (already installed)
Skipping ninja@1.9.0 (already installed)
Skipping idf-exe@1.0.1 (already installed)
Skipping ccache@3.7 (already installed)
2020-04-04 08:56:03.461 Installing Python environment:C:\Python37\python.exe "E:\.espressif\idf_tools_fallback.py" --idf-path e:\esp-idf install-python-env
2020-04-04 08:56:44.084 Done, exit code=1
2020-04-04 08:56:44.084 --------
2020-04-04 08:56:44.084 Running command: C:\Python37\python.exe "E:\.espressif\idf_tools_fallback.py" --idf-path e:\esp-idf install-python-env
Creating a new Python environment in E:\.espressif\python_env\idf4.0_py3.7_env
Installing virtualenv
Collecting virtualenv
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (4.6MB)
Exception:
File "C:\Python37\lib\site-packages\pip\_vendor\urllib3\response.py", line 360, in _error_catcher
yield
File "C:\Python37\lib\site-packages\pip\_vendor\urllib3\response.py", line 442, in read
data = self._fp.read(amt)
File "C:\Python37\lib\site-packages\pip\_vendor\cachecontrol\filewrapper.py", line 62, in read
data = self.__fp.read(amt)
File "C:\Python37\lib\http\client.py", line 447, in read
n = self.readinto(b)
File "C:\Python37\lib\http\client.py", line 491, in readinto
n = self.fp.readinto(b)
File "C:\Python37\lib\socket.py", line 589, in readinto
return self._sock.recv_into(b)
File "C:\Python37\lib\ssl.py", line 1052, in recv_into
return self.read(nbytes, buffer)
File "C:\Python37\lib\ssl.py", line 911, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
File "C:\Python37\lib\site-packages\pip\_internal\cli\base_command.py", line 179, in main
status = self.run(options, args)
File "C:\Python37\lib\site-packages\pip\_internal\commands\install.py", line 315, in run
resolver.resolve(requirement_set)
File "C:\Python37\lib\site-packages\pip\_internal\resolve.py", line 131, in resolve
self._resolve_one(requirement_set, req)
File "C:\Python37\lib\site-packages\pip\_internal\resolve.py", line 294, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File "C:\Python37\lib\site-packages\pip\_internal\resolve.py", line 242, in _get_abstract_dist_for
self.require_hashes
File "C:\Python37\lib\site-packages\pip\_internal\operations\prepare.py", line 334, in prepare_linked_requirement
progress_bar=self.progress_bar
File "C:\Python37\lib\site-packages\pip\_internal\download.py", line 878, in unpack_url
progress_bar=progress_bar
File "C:\Python37\lib\site-packages\pip\_internal\download.py", line 702, in unpack_http_url
progress_bar)
File "C:\Python37\lib\site-packages\pip\_internal\download.py", line 946, in _download_http_url
_download_url(resp, link, content_file, hashes, progress_bar)
File "C:\Python37\lib\site-packages\pip\_internal\download.py", line 639, in _download_url
hashes.check_against_chunks(downloaded_chunks)
File "C:\Python37\lib\site-packages\pip\_internal\utils\hashes.py", line 62, in check_against_chunks
for chunk in chunks:
File "C:\Python37\lib\site-packages\pip\_internal\download.py", line 607, in written_chunks
File "C:\Python37\lib\site-packages\pip\_internal\utils\ui.py", line 159, in iter
for x in it:
File "C:\Python37\lib\site-packages\pip\_internal\download.py", line 596, in resp_read
decode_content=False):
File "C:\Python37\lib\site-packages\pip\_vendor\urllib3\response.py", line 494, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "C:\Python37\lib\site-packages\pip\_vendor\urllib3\response.py", line 459, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File "C:\Python37\lib\contextlib.py", line 130, in __exit__
self.gen.throw(type, value, traceback)
File "C:\Python37\lib\site-packages\pip\_vendor\urllib3\response.py", line 365, in _error_catcher
raise ReadTimeoutError(self._pool, None, 'Read timed out.')
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Read timed out.
You are using pip version 19.0.3, however version 20.0.2 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' command.
File "E:\.espressif\idf_tools_fallback.py", line 1196, in action_install_python_env
import virtualenv # noqa: F401
ModuleNotFoundError: No module named 'virtualenv'
File "E:\.espressif\idf_tools_fallback.py", line 1487, in <module>
main(sys.argv[1:])
File "E:\.espressif\idf_tools_fallback.py", line 1483, in main
action_func(args)
File "E:\.espressif\idf_tools_fallback.py", line 1200, in action_install_python_env
stdout=sys.stdout, stderr=sys.stderr)
File "C:\Python37\lib\subprocess.py", line 347, in check_call
subprocess.CalledProcessError: Command '['C:\\Python37\\python.exe', '-m', 'pip', 'install', '--user', 'virtualenv']' returned non-zero exit status 2.
2020-04-04 08:56:44.084 Message box (OK):
2020-04-04 08:56:50.163 User chose OK.
2020-04-04 08:56:50.163 Message box (Yes/No):
2020-04-04 08:56:52.643 User chose Yes.
2020-04-04 08:56:52.737 CurStepChanged raised an exception.
ESP_igrr
Postby ESP_igrr » Sun Apr 05, 2020 10:40 am
Looks like a network issue, perhaps try again, or configure pip to use mirror? (pip.ini on Windows, see https://topic.alibabacloud.com/a/pypi-c ... 76251.html)
LINGdong0110
Postby LINGdong0110 » Mon Oct 12, 2020 7:25 pm
成功安装Python 2.7.18.amd64.msi后(卸载python3.7.0暂时无法通过?),再安装esp-idf-tools-setup-2.3.exe也通过了!
