ESP Wrover KIT UART problem,Rx not working
radoslav.iliev
Postby radoslav.iliev » Thu Apr 02, 2020 8:34 am
Hello everyone,
I use the sample code from the uart_echo example, exactly:
#define ECHO_TEST_TXD  (GPIO_NUM_1)
#define ECHO_TEST_RXD  (GPIO_NUM_3)
#define ECHO_TEST_RTS  (UART_PIN_NO_CHANGE)
#define ECHO_TEST_CTS  (UART_PIN_NO_CHANGE)
#define BUF_SIZE (256)
#define RESP_SIZE (128)
void main()
   uart_config_t uart_config = {
		.baud_rate = 115200,
		.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
	uart_driver_install(UART_NUM_0, BUF_SIZE * 2, 0, 0, NULL, 0);
	uart_param_config(UART_NUM_0, &uart_config);
	uart_set_pin(UART_NUM_0, ECHO_TEST_TXD, ECHO_TEST_RXD, ECHO_TEST_RTS, ECHO_TEST_CTS);
That works without problems on Pico KIT, but not on the Wrover. From the Wrover I only can read the logs, but not to write.
I am using IDF-v3.3 on Visual GDB. It installed the drivers automatically. The interesting thing is that I see only one COM port from it, which works for uploading via JTAG, debugging also works.
Thank you in advance.
Users browsing this forum: No registered users and 38 guests
